Frank Drebin
About Frank Drebin
890 profile views
Frank Drebin's Achievements
  1. May be this? http://www.fordedgeforum.com/topic/18267-titanium-tailgate-and-hill-wont-close/?do=findComment&comment=133557
  2. Exact, remove the bench, unbolt the 2 bolt you see, flip down the rear rest, unbolt the 2 other bolt, move up the rear rest and put the foam under the metal bracket between the bracket (black) ans the tole (white).
  3. I did it during the week-end and...it's FIX!! I use foam used under Wood floor.
  4. The peddles are correct BUT...the footrest is too thick for nothing!! It's annoying...Have to rest my left feet on the ground! If I rest my feet on the footrest...after 5-10 minutes, I realize I'm pushing with my left feet (because my left knee is 2 inch higher than my right knee (footrest too thick)) on the floor and creating a back pain. And you??
  5. It's not the problem. The dealer remove the nut and tightened it down correctly. I'm gonna put a layer of foam between the parts and try it again on the road during the week-end
  6. After a couple month, I sat in an another Edge Sport, Explorer 2016, Taurus 2016, Escape 2016 and every car had a little off steering wheel... I think it's for a proportional space between the door/seat on the driver side and door/seat on the passenger.
  7. FOUND!! Under the bench of the rear seat, passenger side, left bracket who fix the rest on the floor
  8. Yes, 2015 Sport awd There's only 1 wire on the driver side under the bench. Easily disconnectable.
  9. Primo: GO with the lemon law!! Second: "you're not eligible for a rental...WTF are they serious!?! After 10 days !?!
  10. Finally, having the work done on my Edge. 1- They change both rail for the pano roof ("toc" while opening gone...) SOLVE 2- Rattle under the bench of the rear seat... After searching...didn't found something wrong !!?!?! NOT SOLVE 3- Weird sound over my head (roof? headliner?) while the body structure are under light torsion... NOT SOLVE For #2... I'm testing something else tomorrow For #3... I do not find where (exactly) the sound is coming....
  11. I was able to remove mine quickly and easily. Push the front clip (under the bench/front side where the legs rest) on each side. Push the bench (toward the back rest as much as you can) and pull out the rear of the bench (each side separately). I don't ok if it' clear (I'm a french guy)...
  12. This one? (Over my head...driver side...near of the B pillar)
