Think @lildisco may have hit the point. @Perblue, are you driving short trips in your daily drive? -
Ever check your charging voltage? I'd begin to suspect a loose or corroded connection somewhere in the charging system. (Grounds have been notorious for low charge rates). -
2016 Edge Sport - Shocks or Coilovers?
enigma-2 replied to Arbee's topic in Accessories & Modifications
I was told that the rears are not covered under PremiumCARE. (Fronts are however). Rear shocks are designed to wear out and that isn't covered. Think I spent somewhere around $150-$200 at dealer. -
I'd be concerned about how much software programming changes you'd have to do to the TCM when introducing a different transmission. Where would you even get the necessary information?
Brake Pedal continues to go to the floor
enigma-2 replied to Blingamaring88's topic in Brakes, Chassis & Suspension
Basically there's four things that can cause the brake pedal to go to the floor. 1. Air in the Brake Lines 2. Brake Fluid Leaking 3. Brake Booster Is Failing or Is Bad, and Master Cylinder Is Going Bad As you have addressed all of these (I assume you would have noticed a leak), I'd center in on bleeding the abs module. https://rxmechanic.com/how-to-bleed-abs-module-without-scan-tool/ -
I've seen where people used a lay-flat 2x4's with longer bolts. Raised it 1-1/2". Or kits designed specifically to raise a seat 0.25" to 1.5" https://a.co/d/6zznPYl If you need 2-3", this may work. https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=750/mode=prod/prd750.htm?gclid=Cj0KCQjwy5maBhDdARIsAMxrkw26vP9Pjh7JVbf0PRbm7QgQDfKZ8wD1k5YgwT5nh8myEPIJcIGYG1kaAltREALw_wcB Also, to get 4", you could consider an adult booster seat. (Drop it in and .... done). https://a.co/d/jc8KHV4 If the seat belt is tight with a raised seat, you can get 6" seat belt extention from your Ford dealer. Free, just have to ask. (Made for larger sized people who have trouble with fitting into a standard seat belt). Make certain you ask (at parts counter) for a front seat adaptor as there's a difference between the front belt connectors and the rear seats.
2012 Ford Edge AC Issue
enigma-2 replied to FSUFishin's topic in Interior, A.C., Heat, Interior Trim
If your certain that pressures are good and the clutch is not engaging you need to check the electrical part of the system. Start by removing the plug at the compressor and testing the voltage between the leads with the engine running. Expect 0-volts with the A/C off and ~14-Volts with the A/C on. If you see voltage, the clutch is getting signal to turn on and its failure to do so makes it suspect. (Try some impact engineering to see if it's sticking.) If you don't see voltage and your certain the fuses are good, suspect the low or high pressure switches. (These are designed to keep the compressor from running if the pressures are out of tolerance). Take a paper clip or jumper and jump the leads of each switch separately. If a switch is bad, jumping across it should allow the compressor to start. BTW, are you getting any codes? Something like P1461/P1469? Edit: another method is to run a jumped directly from the battery to the clutch terminals. If it engages, fuses, relays and high/ low pressure switches are next in line. If their good, the A/C switch in the cabin. -
The tranny is custom to the engine and model. Doubt you would find any aftermarket unit that would work. What's wrong with yours? Used would run $1,500+labor, rebuilt probably $2,500+labor, new probably $5-6,000. Tranny isn't all that bad in my opinion, slow down shifts but reliable (if fluid is changed on a regular basis; 30k).
Only automatic settings to turn on heated seats in a Ford is on remote start (although Chrysler does have an automatic setting). If it's always turning on, on one particular setting (such as high), then id suspect that the switch is malfunctioning (heated seats or conditioned seats) or module (conditioned seats). If she has conditioned seats, check for codes.
You used grease rated at 4,500Ā°. Was that Fahrenheit or Celsius? Ahhhh, its synthetic. Whap, (slapping forehead) of couse. lol
Wheel bearings can cause grinding. Wife's Sebring Convertible had a bearing that grew louder over time. Dull, grinding. Local Chrysler dealer replaced with aftermarket and it only lasted two years before needing replacement. When I took it back for replacment, I insisted on Mopar bearing. They argued with me. Finally told them if they wouldn't use Mopar I'll go somewhere else. So they agreed. But I made them put on work order that I was to be allowed to see the replacement bearing before assembly. Again they argued. And again I made them agree (or lose the job). (NAPA parts have a better markup and profit). So far the Mopar bearing has lasted 5 years without problems. If you replace the wheel bearing, use Motorcraft.
2011 Ford Edge Sync Replacement
enigma-2 replied to magnum3672's topic in Audio, Backup, Navigation & SYNC
Here's another option BestRefitCar 2021 SYNC 3 Upgrade Kit, Fits for 2011 Ford Edge, SYNC 2 to SYNC3.4 MyFord Touch (MFT) Support Carplay,Including 8 Inch Screen, APIM Module, na3.4119, For Ford https://a.co/d/9en8sEM -
Did you check the lube on the pins? Lack of lube can cause the caliper to seize and contact the rotor. When you did the new pads, did you use Motorcraft or another quality pad, or the cheap stuff? Cheap pads can have metal fillers that show up with age. (And cause grinding even though there's sufficient thickness).
Keep smiling. OPEC announced they're dropping production by 2 million barrels a day (to force prices up). ? -
Verify this kits fits your car by emailing your VIN with the vendor. https://www.ebay.com/itm/204058627282?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=DzWCZ5ZUSGi&sssrc=2349624&ssuid=Snv36mbbRk2&var=&widget_ver=artemis&media=COPY If you can't find online, there's always your local Ford dealer's part department.
2016 Edge - A/C water Drain location?
enigma-2 replied to omar302's topic in Interior, A.C., Heat, Interior Trim
Great pictures. I was surprised that they took the passenger door off. Also surprised that the drain drains directly below the car, over the PTU and exhaust (turns to steam). Scary to think that it will all get back together properly; but it will. These guys are pros. (Now if I were to do it, the steering wheel would in up in the back seat and I'd get the passenger on backwards). -
2022 Ford Edge ST Sub Bottoms out.
enigma-2 replied to Ichiemo's topic in Audio, Backup, Navigation & SYNC
Others in the Bronco forum, have also reported this same problem. Here's how they fixed it: https://www.bronco6g.com/forum/threads/subwoofer-rattle-i-think-i-gotter-licked.27038/ https://www.bronco6g.com/forum/threads/terrible-rattling-in-panel-above-rear-subwoofer.33653/ -
Not quite yet. The order banks for the 2023 Edge, opened up in July. Think akirby posted the Job One date. Starting with the 2024 model year, you'll have to buy one labeled "made in China". -
With those sidewalls, they'd look like I was driving around with a bias-plys. Add a 4" white wall and ...... My spare is 17", but 2" shorter than the Scorpion's. Now, THAT looks small in the wheel well. LOL.
I seen where #akirby posted back in August in the mkx forum, that Job 1 was 10/24/22. https://lincolnmkxforum.com/topic/3748-2023-order-guide-and-timetable/
In comparing the 18" tires that came on my mix from the factory to the 20" on there now, even a small difference in diameter makes it look different. Not much, but I prefer the larger size for looks. (Doesn't ride as well however). Back to the op's question, yes, the 2008 Edge SE came with 235-65/17" tires; so they will fit. The pressure sensors are strap type (at least they are on my 09, assume yours are the same). And, due to the age, and these sensors have an battery life span estimated at 10 years, plan on buying new sensors as well. (I had problems with aftermarket strap braking, went with Motorcraft instead. Dealer told me they have a return problem with NAPA and other aftermarket sensors. But expect to pay a lot more for Motorcraft).
