Cant get ball joint into spindle 2008 ford edge
enigma-2 replied to darinf01's topic in Brakes, Chassis & Suspension
@darinf01 you get it to fit yet? -
Not certain as to how to adjust, I would imagine that there should have an adjustment somewhere. Fogs are aimed differently than the main driving lights. Fogs purpose is to illuminate just the edge of the road. Theory is, in heavy for, snow or rain, you're going to be driving slow. 10 mph slow. The main purpose is to show you where the edge of the road is, not to illuminate to road in front (which you can see anyway.) Because of this, I can see why one light may be aimed lower than the other. Best way to tell is to flip them one and judge if they're lighting the road edge adequately.
Personally I'd go to the dealership. Costs more, but they do the job right and guarantee the results. Plus, get a Carlite windshield and not an aftermarket.
Or our VA benefits.....!
As an alternative, and the seals aren't too bad, could always try 303 seal rejuvenater on them. https://www.overtons.com/303-rubber-seal-protectant-3.4-oz.-320858.html?utm_source=google&utm_medium=cpc&utm_campaign={Campaign}&cq_cmp=22321557994&cq_con=181735643968&cq_term=&cq_plac=&cq_net=g&cq_plt=gp&gclsrc=aw.ds&gad_source=1&gclid=Cj0KCQjwtJ6_BhDWARIsAGanmKfYMpnjrb-AMJwEfuC3HIv6fCTyw5FnBzjvnfwY35Sw4_qyW0f4fa4aAoIbEALw_wcB
Link to working diagram, part numbers, prices and where to buy parts. https://parts.levittownfordparts.com/v-2009-lincoln-mkx--base--3-5l-v6-gas/body--sunroof
My guess is you're talking about #16 (upper seal, 7T4Z-7851707-A, $127.86) #17 (front seal, 7T4Z-7851884-A, $228.63) & #18 (rear seal, 7T4Z-7850036-A, $244.66). As for method of repair, you are going to need to buy a body manual to do the job properly. You can buy a set of bofmdy manuals on Ebay for $30. Item number 394401556064 (last one, don't dilly dally). https://www.ebay.com/itm/394401556064?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=2_naznvlqda&sssrc=4429486&ssuid=Snv36mbbRk2&var=&widget_ver=artemis&media=COPY
Are we about to see an additional 20% on OEM auto parts? Talk about inflation. I'm on Social Security and need this about as much as I need to grow a hemroid.
You could adapt something like this. https://a.co/d/8SdBWqO
I also believe that do to lack of use, the lock cylinder is probably gunned up. Second on spraying WP40 into the key slot. Now, some cars have a twist when using a mechanical key. Don't know if it affects yours, don't think Ford uses, but doesn't hurt to try. Put the key into the key slot, but don't turn it. Wait 5-10 seconds then try.
How does one disable AWD - convert to RWD only ?
enigma-2 replied to Brandon123's topic in Accessories & Modifications
The standard for the Edge/MKX is front wheel drive. To turn a FWD car into AWD car, they add a Power Takeoff Unit, a driveshaft from the PTU to the rear axle, an electronic coupler where the driveshaft joins the RDU and a RDU with active differential. There's no practical way to convert an AWD to RWD without modifying the transaxle. Possibly by changing out the transaxle and installing a transmission from a F150. Would also have to modify the driveshaft and RDU. You could disable the AWD function by popping a fuse or two and make the car FWD only. This will set a code and light in the instrument panel. As an alternative, you could remove the driveshaft. Question is, why would anyone want to? -
Active Noise Control (ANC) - Retrofit 2019 Titanium ?
enigma-2 replied to Iroga's topic in Audio, Backup, Navigation & SYNC
Not my browser. I'm using Google Chrome. Here's what I'm getting when I click on the link This page isn’t working www.2gfusions.net redirected you too many times. Try deleting your cookies. ERR_TOO_MANY_REDIRECTS -
Can't get the link to work for me. -
Fuel Pump failed at under 27K on 2.0 Eco Boost
enigma-2 replied to CaliGal's topic in Owner Impressions
Fuel pump failure in a 2020 would be considered extremely rare. As you bought it used, I wouldn't get my knickers in a bunch unless other parts start failing. Eco Boost is related to turbochargers. Nothing to do with a fuel pump failing. Fuel pump failures are more related to a load of bad gas with dirt in it, clogging the inlet filter and overheating the pump. That can happen to anyone (in fact happened to me years ago.) Traced to a small operator who pumped out a tank at one of his stations to fill another at another station he owned. He sucked up all the dirt at the bottom on the tank. Couldn't sue as he denied everything. Cost me over three hundred as I had to also replace all filters, carb rebuild. -
???? There's a mat in there?
Member's details not shown anymore?
enigma-2 replied to handfiler's topic in Forum Help & Site Suggestions
We're sorry, that number is no longer is service. If you feel that you've reached this message in error, please stick your head out of the closest window and yell at the top of you voice, "I'm sick of this •••• and I'm not going to take it anymore." There now, don't you feel better? I know I do. Your welcome. -
Sealed for life is a relative term in which "life" represents the length of the original warranty. 🙂
You ever fix this?
Heater goes cold two minutes after cranking
enigma-2 replied to randyktc3's topic in Interior, A.C., Heat, Interior Trim
Check your coolant level. If ok, I'd suspect the heater door is malfunctioning (blocking heated air.) -
911 assist error and dealer cannot fix it.
enigma-2 replied to rusty813's topic in Audio, Backup, Navigation & SYNC
Not a subscription nor an update. Been on Ford/Lincoln since Sync 1. I know if you don't have a cell phone linked to your car, you'll get a message that 911 is not available. -
True enough, but the OP clearly stated he wanted a printed manual. I personally favor a printed manual as well. Clarify: For my car. I actually have all my appliances and equipment on PDF. Great space saver (and I can't find half of the anyway.) Cell PDFs puts everything in one place. .
For whatever its worth, you could pick up a set off Ebay. Since 2015, they should be interchangeable.
@rafeeki posted here back in 2023 that they were discontinued for the 2024 Edge. (As well as a bunch of other stuff.)
New control arm installed - alignment needed?
enigma-2 replied to DrivingofftheEdge's topic in Brakes, Chassis & Suspension
Of course you do an alignment after changing any part in the suspension or steering components. The old alignment was based on worn components. Rotate your tires as well. .
