Got the Edge back tonight from the second attempt for the fix. Thanks to Tricia at Ford who helped the dealership find out that a technical bulletin had been issued. They put in a "CT4Z 7210 KC: Gear Shift Lever," because the gear shift lever sometimes did not recognize that the car was in park and off, causing a draw on the battery. Got a new battery on the first trip in and just lucky that it was all covered under warranty. They even supplied a loaner Ford Focus for the 2 days they needed the car the second time. Hopefully, this will solve the issue. To those of you who may have had to pay for the fix for this problem, I would tell you to save the receipts because if a recall occurs, you can be reimbursed for your expense.
