Former Marine Airwing, Avionics CH-46. Also flew as a door gunner in Nam. Whenever I travel I sometimes have to walk on the tarmac to reach the aircraft. The sounds and smells of avgas burning takes me right back to those days.
2015+ common area - a place to say anything (feel free to pin)
enigma-2 replied to 037's topic in 2015 Edge & MKX
Referencing the owners manual, page 126. Make certain your climate control is turned on (button H). Make certain the A/C button is off (button G). Set the temperature to lower than the outside temperature. (Down to 60° to keep the outside air continously flowing, otherwise the air will slow or stop when the cabin temp matches the outside temp). Or take it off automatic by manually setting the fan speed. -
I wish. My 09 has soft, squishy brakes. Ah .... NO! No, no, no. My 09 seals the cabin area tightly. That is NOT normal. Your car has a leak around the rear doors. I would start by checking the rubber weather seals. Try using a dollar bill, shut it in the car door and wiggle it around the door seal. It should not move easily. If it does, the seal has gaps and is letting in air and water.
Outside air inlet clogged?
enigma-2 replied to edgemaster's topic in Interior, A.C., Heat, Interior Trim
FWIW, I check my cabin filter to see if dirty (this was last year), and found piles and piles of shredded foam rubber laying on the filter. Have no idea as to where it came from (suspect the asst. service mgr. did it - guy didn't last and he always seemed to by hustling repairs not needed). Anyway, it IS possible that there is a blockage in this area -
Plug n play http://www.oemautopartsco.com/products/2011-2016-explorer-edge-myford-touch-sync-gps-navigation-upgrade
Ok. By chance, did you switch to recirculate to see if the air flow improved? If it doesn't I would suspect something in the core causing the blockage. (Or one of the doors not actuating properly.) Another way to isolate is to remove the cabin filter and leave the filter door open. If it improves, it's allowing air to bypass the engine intake and, yes, I would then suspect it. If not however, it's still being blocked lower in the system. -
You can color your existing bulbs by using several coats of Dupli-Color Metalcast Yellow. There's an excellent discussion on fog lamps at http://www.danielsternlighting.com/tech/lights/light_color/light_color.html
I would think that synthetic grease would last the longest. The service manual recommends silicone spray. I use a super silicone, a mix of silicone and Teflon (think that's what it is, haven't used it in a while).
- 31 replies
- 2010 Ford Edge
- Vista Roof
Angel eyes size?
enigma-2 replied to Grant Stevenson's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
http://www.carid.com/2014-ford-edge-headlights/- 6 replies
- angel eyes
- 2014 limited
(and 3 more)
You talk about your, like my friend talks about his; with TLC. (Smile). His doesn't have an automatic control however, he uses a thermometer and manually opens and closes the vents to regulate heat. Is that a feature on the newer grills?
I wired my radar detector to the mirror wiring with a commercial wiring harness. https://www.amazon.com/gp/product/B006074LT8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 They make them to fit different vehicles and years, to fit specific equipment. Is simple and easy, you just push the harness wires into specific locations the back of the mirrors wI ring connector, and use the two wire ties provided to anchor the harness to the mirror. (With microphone): (+) is pin #1, blue with orange stripe, (-) is pin #10. Wire color is black. Pos is on the accessory delay circuit, fuse #41. When looking a face of connector with release tab down, pin 1 is lower left, pin 10 is upper right. (Reverse of looking at back of connector). Without microphone: (+) is pin #1 (blue with orange stripe, (-) is pin #2 (without lighted sunvisors) or pin #3 (with lighted visors). Connector has 7 wires and is numbered 1-7 starting from left when viewed face on and release tab is on bottom. You can find the correct harness at their website: http://www.mirrortap.com/?gclid=Cj0KEQjwwpm3BRDuh5awn4qJpLwBEiQAATTAQef_byFHwAnKPSE7fz0phXDuO8319hy0IWvpk3PUhBIaAht48P8HAQ Ford Edge and Lincoln MKX use .080" taps for 2007-2009 and .050" for 2010+. If your mounting something other than one of the current detectors, you could either modify an existing harness with a dofferent connector or make your own (not hard, two wires & a connector). You could also contact Mirror Tap and see if they would be willing to make you a special harness (perhaps if you furnished the correct connector). Need to use a stiff wire or solder wires to a pin of the right diameter to be able to push into connector next to existing wires.
Sorry, thought I had posted this on the "lounge". As for the egg, they are great. (Rather expensive however). Always wondered how they compare to a Weber. Have a friend that has dinner parties, makes really delicious gormet pizza on his, using a pizza stone. There's something about charcoal that just tastes better. When he's done, he puts the still hot brickettes in his fire pit and we sit around drinking great Italian wine and solve world problems. Two thumbs up on the egg.
Well this is the Lounge and we can talk about anything off topic, so here goes. Next to my MKZ, my favorite thing is... food. Tonight's supper was chicken breast and stir fry. We marinade our breast's in Weber's Southern Whiskey marinade mix. Oh my that's good. Anyone else care to share a favorite food tip?
White 2016 loaded edge sport
enigma-2 replied to specialk4523's topic in 2015+ Edge & MKX Generation II
Beautiful ride. I have an 09 MKX with the white tri-color, never gets old. You're going to continue to love the car.Recommended you consider adding splash guards on the front. -
https://www.rightchannelradios.com/collections/car-suv-cb-radio/products/midland-75-822-cb-car-kit Something like this. Antenna : https://www.rightchannelradios.com/products/k40-cb-antenna-58-magnet-mount
Adds mystery. Have you thought about changing the Ford emblem from blue to black? -
