U0415 - Invalid Data Received from ABS Module
enigma-2 replied to CrackedDSM's topic in Brakes, Chassis & Suspension
@CrackedDSM wasn't too specific as to the exact location. His advice was to start checking the wiring at each sensor (each wheel), follow up into car and then to ABS module. He found his break in the harness under the back seat. Its more likely that a break would occur under the car where it's subject to ice, snow, road debris like rocks and stuff. Under the back seat sorta tells me he had shoved something under the seat, hitting the harness. crusting. I'd also check the connector at the ABS module for green crusties. -
New phone techology limitation 2020 Edge
enigma-2 replied to BamaInArk's topic in Audio, Backup, Navigation & SYNC
VERY COMMON PROBLEM being reported with the S25. The S25 seems to have been optimized for use with the Samsung charger which limits max current when charging. The higher current causes the phone to get hot and shut down. When cooled, it starts to charge again. Then repeats. One user reported (Samsung forum) his charger (which worked perfectly with his S23) was drawing higher current when needing more charge (weak cell battery.) His fix was to charge the phone using a cable (connected to the 12v power port) to about 2/3 charged, then finish it off with the wireless charger. Said this solved the problem. -
I'll assume that both remotes are OEM. Sounds like the fob's are registered (as they seem to function.) Unlikey they'd both fail at the same time. So the next thing I'd check is to test the car's battery. May be failing. (Must check the CCA reserve, not the voltage. Even weak batteries can test over 14 v before cranking.)
This Ford website might help. https://veteransfordtampa.com/which-ford-vehicles-can-be-flat-towed#:~:text=Why Flat Towing?,for planning your next adventure.&text=Ford has a diverse lineup,the open road without limitations.
If I'm not mistaken, the single horn doesn't use a relay, where the dual horn assy requires the relay.
As an additional thought, have you tested your cold cranking capacity Amperage, of your vehicle battery? Low voltage can also cause the shift solenoid from functioning and cause various other systems from responding.
It's on page 188-9 of the owners manual. ------- "STOPPING THE ENGINE WHEN YOUR VEHICLE IS MOVING WARNING: Switching off the engine when your vehicle is still moving results in a significant decrease in braking assistance. Higher effort is required to apply the brakes and to stop your vehicle. A significant decrease in steering assistance could also occur. The steering does not lock, but higher effort could be required to steer your vehicle. When you switch the ignition off, some electrical circuits, for example airbags, also turn off. If you unintentionally switch the ignition off, shift into neutral (N) and restart the engine. E357998 1. Press and hold the push button ignition switch until the engine stops, or press it three times within two seconds. 2. Shift into neutral and use the brakes to bring your vehicle to a safe stop. 3. Shift into park (P). 4. Apply the parking brake."
... and any assistance or recommendations of anything that should be addressed maintenance wise, or preventive maintenance wise would be greatly appreciated. This response is a little late, but I'll give you my recommendations. Fluids Change the transmission fluid (important), PTU fluid (important), the coolant (important), the brake fluid, the power steering fluid, and the rear axle fluid. I'm assuming that the oil was changed on schedule. Look for a sticker & if its over mileage or missing completely, change the oil. Only use a Motorcraft filter. ->Consider having to oil change at local Ford dealer and request a "The Works" oil change. It includes a ¹synthetic blend oil change, ²tire rotation (and ³pressure check), ⁴brake inspection, ⁵vehicle checkup (ask for a close look at steering and suspension components, ⁶fluids top-off, ⁷battery test, ⁸filter check & ⁹belts/hoses check. Filters Check the engine air filter. Change the cabin air filter (definitely check this one, often over looked and can be harbor bacteria. Its located behind the glove compartment. There are YouTube videos that show how to change. Amazon has dozens for sale, use Motorcraft as your starting point.) If car has heated/cooled seats, (not heat only), there's a "filter" of sorts under the center of each seat. Use a flashlight and check to make certain its clear and there's nothing under to seat to block the fan intake. (It's opening is round, around 3" in diameter, under seat neater center.) Lights Do a walk around and make certain all lights are working. Have someone step on brakes when you check. Tires Check the spare tire for air pressure. This is often overlooked and they tend to leak down slowly & nearly flat when needed. Inflate to the pressure marked on the sidewall. Check air pressure in ALL four regular tires. Inflate to the pressure marked on the sticker on door pillar (NOT pressure marked on tire.) Rotate tires, drivers to passenger rear, passenger rear to passenger front, passenger front to drivers rear & drivers rear to drivers front. Wipers Check wiper blades. If new needed, drivers is 26", passenger is 20". These are beam type. Rear is 14", bow style. There are YouTube videos available to show you the secret to replace rear blade. (Bosch and Trico are the best, longest lasting.) Check windshield washer fluid. Do not use plain water. Check that it sprays on windshield AND rear window properly. Moon roof If she has a moon roof, consider spraying the track with silicone spray. Plugs Normally you change spark plugs at around 90k. Its a little early, but wouldn't hurt. (Not too bad on a 4-cylinder, but a 3.5L, V6 will run around $650.) It's very important that the plugs get changed on schedule as the older they get, the wider the gap and the more current it takes to fire them. More current means more heat in the coils. If the coils get too hot, they fail. If they fail by burning open, you only need change the coil (hundred bucks or so.) However if the coil shorts, it takes out the PCM (can get a rebuilt for around $250. New around $500, plus coils.) Let's see, doing this from memory, what am I forgetting? .
2013 Edge SEL Driver Seat Stuck in Full Recline Position
enigma-2 replied to Berndog's topic in 2013 Edge & MKX
This is a little late, but if you still have the problem, I had a similar problem with my passenger seat. Wife would be sitting in it and suddenly it would decide to fold back. (Kinda funny to be driving along and she started to disappear. She never found it funny though.) Anyway, the problem was the seat switch. (As I have the MKX, it was a 10 way switch.) Simple enough to replace, wrote about how to replace in a different article in this forum. -
2008 Edge Limited - Changing dash display from metric to imperial
enigma-2 replied to RobynL_328's topic in 2008 Edge & MKX
Look below the instrument cluster. There is a switch with three buttons. They are marked (left to right): "INFO", "SETUP" & "RESET." This control allows you select, change and reset several functions which are shown in the INFO screen at the bottom of the instrument cluster. Press "SETUP". This will allow you to make changes on the following areas; System Check Units (English/Metric) Autolamp Autolock Autounlock Apparently your boyfriend was pushing buttons to see what they did & forgot to set everything back to original. -
"Check Headlight/Headlamp System"?
enigma-2 replied to bruker's topic in 2019-Current Edge & Nautilius
It's issued to the headlight comtrol module and can be triggered by the the left or right swiveling motor or when the car lost communication with the headlight communication module. Probably triggered by a random network interruption. That it went away means it was probably momentary. -
Cylinder diagram for 2015 ford Edge Titanium 2.0
enigma-2 replied to Scottnotcarguy's topic in 2015 Edge & MKX
Not certain about this, but isn't it on the sticker on the underside of the hood? -
Engine wants to stall - Code P1450 & P144A/C - Evap Purge Valve
enigma-2 replied to shumax's topic in 2017-2018 Edge & MKX
Looking at your results, it seems that your fuel trims are a wee off. (Could be the way your car responds however.) Still, I'm kind of wondering if there isn't a small vacuum leak going on, on the evap purge line. (?) -
Glad you found the fix. Personally I wouldn't have used aftermarket, but maybe its good enough. What brand did you go with? Always good to know if aftermarket works (and holds up.) -
NHTSA Recall ID Number : 25T001 Synopsis : Pirelli Tire, LLC (Pirelli) is recalling certain P7 Cinturato tires, size 245/45R18 100 Y. The tires were incorrectly marked with the wrong maximum inflation pressure and may not meet the strength requirements for the stated pressure. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 139, "New Pneumatic Radial Tires for Light Vehicles." Tires with insufficient strength may fail, increasing the risk of a crash. Dealers will replace the tires, free of charge. Owner notification letters are expected to be mailed March 17, 2025. Owners may contact Pirelli customer service at 1-800-622-2390.
Anyone replace their DriveShaft on their Edge?
enigma-2 replied to Spprtmechanic's topic in 2010 Edge & MKX
That part number fit 2007-2014 Ford Edge and aftermarket costs under $300 online. OEM dealer price is $962.91 plus say $50-70 shipping. ( https://parts.lakelandford.com/p/Ford__Edge/Drive-Shaft/51620461/DT4Z4R602A.html ) So they are quoting approx $1700 labor. At $100/hr, their saying its going to take them 16-17 hours to replace. Uh, no. -
A little late, but just in case you didn't find an answer elsewhere. There is an AWD indicator on the instrument cluster; its icon is a wrench, and indicates that there's a problem with the power train or AWD system. Its a fault indicator, & it only illuminates when there's a problem (such as the AWD has been overworked, is overheated and is off until it cools.)
1. I purchased extended warranties until I reached 125,000 miles. So their not being honest. One of the requirements is the car must be inspected and everything they find must be repaired. (Start with an even slate.) 2. You don't have to buy the warranty at your dealer. ANY dealer can sell you the Ford warranty and ALL Ford dealership will honor. I went to Levittown Ford (online) got my quote, then made an appointment with my dealers financial manager. We went through his sales pitch, I chose the best, he gave me his price, I showed him the quote that I printed out and said "here's a quote from another Lincoln dealer, will you match." He read the printout and instantly said yes. Then I said "what else can you do?" He asked what I meant and I told him I wanted a $0 deductible. He ran some numbers and said he'd give me this if I had all my service done at their dealership. We had a deal. Spark plugs can stick, but a professional mechanic should know how to remove. Friend i used to have was a mechanic and I remember he used to use an impact wrench on stubborn plugs. (Hell, I've seen him get out broken off exhaust manifold studs that were welded to the block.) Mention that if they can service your car, perhaps you should try another Ford dealer. ... That should do it.
'18 Edge Titanium P0744, P0741, P1016
enigma-2 replied to EdgeGirl21's topic in 2017-2018 Edge & MKX
What were the transmission codes? (Do you hot rod the car, or tow heavy boat?) -
Vehicle battery getting weak can cause this. Have the battery's CCAs rating tested (not just a voltage test.)
There may be a couple of other checks that come to mind. Gas cap gasket or cap not clicked on. Wiring to the purge valve. Corrosion in the connector, Micky chewing on wires .. -
Radio no audio any source
enigma-2 replied to Gotdalotta's topic in Audio, Backup, Navigation & SYNC
1. Can you run radio Diagnostics? • Simultaneously press and hold the on/off button and the seek down button until the bezel diagnostics mode is entered. The Speaker Walk-Around Test begins and the display indicates each speaker as it is tested. Once the Speaker Walk-Around Test is complete, the following menus are available: ▪︎APIM Diagnostics ▪︎AHU Diagnostics (refers to the ACM) ▪︎ICP Diagnostics (refers to the radio control panel) ▪︎ECG Diagnostics (refers to the GWM) ▪︎Testing Settings menu ▪︎SiriusXM Diagnostics menu 2. Tried a master reset? • Press and hold the Seek up and the audio unit Power buttons simultaneously until the screen goes black. Wait for the system reset to complete.
