tanman_2006
Everything posted by tanman_2006
2010 Ford Edge strut and brake replacement
tanman_2006 replied to tanman_2006's topic in Brakes, Chassis & Suspension
I've never had an injector or O2 sensor fail running seafoam. I even buy the spray can and flood the engine with it once a year and never had an issue. Ill stick with what I know there. As far as coolant I don't mind conventional but the Evans makes a good product imo and it cools duramax, 6.5, and 6.0 GM engines very well and for alot of miles. -
I run Evans in 2 other vehicles. It's oil based coolant and lubricates the water pump actually. I really don't think it would cause damage, you also don't run any coolant pressure with this fluid so it won't cause leaks due to pressure. -
Warranty on a 7 yr old nearly 200k mile car? -
The deer didn't scratch the car, it caved in the fender and both driver side doors. The scratch is new in the past 3 months. Since I told the wife the goal on the car is 500k miles she said it better not look like it has 500k on it, so happy wife happy life, it must look good -
I've done the turkey baster changes yearly on the power steering and brake fluid. I have a thermostat for the edge. It's on the pre 200k list once I get a chance. Anyone ever run Evans waterless coolant in these? I run seafoam fuel treatmemt in my gas every oil change. I've done this in every car/truck I've ever owned. -
Just spent the past 2 weeks reading your OC thread and this one. My head hurts... haha
- 668 replies
- 2
- 2011 Ford Edge
- Limiited
(and 4 more)
If that's what you want to call going from 80 mph to 0 in the blink of and eye for giggles haha -
For the record I did: Plugs Trans service Raybestos Premium pads on all 4 corners (lubed pins) Timken rear wheel bearings KYB struts KYB shocks Mobile 1 5w20 w/ wix xp Wix air filter 2 new cooper SRX tires (this makes 10 tires total being mounted on this econo beast) Old pads still had nearly 25% left. The new rear pads groan worse than the oem. Next on the to do list is clear coat peeling on the hood, front driver side fender has a 18" scratch (and it's new due to deer damage), front Ford emblem is fading, and a cab air filter (I just watched Mac's video on it) -
Yesterday we ended up on a 80 mile long beginner jeep trail by accident. Cinnamon took it like a champ, we got some funny looks though haha. -
It's done and we made it to Ouray. Got 24.6 mpg cruising 80. Been awhile since to drove without humming tires and did better than 22mpg. -
Plugs are on the list but not before vacation on the 10th unless we get time. I did all fluids at 100k when we bought it from my mom. Amsoil tans and fresh coolant. I had to give up my shop last year so I don't have a place to work and my wife needs it done quick as we only have 2 vehicles on the road at the moment. I'll look into the Ford credit that would be nice prevacation -
Ours has 17's. Our rotors aren't warped and the Ford dealer has a special on lifetime brakes through them so I will likely just do that. I will end up ordering rear wheel bearings and have them put in since we are nearing the 200k mark. I don't have time to do the work unfortunately so I have to take it in. -
Doesn't navigate on my phone and I was wanting to get my order in before I got home. Just got home so I'll figure it out. Thanks anyways. -
Anybody have a part number for the KYB strut and motorcraft strut mounts? This is on a 2010 Edge. Also need part numbers on the rear for shocks/struts.
Can a Mod delete this post so I don't have a double -
Our 2010 edge front wheel drive has been in the family since new with 182k miles on it now. It's never had any work done on it other than oil and filters. I figure it's time (passed time) for struts, strut bearings, and a set of brake pads. If anyone has the list of parts needed and part numbers I'd appreciate it so I can get things looked up on rockauto and Amazon and save a little money on repairs.
2010 Ford edge brakes and suspension
Double Post -
Plugs at 100k, oil and air every 10k, trans every 50k, all other fluids at 100k. Factory tires had 95k on them when we got it, bought 4 cheap hankook ventus tires for the rear and summer use, and 4 Cooper srx tires that are all season with a good winter rating. -
The strut mount broke at 20k miles and the whole strut was replaced on that side under warranty. Never been aligned, tires only last 80-90k per set. Honestly never saw a wear issue that needed addressed. Hubs feel tight. I don't feel a need to have vibration dampers. Only makes noise in reverse. I typically use Raybestos brake parts. So I need to get rear shocks and a 4 wheel alignment? Front struts are fine and just need new bearing mount assemblies? Just wait until hub bearings fail to replace them? -
Brakes are finally hitting the squeakers at 170k miles. This car has only had 1 front strut replaced since it was new. Otherwise it's all original. What should I replace as preventive maintenance? I was planning rotors, pads, and front strut bearings. My other parts in question are wheel bearings/hubs. Do the rear brakes have those dampers? Do I just get rid of them, if so what bolt size? Should I replace calipers or just relube the pins and keep using the originals? Thanks for any help!
Never mind, as I was backing out and kept selecting return it showed up. I selected off
I followed the book and never saw vehicle health report but I did turn promts off. We'll see
I don't have a touch screen, just a 6 disk/mp3. I have a phone button on the stereo
