GreatWyte
About GreatWyte
795 profile views
GreatWyte's Achievements
  1. I'm not sure about the interchangeability of the panels. I would think that if it was from the model years 2011-2014 and had the same features it would work. I ordered mine from my local dealership and didn't compare part numbers of the old one. Looking at my receipt the part number of the new panel I received is DT4T18A802CC.
  2. Is the programming/camera initialization something that you can do yourself, or do you have to take it to a dealer?
  3. Yes, I believe the part alone was $340. Initially my blower would turn up all the way. Then it started doing the opposite and turned down all the way, so I pretty much had no heat/AC, so I had to do something.
  4. The fix for my vehicle was the replacing the FCIM. The Front Control Interface Module was replaced in May of 2019 and has been good since.
  5. Has anyone found the fix for this issue? I am experiencing the same problem on a 2012 Edge Sport. Climate control kicks out of auto and blower turns all the way up. It keeps beeping as if the up button is being pressed repeatedly.
  6. Thanks for the tips in this post edgeguy08 and enigma-2. I had the problem described in this post; noise from vents and fan motor (especially when turning left) and water on passenger floorboard that was not antifreeze. With the climate control and radio off you could actually hear water sloshing around in the ductwork when driving. I located the drain hose under the dash on the drivers side and, blasted some compressed air up into the evaporator housing through the hose. That unclogged it and water started flowing out. I saw some pieces of leaves in the discharge so I'd say that was my problem. I don't have any odor but I ordered a can of Lubegaurd and will use it when it arrives to be on the safe side.
