As @1004ron stated, the real harm is in the bearings. One area that's more sensitive is the lobe rise on the camshafts. Changes the timing. If the engine seems to be running OK, I'd stop driving it now and get the water pump fixed. (You'll also change out the timing chain and guides.) Also change the plugs while the engine is torn down. Its entirely possible that the plump failure is only a recent event. Coolant can drain into the pan quite quickly when the seal fails.
Any of the following is listed as fitting your 22 st. 245/60R18 245/55R19 245/60R18 245/50R20 245/40R21 My temporary spare is 17" and was OEM. Fits ok. (But at 55 psi it rides rough and noisy as hell.)
However, the mechanic is supposed to do this as part of the rotation service. I get The Works for my oil changes, and tire rotation is part of the service. Never had a TPMS light afterwards. (Its a simple procedure, takes only a minute or two. What else is your mechanic overlooking?)
2020 Ford Edge Titanium tire replacement
enigma-2 replied to Ellen Marchese's topic in Wheels & Tires
One thing to check is tire pressure. Believe your tires should be set at 35 psi. If higher, they'll cause the car to wander in and out of the lane base on the crown of the road. (Some mechanics mistakenly believe higher is better.) -
Honestly I would doubt it. You getting any codes when this happens?
- 8 replies
- hard start
- ford edge
(and 2 more)
You can buy a Chinese aftermarket (comes from China) on Ebay for $80. (Or OEM for $200.) In the meantime, stop at your local auto parts are us and buy some translucent RED tape to cover the clear LEDs. Its made for this use, to cover broken plastic break lens. (Is @akirby still in the forum? 🙂 Usually accepted by the cops as an accepted method of temporary repair. (The third brake light is a DOT requirement in all states and you can get stopped for displaying white instead of red.) Call your local Ford service and get a quote as to how much it will cost for replacement and labor. Then call your insurance agent and see if you can claim on your comprehensive policy (may have to pay the deductible, mine is $100, but I'll bet the cost would be upwards of five or six hundred. Two, two-fifty for the lens plus two fifty or three for labor — I'm being generous, of course its going to be more, what with sales tax and all that.)
My 2009 MKX has done this three times to me. Year or two between events. Always started on second try so I ignored it. My guess at the time was it was related to the immobilizer circuit had gotten the wrong signal or a spike had occurred during the start sequence. If it happens again and doesn't start on the second try, try disabling (or resetting) the immobilizer by putting the key in, turn to on, then off and wait a few seconds. (With keyless not certain, perhaps push "srmtart" button (goes to accrssory), then off and wait a few seconds for the immobilizer to reset.) I tend to believe that the immobilizer is what's involved, inasmuch as the car reacts exactly like the wrong key (or fob) is in the car.
- 8 replies
- hard start
- ford edge
(and 2 more)
Rear lift gate intermittently closing by itself after being opened
enigma-2 replied to mjm917's topic in Exterior & Body
I remember reading about a simular situation some years ago, where the guy finally identified that moisture was getting into the switch on the liftgate and triggering it when its position changed from vertical to horizontal when open. Think he said he found this by putting some tape (think he said tape) over the outside of the switch to seal it off from the exterior. (Don't believe he has driving a Ford however. Think it was a Japanese import.)- 1 reply
As the title states, this is the method used by one person to clean his intake & exhaust valves, in his direct injection engine. Gives the name of chemicals, tools and methods used. Claims it takes him 6 hours and does this at 120k km intervals. Shows pictures of before and after. (Super impressive results.) Discusses use of catch cans and why he doesn't use them. He talks about the use of catch cans & that they do work, but feels they're only 50% (maybe more) effective. I'd guess 59% — 75% which extremely helpful, but still not perfect. Some stuff gets through and accumulates on the valve. Love to see a picture of valves with catch can after 50k miles. Just to see how effective the catch cans really are. Anyway, I found this extremely interesting and thought I'd share.
- 1 reply
- 2
You're very fortunate. Every car I've ever owned used some oil between changes. Years ago my Ford service department told me it wasn't unusual to lose up to a quart between changes (said it was the reason the owners manual tells you you to check your oil between changes.) I remember when I was a kid, we used to check o level at every gas fill up. My 3.5 aspirated uses some, half qt to 3/4 between changes. I'd expect a pressured engine to use at least that much.
- 20 replies
- oil
- consumption
(and 2 more)
Have you done the water pump & timing chain yet?
The requirements in FMVSS No. 108 are: Passenger cars must have four reflectors: two red on the rear and two amber. Reflectors on the rear must be as far apart as possible and on either side of the vertical centerline. Reflectors must be visible from 500 to 50 feet away when directly in front of headlamps. Reflectors on the sides must reflect light to the sides. Reflectors on the rear must reflect red light to the rear.
Audio would not turn off (fixed)
enigma-2 replied to enigma-2's topic in Audio, Backup, Navigation & SYNC
Well, it did it again. Tried to engine off/open door trick and it stayed on. Hit the media button and the radio rebooted and ran fine. Last night was making a Taco Bell run and map froze and radio dead. Nothing worked. Ignored it and it rebooted on its own. Beginning to think the APIM is going out. Crap..! -
You check the tranny fluid level?
Oh, they know exactly what's in their warranty. Their smart enough to exempt certain items that are known to fail and cost big bucks to fix. If it's covered in the warranty they have to cover it. But read the fine print carefully. (One reason I always went with the Lincoln Extended Warranty. No arguments.) Reason the water pump is internal on the Edge is it shortens the overall length of the engine (being transverse). In the F150 its on-line and the water pump is external.
Might be a good idea to have a mechanic pull one of the easy to get to plugs on the front of the engine as see what they look like. Its important to change the plugs on or before. Accessory belts can be examined easily, I've got 140 miles and still good. Don't think its necessary to change preempt. More important in hot climate to change the transmission fluid on regular basis. PTU annually as well (if you have AWD.)
@JPJMustang most likely the water pump seals failed. My dealer quoted $1600-$1700 couple of years ago. They drop the subframe to service. (Good time to also have the plugs serviced as well.) Q. How many miles do you have on yours? (Thinking about having mine replaced as preventive maintenance around 170k.)
Just seen your post. Does you extended warranty cover a loaner or rental?
Some of the folks here would disagree with you. Most of the high oil consumption problems I've read about were in the 150. Slightly different version but many similarities.
- 20 replies
- oil
- consumption
(and 2 more)
I've formed my viewpoint based on hundreds of posts I've read on the Ford F150 forums. In all reality, the only entity with all the facts is likely Ford, who has all the statistical data from all the dealership repairs, and that is likely confidential. I Don't believe that Ford issued an TSB for the 2.7 in the Edge, but they have for the 150 for high oil consumption. (TSB 18-2237) Probably unrelated, there is a recall for the 2021–2022 Edge and Nautilus (and every other model with the 2.7) due to a potential engine failure risk. The issue stems from faulty intake valves. Reading on Bob's the oil guy where one user reported his dipstick was popped up from excessive pressure in the crankcase. #4
- 20 replies
- oil
- consumption
(and 2 more)
Tip from famous YouTube tow truck owner:
Should be able to find chains to fit your edge here: https://www.etrailer.com/fitguidechains.htm?gad_source=1&gclid=Cj0KCQiA_Yq-BhC9ARIsAA6fbAjtbZ734WY3F3K-xqOOkWZnPHfawr5wocJ_V_da8a-mYUa-q46m3ikaAhbKEALw_wcB
- 1 reply
I'm running 245/50 R20 wheels with a factory 165/80 D17 spare. The spare is labeled “THIS TIRE AND WHEEL FOR TEMPORARY USE ONLY.” there are several conditions listed when using, such as max speed of 70 mph, don't take the car through a commercial car wash and don't use snow chains. My owners manual doesn't differentiate between the 17" & 18" spare, and I have driven using the 17" spare with my 20" wheels w/o problems. (I have AWD.)
The 2.7 EcoBoost engine is known for having several problems due to the engine design and direct injection. One of the most common problems is high oil consumption. (A common failure is due to oil plan leaks due to the plastic oil pan and gasket design.) But there are other, internal causes. This website talks about these and other problems, symptoms and fixes on the 2.7 EcoBoost engines. https://lemonlawexperts.com/ford-2-7-ecoboost-problems/#Problem_4_Head_Gasket_Failures
- 20 replies
- 2
- oil
- consumption
(and 2 more)
