Tjbagz
About Tjbagz
Tjbagz's Achievements
  1. Can anyone help me with rear lower control arm bolt removal? I am in process of installing bags and have removed bottom shock mount, and now want to remove lower arm bolt so i can drop out spring. I have removed outboard nut, jacked up to remove pressure and stud does not budge. I see on inside there is small bolt, and where I removed nut on outboard side, stud has allen keyway. Am I just missing something....? Any help much appreciated.
  2. Lower control arm bolt.... Cant figure how to remove still, seems simple but nut on one side (outboard) and small bolt on inboard side. Take off outboard, jack stand under to remove pressure, and does not budge. (Allen key in center of stud). Anyone got advice?
  3. Can anyone tell me how to remove rear lower control arm bolt? I am in the middle of trying to install air bags and can not seem to get bolt out. Thanks for any and all info.
  4. Has anyone installed airlift system on 2013 edge? Would like to know if it is doable (at home)instructions seem very generic. Need to carry a lift on back and power wheelchair. Any help would be appreciated!
