Everything posted by gmfranco88
Ford Edge Door Sill Plates Kit Charcoal Black - Brushed Aluminum
gmfranco88 replied to gmfranco88's topic in Classifieds
Bump.. Still in garage. Anyone interested? -
I have 35% on my fronts, and they are very close to factory. I did however had a hard time passing inspection this year in NY due to the tints. As of Jan 1st 2017, cars with aftermarket tints will not pass inspection in NY. I was lucky to find a place were this wasn't enforced yet.
Hello toast1850, They are. Apologies for late response, I do not frequent the forum as much as I used to. PM me your zip code to check shipping. -
No, these are the stock ones. The dealer installed the illuminated ones and left these in my trunk. -
Let me know if you find some that fit the Sport Trim. Have been looking for these as well for a while! can't seem to find them.
I use QuadLock. http://www.quadlockcase.com/ I have the QuadLock case, with the Car, Bike and Armband mounts.
Cleaning my garage.. Still have these for sale! -
Ford Edge 4-Piece Ebony Front & Rear Carpeted Mats
Sorry. These have been sold! -
Hello Westo, The most important part of the install was actually letting them set for 12 hours or so without opening the window. This will allow the M3 double sided tape to fully adhere. If you still run into issues, try pulling slightly on them to make more room for the window. With some trial and error you should be able to get them to not interfere with window functionality.
gmfranco88 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Installed WeatherTech Visors & MGP Sport Caliper Covers -
Hello Guys, Now that fall is here, I purchased and installed the Weathertech Front/Back Window Deflectors. 10 Minute install, look great on car. -
Lupid, I did not remove any of the pieces. Although that would have made the process much easier. It took me about an hour to wrap it, specially since i wanted the pattern to match from the center trim piece to the left/right pieces. Because of the curvature of the trim pieces over the headlights, these need a little more time and attention while heating the vinyl to properly maintain the pattern without stretching the vinyl and causing it to warp. From what I saw, the center trim pieces is easy to remove. There are only a couple of screws and a clip to remove the center trim. The trim on top of the headlights also have screws that can be removed, however, one of the screws on each side is convered by the side fenders. I didn't see a way to remove the headlights without removing the bumpers, thus the reason why I decided to do it without removing the pieces.
Hell Lupid, I remember when I was searching for a way to remove that chrome piece between hood and grille I would search for Chrome Trim, and for the ones above the headlights i would search for Headligh Chrome Trim, etc. I ended up wrapping it in Carbon Fiber Vinyl.
No interest? Still for Sale.. -
20" Scraped Wheel Lease Turn in Question
gmfranco88 replied to Cassie McCracken Gokey's topic in Wheels & Tires
Hello Cassie, I had a Ford Fusion with the 19" wheels and the same happened when my wife took the car one night. They didn't really make a big deal about it. I had a couple of dents in the hood, road rash on all wheels, couple of gauges on the wheels plus a keyed door.. total damage came out to $214. Since I was getting another car from ford, they waived the fee. -
Bump -
Bump. -
Hello All, Wrapped the top trim using carbon fiber vinyl. I did not take bumper off, simply wrapped all pieces as best I could. The most tedius parts were the trim above the headlights. It took me a while since I wanted the pattern to match from the center trim all the way to the headlight trims. I have to re-do the left headlight trim, since I ended up stretching a bit to much, which distorted the carbon fiber pattern. I also wrapped the ford logo. Overall I think it looks great. Will be doing the back Ford logo sometime this week as well. Vinyl specs on sig.
bump -
bump -
Daytime Driving lights
gmfranco88 replied to Bignate417's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I actually love the look of the turn signals of the DRLs. As normcloutier said, you really won't notice they are there if you don't hook them in.. But atleast have the option to turn them on if you change your mind. -
Windshield sunstrip tint
gmfranco88 replied to N14020's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yes no problems at all.. Except the obvious air pockets that are visible from the outside, but that's normal with any tint installation over that dot matrix. From inside all looks good. 35% tint. -
RustyEdge just PMed you -
Xenon Depot kit troubles
gmfranco88 replied to mestguy182's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Perhaps you need a harness that draws the initial startup power directly from the battery? I have 35w 6000k HID kit with an additional harness which stopped the flickering and false starts. -
dacurb, you most likely getting the streaks from the felt-like material that is located on the inside of the outer panel. If you lower your window you will notice it. As a rule of thumb, I try not to lower my windows after a car wash to avoid the streaks.
