enigma-2
    303
  1. What did you order vs. what did they actually send? Although you felt the substitution was not what you wanted, would you consider the substitution to be of equal value?
  2. Should be part of the home screen. Try calling Sync support team at 888-270-1055 weekdays.
  3. Standard on Titanium and Sport. On home screen, "settings" key on your home screen, touch "vehicle" and "ambient lighting".
  4. Local car wash, every week, ultimate is $18, takes 5 minutes looks great, and has all the good stuff, tire shine, wax, Rain X, drive away dry and shiny. Screw the hours of washing, buffing. Good enough.
  5. If it's listed on your window sticker, I'd be calling my sakes agent on Monday morning and asking where is it. Worst comes to worst, you can add it yourself. Vern talked about here in the firum, and the following posted pix on exactly how he did his http://www.fordedgeforum.com/topic/6122-diy-for-installing-homelink-in-se-sel-and-sport-edges/ I've done several, not hard at all. (You might get lucky and find one on Ebay from a wrecked car, at a much lower price).
  6. Goto https://owner.ford.com/tools/account/sign-in.html Create an account, put in your VIN and it will tell you which version of Sync your car has, and if any additional updates are available.
  7. Looks like an extra dot got added when I cut and pasted on my Android. The correct url is: https://www.youtube.com/watch?app=desktop&persist_app=1&v=Ot_CgAjyCFQ And the title is "Fixing A Car That Clacks When You Turn" by Scotty Kilmer. He makes it look easy.
  8. Could always pop on chrome covers. Look good and might be less expensive.
  9. Does it sound like this? (Scotty shows in this Youtube video just how easy they are to change). https://youtu.be/Ot_CgAjyCFQu
  10. 2009 MKX, I'll assume that later years are nearly the same. Measurements include all projections and assume a box-shaped structure, slid imto place. Width: 45", height:29", depth: 5ft. (In mine, the back seats do not fold completely flat). These are rough and a slightly larger box will fit.
  11. Did you by chance read this thread? http://www.fordedgeforum.com/topic/12517-ford-edge-center-console-plastic-piece-cover/ There are also cover kits available: http://www.carid.com/2014-ford-edge-dash-kits/
  12. Yea, stopping on ice in a MKX can be a real exciting moment. Couple of winter's ago, I thought I'd need a defibrillator to get me going afterwards. lol
  13. On my 09, I press anywhere on the map display, and get 5 soft buttons. Then press on "POI Icons on/off" to turn on the 3 POI buttons I have selected. (Gas stations is one of the three I usually have selected).
  14. enigma-2
    Ford Edge 2012
    Try one of these: http://m.yp.com/philadelphia-pa/non-ethanol-gas-stations
  15. Sounds like it's part od the chassis/suspension system. At a stop, the car stops with the nose dipping. Starting up, the nose lifts and the suspension shifts. I would begin by looking at the torsion bars, front struts, etc. Try bouncing the front end (while parked) to see if you can recreate the squeek. Could be as simple as a bushing getting hard and needing a little lubrication.
  16. enigma-2
    Ford Edge 2012
    So do i. Here's a website that list all of the Ethanol free gas stations by state. http://www.pure-gas.org/
  17. I would agree with akirby, it probably doesn't exist on to 2014. If so, about the only thing I could think of, is to put on shocks with a shorter length, -or- possibly some sort of restraint, strap, chain or whatever, cinnected between the top strut connection and the bottom connection points.
  18. Most likely it's from a clogged evaporation core drain. This allows mildew and mold to grow and produce a foul selling odor to be present in the air stream. Easiest way to fix is to buy some Lubegard and squirting it up into the hearer/AC drain. It will foam and fill all the nooks and crannies of the cores, kill all the nasty stuff and then turn to a liquid and drain out. http://www.amazon.com/Lubegard-96030-Evaporator-Heater-Cleaner/dp/B0007PHD0S Here's a YouTube video on how to do it: https://m.youtube.com/watch?v=Bi22mdXj3wM
  19. enigma-2
    New
    2010 with 38k? Man, talk about babied. Nice find. I have the Platinum White Tri-coat as well. Love it, really stands out in the sunlight.
  20. WWWPerfA_ZN0W already suggested this same bracket (or one just like it) in an earlier response. Interesting but very expensive, subject to road damage, still requires drilling holes and running a 12 volt circuit under the car. Thread starter wanted to mount the plate without drilling. If it were me, I would just drill the holes. More reliable and the plate would be needed by the next owner anyway.
  21. Probably more likely a dry joint where the shaft comes through the cowling (hinge barely moves when in use). You might try using penetrating oil on the shaft.
  22. Make certain your phone does not have your caller ID blocked and that this phone is the one registered with your account.
