Semper Fi to all who served. Freedom is not negotiable. OO-RAH.
headlamp problem
enigma-2 replied to Dale's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Mine has a dark (or dimmed) area as well, probably a function of the shape of the projectors and unevenness of the light source. I suspect that if we could get a uniform light source (filaments and LEDS have uneven illumination points) this dark area would vanish. -
Noise start before or after the repair?
Looking through TireRack's ratings for the Bridgestone's All Season Dueler's, they are rated at 7.2 on ice. Their winter tire is rated at 9.1. Huge difference. (Note that the winter tires are noisier do to their design.)If you expect to do a lot of driving on snow and ice, they may well be worth the investment. Currently TireRack has the Bridgestone's on sale at $150 tire (would need to add cost of rims, pressure sensors, mounting and balancing, so you would still be looking at over a grand), plus storage and r&r each spring/fall. Are they safer, yes, no question? Are they worth the added cost and trouble, only you can decide.
My 09 MKX brakes squeek when backing slowly out of the garage in morning if the car has sat overnight. It's normal, the brakes wear on the leading edge, traveling in the forward direction 99.9999% of the time. This allows crud, dust, etc) to build up on the trailing edge. When backing up the crud is the cause of the sound. If yor getting it going forward after backing, my guess is, the dust, rust, etc. has moved to the front leading edge when backing and will stop as soon as it's burned off. Easy way to eliminate it is to do an aggressive stop while backing up, essentially burning it off. Should be good for a few days until it builds up again. Just for fun, when my wife is with me (going to the store or whatever), I'll back out of the garage reallllly slow and squeek all the way down the driveway. Drives her nut, like fingernails on a blackboard. Heh, heh, heh.
Does the sound vary with speed? FWD or AWD? Does the click or pop occur for only a few seconds (just when acceleration starts) or does it continue for a period of time? Is it poss that this is a body panel making a clicking sound as the center of gravity changes, or more related to drive train?
Running Bridgestone's Dueler's, about 50% worn. Never forget your Edge is a heavy vehicle and will take much longer to stop. My 09 MKX did only fair last winter, the anti-lock breaks were a Godsend. On packed snow or ice, I drove very slow, much more carefully than when I drove my wife's car. On snow, I had no real problems, probably do to having a AWD. Can't beat snow tires, (rubber stays flexible in cold bettet, more aggressive tread, etc.), the roads are cleared in a few hours, so most of the time I'm driving on a cleared road surface (or nearly clear), so I really didn't feel I needed snow tires.
Had the same problem, small areas of road rash. I masked off the area and sprayed the scrape with spray chrome. (Forget the brand, bought at lowes). Not a perfect fix, but helped a little.
Wow, 5,000 miles a month. You do some serious driving!
Had a slight rattle couple of weeks ago, traced it to a rear seat belt just barely touching the plastic panel.
Yea, I test drove my wife as well. LOL
Was interested in reading more about the DM-V2 tires, approx outer 50% of the tire is a softer, quieter, more "rubbery" type of rubber (quieter and better traction). When this wears off, the tire will get noisy and not have as good traction. That's when I trade, hate noisy tires. Ergo, you only are getting approx. 55% of its rated tread, which could be as little as say, 25% of its rated milage (picked a number out of thin air, exactly how many miles are in first 55% of tread depth? Remember that the outer 55% is a softer rubber that will wear faster.) Probably would still be usable tires, just ride harder and a lot more noisy. I've suspected other tires of doing this. Had a set of Michelin's that got real noisy and hard riding when 50% worn. Dealer told me the soft wear layer had worn off. The DM-V2 must be the V1 replacment, hence the reason why the V1's are marked down $40 less.
FWIW, link takes me to TireBuyer.Com website.
For snow only, I would go with Bridgestone's Blizzak DM-V1. For all season, Bridgestone's Dueler H/L 422 Ecopiate (what I'm currently running). http://m.tirerack.com/tires/TireResultsServlet?tireIndex=1&autoMake=Ford&autoYear=2010&autoModel=Edge+Limited&autoModClar=FWD&width=245%2F&ratio=50&diameter=20&sortCode=59938&skipOver=true&minSpeedRating=S&minLoadRating=S&tab=ALL&zipCode=null#0
Ford Extended Service Plan (ESP) Canada
enigma-2 replied to hassan.syed's topic in Buying, Leasing & Ordering
Simple fix, get the Flood quote (in writing) & demand local dealer match. They will 100% of the time. I sometimes negotiate service work (certain jobs, not common work). Local service manager agreed four times so far. Everything's negotiable. -
More likely, the supplier is owned by GM. :~}
- 8 replies
- Front Diff
- Trans-axle
Hey Mac, ever finish the comparison video? Curious.
- 25 replies
- 2008 ford edge
- Tail lights
(and 3 more)
Been talked about at length here in these forums. Basically the Ford unit is too low and allows the BAMR to contact the rails. Here's a quick link to start http://www.fordedgeforum.com/topic/14435-installed-factorythule-roof-rack-on-a-vista-bamr/?do=findComment&comment=136254
Tail light Condensation
enigma-2 replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Be interested in seeing what someone with this problem pull a light and give it a careful examination. Defective bond between outer and inner shell, weak bulb gasket, crack, etc. -
Note what I wrote about some connectors being wired differently causing the fans to run continously, even when off. Need to reverse wires.
Breadcrumbs on v3.8 doesn't clear out
enigma-2 replied to drpepper's topic in Audio, Backup, Navigation & SYNC
I used bread crumbs this summer when I was running around garage sales in a confusing subdivision. Helped alot, I could easily see which streets I had already been down and which ones I hadn't. Don't know how breadcrumbs works on other versions of navigation, but on mine they stay on until I turn them off. Have you tried turning off the breadcrumb feature (should clear the screen)? NAV》Map Prefs》and tap off breadcrumbs. -
Limit finger prints on screen
enigma-2 replied to Tophat4321's topic in Audio, Backup, Navigation & SYNC
Nice one! -
Ah poop, used the premium price by mistake. Doing this on my phone. Thanks for catching this, makes a big difference. The V6 is less expensive to operate. Big difference.
