quincy
About quincy
751 profile views
quincy's Achievements
  1. Technically I've owned this vehicle for 13 years, since I purchased it new in Nov of 2011, as a 2012 model year. I have been very happy with this Edge for all those years. She currently has 103,000 miles on her. Just had a safety inspection performed, along with oil change and tire rotation and air filter/cabin filter. Master Mechanic states nothing wrong with the chassis or suspension or steering or engine or transmission or brakes or electrical system. I've had one brake job, one set of tires, one battery, one spark plug change. one throttle body cleaning, one transmission oil change, one engine coolant change, new belts and idler pulley. I consider this as normal maintenance, as is the case with all ICE vehicles. A/C has not been serviced, and still blows cold. I did have a issue with the brake pedal going to the floor with loss of braking effort at around 60K miles. The dealership had the car for 5 weeks trying to figure out what was wrong. The Ford Dealership wound up changing the brake booster, master cylinder, ABS unit, ABS computer, and fluid twice. It was a $1600 bill, and I never really got a good answer as to what was wrong. The only other repair was a fuel filler tube (no traditional gas cap) replacement. The brake issue is the only major glitch we have had with the Edge. The body is solid, no rust or corrosion. Paint still shines like new. Interior and carpeting is in excellent condition. I still like my Edge, and I would buy another, but alas, this vehicle has been discontinued after 2024 MY. I've owned lots of Fords over the last 55 years, and this has been one of my favorite ones!
  2. Interesting nugget of data / information that I can not verify as of July 2019. I no longer take my Ford to the Ford dealership because they have lost my trust. I now take it to the local shop who I allow to work on my 1999 Plymouth Prowler. I had the Prowler in for an oil change and was talking to the master mechanic. The subject came up about the loss of brakes on my Ford Edge. He was familiar with the issue, which surprised me. He stated that it is an issue with the master cylinder and some internal seals. They get pushed out of their 'seat' creating an internal leak. The fluid pressure can not build up as required. He said that if you pull the brake pedal back very quickly and with a lot of force that will temporally correct the problem. (pull the seals back into place?) In his words only a rebuilt master cylinder will permanently correct the issue. New master cylinders will suffer from the same issue (perhaps a manufacturing spill??) Any way so far so good on the brake fix. But, in the back of my mind I'm waiting for this to occur once again......
  3. No other explanation was provided by the certified and trained experts at East Tennessee Ford. After 5 weeks in the shop only a mystery 'second special bleed procedure' involving the application of the the emergency brake brought the brake pedal back up to normal. Coincidence? Perhaps? Incompetence at the technician level? Perhaps? The point of this post is to warn others of a potential issue, and to advise owners to have their brake fluid system flushed every so often. Cheap insurance! It took two others to concur that off gassing in the brake system was even possible while others cast stones..........
  4. Yes, it does sound odd, but there is a safety recall out for the condition. I did not make the recall number up. It really exists. I realize 1 + 1 does not always = 2, but this one company makes all the brakes for the major OEM's. Just like Takata made the air bagas for the major OEM's. Look at that debacle. As of this date (3/5/19) I have not been contacted by anyone at NHTSA. Time will tell if they ever do. In the meantime my braking system is 100% functional and I have a 2 year 24K mile warranty from the dealership.
  5. Here you go! Lou https://www.consumerreports.org/car-recalls-defects/honda-recall-acura-honda-suvs-and-minivans-brake-issue/
  6. Akirby, Spend a few minutes on Google....search for 'sudden loss of brake pedal on Ford Edge'. You can spend an afternoon reading about this condition. There are folks who have even placed a video of the issue on youtube; and some folks have had a repeat of the issue. Most, if not all of the reporting owners, have not taken their vehicle to a Ford Dealership, as I did. My Ford vehicle has only been serviced at a Certified Ford Dealership its entire life. There is an obvious reason for that....Ford Techs are certified in repair of Ford Vehicles. Not many years ago brake systems were relatively simple. Then in the mid 90's ABS came into vogue. Now we have Traction Control and StabiliTrak systems. The latter systems APPLY brake force to certain wheel ends to either transfer torque side to side or to halt wheel spin. These systems work in conjunction with ABS but are more complicated. These are PRAM parts, safety related, and I would hope the Tier One companies spend sufficient time on the required Design and Process FEMA's It is also very plausible that Ford is not aware of the condition that can occur....the off gassing of a coating on internal brake components. Since the brake system is 'purchased finished' from Akebono it is possible 'they' are not sharing important safety data with Ford. I'm hoping once the government shutdown is over and the engineers have a chance to catch up they will contact me so I can share this data with them for further analysis. We will see..... BTW, I am the original owner of this Edge, purchased new off the lot in 2012, and currently with less than 47K miles on the ODO. It's been a very good vehicle (up to this point) and is still one of the favorite vehicles I've owned during my lifetime of driving, 50 years worth.
  7. Bill, I hope your correct. I do appreciate your input. I don't feel I'm being 'hysterical', just cautious, and not very trusting. I worked in the big three (including Ford) for a total of 35 years. Engineering and Design....I know how they operate. I've seen 'blind eye' decisions made based on the almighty dollar....... Understand, I never received a logical answer from the Ford Dealership on what went wrong to cause the primary 'loss of brake pedal' issue. After 5 weeks in the Ford Dealership shop they became 'parts changers', returned the vehicle to me with the same condition, stating this is the 'new normal'. I would not accept that 'repair answer' and handed the keys over to the service manager telling him to let his wife drive the car for a month. In the meantime my daughter received a recall on her Honda van, which uses the same Tier One Brake Supplier Ford uses, Akebono. Same caliper set up, same basic parts. It seems that some internal components to the hydraulic system are 'off gassing' in some way. thus introducing air into the system. A special brake bleed procedure is necessary to remove this air. I call this discovery 'good Karma' and a warning of a 'system issue' which may be covered up. I would recommend a preemptive brake bleed to any one with a Ford Vehicle to help prevent this from occurring to them. This service can be performed at any Ford Dealership for under $100.00. I was lucky I could pull over to the shoulder.....there will be those who will not have that option.
  8. That's now up to the U.S. government. I will assist them at no cost for as long as necessary. NHTSA has the deep pockets necessary to uncover safety issues.....
  9. The engineering is all the same across all these vehicles. Same components. Do a google check on loss of brakes on a ford edge....hundreds of people have posted on line. When the potential exists for loss of life, I'm sorry, your perceived etiquette rule does not apply. All you have to do is look at the Takata Debacle....... The 100% way to verify this would be to examine all the components drawings from Akebono. If you can obtain them I would be happy to review them.
  10. At the end of October, 2018, the brakes went out on my 2012 Edge while on the freeway. Here is the link to my original post: Now we are into 2019 and here is some additional information I have discovered about this issue! Dealer could not explain what went wrong. I had to push the issue hard with the svc. manager. Finally after the 2nd "special brake flush" issue with brakes was corrected! Now for the smoking gun..Daughter has a 2019 Honda Odyssey van. Recently she gets a recall for a brake issue. Honda must bleed rear brakes with a special procedure. I looked up the Honda recall. Seems there is an Issue with "coating on rear internal disc brake parts; creates air bubbles inside (sealed) system causing loss of brake pedal". I study up on who supplies brakes to Ford and Honda (& many others)....A Company called Akebono supplies to most of N.A.! This is another "Takata" issue brewing! I suspect Ford is covering up any knowledge of this 'loss of brake' issue. I suspect that this 'loss of brake issue' will occur on thousands if not millions of other vehicles, it's just a matter of time! Felt strong enough about this potential fatal issue to make another post (this one) and to file a complaint with NHTSA.....#11164252. Please pass this info on to others as necessary........
  11. OK. Thanks everyone. It seems my SEL does not have adjustable headrests. So, it looks like I will be trying the vice adjustment trick first. I suppose I could swap the drivers for the passengers headrest. Pass side seems to be in a more comfortable position. Not sure why FoMoCo would do this??? Cheers and Merry Christmas
  12. Greetings! Does anyone know how to adjust the headrest fore and aft. (front to back....NOT up and down) Or some might call it tilt. The top of my headrest is tilted to far forward at the top. I have no idea how to adjust it. If you do know how to adjust the headrest, please explain how? Thank You,
  13. Bleed included the HCU. And yes, as explained to me the parking brake was applied multiple times during the process and at least 30 pounds of force applied to the brake pedal. That did the trick and I am once again with proper brakes. I hope others with this same issue are lucky enough to read this post to gain some knowledge. If you can, please copy and paste the Ford procedure for this unique bleed process below. It may save someone from a crash or worse......Thanks. I do not fully understand the failure mode on this event, and do not want to experience it again.
  14. Closing the loop on this subject. It's important to always close the loop on major issues so people can learn, save time, energy, money, or their lives! This ordeal has taken from November 30th to December 3rd, 2018. An eternity when your dealing with loss of brakes! Went back to the same dealership yet again today to have yet another 'brake flush' or power bleed performed on my vehicle. I complained over and over that the brakes felt like mush and the pedal would go to the floor. It took the dealership ~ 2.5 hours to perform the bleed. The service manager was now involved, upon my insistence. I got the vehicle back and low and behold, my brakes feel like original equipment, brand new, off the lot!! So, what happened that was different?? The first tech did not perform the bleed procedure as specified in the manual. The second tech did. This is the story I am being told....... There is a very specific procedure called out and if you take any shortcuts you will not have a decent brake pedal. Even though I got the run around and lied to about many things, I am happy to say my brakes are finally fixed!
  15. Hummm. I don't do social media so that door is closed. What a debacle, but not really unexpected.
