bubbadewsky
Everything posted by bubbadewsky
I still have a My Ford Touch SD navigation card the newest one A-11 for $25, traded my Edge off 304 813 5973 Like Comment
Black Weather Tech floor liners like new........A11 map SD
bubbadewsky replied to bubbadewsky's topic in Classifieds
...call 304 813 5973 -
those wheels you have are 20in there is a company that sells wheel skins exact replacement https://www.hubcaphaven.com/p/25540/imp-3847-ford-edge-replacement-chrome-clad-wheel-cover-20-inch-single.html
- 4 replies
- 2
- 20 inch chrome clad wheels
- 2013 ford edge
bubbadewsky posted a topic in Classifieds
Best offer A 11 SD card is newest and works great A11.... floor liners like new 2014 Edge and other years Traded the Edge off....make offer -
I went to the dealership today for antifreeze for my 2014 Edge and they told me they just changed the recommended antifreeze to a new type green that is not the old green or yellow. Can this be verified
https://www.hubcaphaven.com/p/25540/imp-3847-ford-edge-replacement-chrome-clad-wheel-cover-20-inch-single.html I just had new tires installed the dealership gouged the wheels and they replaced all four, very expensive. Check out these replacement covers they look good to me. Removal and installation vids are on U Tube. They also have replacement wheels. Good used wheels are hard to find
if they are very good they will sell
Has anyone had rims gouged during tire change or balance. Dealer already replaced one and just destroyed another. Glad they are being responsible. They have a so called state of art changer and balancer. One was while changing and other on balance machine
Has anyone tried replacement plastic clad covers on their 20 in wheels there is a place called hubcap haven that sells them they look good and good price....what do you think phone 877 482 4283 hubcaphaven.com
Dried blood on headliner
bubbadewsky replied to bubbadewsky's topic in Interior, A.C., Heat, Interior Trim
Unfortunately they would not tell me but since you are not local maybe they will tell you or if possible stop by...Nelson Auto Sales ...Ridgeley, WV. -
Was on headliner for over a month, two spots both the size of a quarter. Took it to a used car lot that has an excellent detail shop. Half hour later blood gone and looks like new again
Reread the post if you use a long enough transparent hose you can see when the dirty oil gets close to the engine. I used an icemaker hose and the oil was drained several feet before reaching engine. As far as asking a ford dealer, they all say you do not need to change ptu oil for 100,000 miles. Now what is the stupidest post
That may be a casting number. I need the same part only for the left rear door on a 2014 Edge. Mine has a scar from a dog crate. Most of it rubbed out but I don't want to rub down to black plastic (is that silver paint on black plastic????) Ford told me you have to order the whole door panel and junk yards most likely only sell the whole panel. If you find out anything let me know
I just added 19 gal to my 2014 AWD edge.....gauge said 1 mi to empty
ford sync no longer supported by ford
bubbadewsky posted a topic in Audio, Backup, Navigation & SYNC
Got an email stating the above, what does this mean?? -
title just about says it all. I checked Levittown ford prices and comes to about $1,700 I pamper this car likes a princess.I am sure aftermarket prices may be less and same with used. Should I demand Ford new oem parts or be happy with Allstate. Still waiting on their reply ...Any input would be helpful. 2014 edge sel, loaded, 38,000 mi perfect until this. Allstate customer since1970 no claims for many years
Fill plug easy to acces. Used lift but jack stands will work
I had the oil changed in the ptu today using a BG machine. Was able to suck out approx. 14 oz each time, we did a drain and refill two times. Run the engine and wheels in between changes. The 2014 Edge has 20,700 miles on it. The oil color looked amber almost like new motor oil and felt like new motor oil. Filled up with Royal Purple 75-140. I think I will change it every 20,000 mi. No reason to change sooner or later.. This could be just as easily done with a cheap vac. pump. Fill plug easy to get to. Took about two min. for the machine to suck out the oil.
What is the first year for PTU drain plugs installed by ford? Mine is a 2014 does it have a drain plug.....thanks
I have a 2014 Edge only been in salt once. I washed the undercarriage after, it has no rust. I would wash that undercarriage very well and apply a coat of heavy oil on the rust..............will be ok for atleast 30 yrs. Years ago we used to get an oil can and squirt the undercarriage then drive down a dusty dirt road rust was never a problem then. I found that undercoating peels after a few years then the peeled sections become traps for salt
Is there supposed to be a large dust shield that needs removed to change oil and filter on a 2014 edge 3.5? Mine did not have one and I bought it new. Changed oil on my sons 2014 Focus today and it has a large dust shield that covers the bottom of the engine compartment that we had to remove to even see the drain plug and filter.
Weather Map malfunction?
bubbadewsky replied to bubbadewsky's topic in Audio, Backup, Navigation & SYNC
I think its 6 mos. You can get a better deal than $20 per month, call them and haggle with them before expiration date. I forgot how much my 1 yr extension was but it was way less than $20 -
2014 edge. Yes Sirius travel link, I also think I shut the car down today and locked the doors and returned 15 min later and the radio was playing music -
When I have the weather map on the display it will revert back to displaying the regular road map screen for a few seconds then back to the weather map for a few minutes then back to the regular road map is this normal
Can anyone post the success of drilling and installing a drain plug for their PTU unit and what size plug. Did you drill while in vehicle Did you use the suggested drilling location posted in earlier threads here. What is the warranty on a PTU unit. Thanks
