Anyone looked at rims that light up? http://www.carid.com/oracle-lighting/oracle-lighting-led-illuminated-wheel-rings-75090434.html
Led switchbacks
enigma-2 replied to Aron Tigchelaar's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Deleted -
Need help! Hood shakes over bumps/on highways -2015 Edge
enigma-2 replied to MARIAV75's topic in Brakes, Chassis & Suspension
No. It should not shake or jiggle or wiggle. My 09 MKX is rock solid. There are two adjustable screws with hard rubber caps used to adjust the hood to make the hood set on a solid foundation. They are located one on each side of the engine compartment. If adjusted up, will provide lift on each side if the hood. Thus will take all sloppiness out and make the hood sit solid when closed. Simple fix if they still are using this setup on the 2016's. -
Edge completely wrapped satin pearl white with new wheels
enigma-2 replied to drjoe's topic in Accessories & Modifications
Wonder what it would look like with a full chrome wrap? Now, "that" would really stand out!!! (Heh). -
Key FOB AND manual key won't work
enigma-2 replied to brahmabull's topic in Alarms, Keyless Entry, Locks & Remote Start
Did she try the 2nd key, fob, to see if they work? When you use the key, does it turn when unlocking (indicates a connecting rod may have become disconnected). If it doesn't turn, would indicate a broken lock. One other thought, have you ever tried this key before, are you certain that this is the correct key? That the fob didn't work and then did, could be a weak battery. Don't know of what it could be otherwise as it works now. Perhaps the battery is weak and she was too far away to talk to the car, but was closer on the last attempt. -
I was also told the same thing by local Ford dealer and Monteith Tire. Monteith did have the same brand and series and told me that I needed to put on the same size and tread if I needed to replace. Asked why about tread and had to do with the stability system or breaking (maybe both, they were talking (and talking) about what happens if the tread is different with AWD on ice. At the time it seemed to make sense. Do remember that it didn't matter if it was only FWD. However, owners manual only requires same tires on each axle - seems to allow different tread designs between front and back axles. From a personal preference, I would prefer same tires on all axles.
He didn't say anything about hearing warning chime, just it shut unexpectedly. If it were closing (button or otherwise), he would gave heard the warning chime and it would have close slow enough for him to get out if the way. With weak shocks, (and I agree, shouldn't be happening on a 2014), it "could" close without warning, too fast to get out of the way. Easiest way to isolate is to try to repeat it.
That sounds really high. I looked on Angie's and found the following for the best paint costs: "A platinum paint job includes light chip and scratch repair, priming and block sanding all areas, and a urethane sealer. It also comes with a five-year warranty." "Frost says his prices start at $299 for a basic job, and up to $3,000 for a premium show-car-quality finish, which includes a full wet sand and buff. He adds the base coat clearcoat offerings, which are part of the premium and platinum packages the company offers, start at about $1,200." -
I would not have rejected a good deal because of 1400 miles. Salesmen drive the vehicle (need to learn the car in order to sell it), possibly driven between dealerships (the use retirees to do this, cheaper than putting on a trailer). Not too much especially if they offering a good deal. (Shrug).
Great presentation, goes a long way to explain why some people are able to fix with WD40 (or whatever you care to use) and problem comes back. I've never had the problem on my MKX, but I did on an Sable I used to own. (WD40 fixed that one). But if I ever develop the switch hanging up, I'll try this. Thanks for posting!
Any California tuned cars out there?
enigma-2 replied to 3500cc's topic in Accessories & Modifications
Do you have to have your smog level tested on an annual basis (leading to modifying the tune changing and take the emissions settings out of the acceptable envelope)? -
You need to replace the lift cylinders. Mac has a video on how to do this (super easy).
Amazing, never seen a vinyl wrap before. What color was it before? -
In the cargo well. (Did I rad this wrong?)
Click on my link (above). 22", OEM, $600/wheel.
2013 and later MKX gets roadside service 24/7 for the lifetime of the car. 2007-2012 gets 6 years/70k miles. After that it's on a per pay use. Does anyone know how much the cost is to use the roadside service after the warranty runs out?
Did you burnish them after install?
http://www.findrim.com/FORD-EDGE-2011-22-FACTORY-OEM-WHEEL-RIM-3850-BT4Z1007E.htm
The two grand is the price for one. Did you check out trierack.com ? Nice selection at fair pricing.
One area nearly everyone forgets about is the spare. It's supposed to be changed when you put on a new set of tires (or every 6 years). (from the owners nanual) "You should replace your spare tire when you replace the road tires or after six years due to aging even if it has not been used."
Seats giving me a back problem
enigma-2 replied to Mike Tollin's topic in Interior, A.C., Heat, Interior Trim
True enough, but what's clear when reading other forums is that many people have serious problems with the modern seating. Some are forced to seek medical attention for their problems. While my MKX is ok, it's definitely not as comfortable as my Sable was. My wife hates the MKX seats, and truthfully, I find I end up sliding around on them whenever I make a turn. I would say that the seat comfort is the biggest complaint I have with my MKX. On a scale of 1-10, I wouldn't give more than a 3. Edit. I'm sorry fellows, I meant to type a 6, while I'm not completely crazy over the seats, I'm not dissatisfied. The leather is slippery and mostly flat. They're confortable enough, but no where as confortable as my Mercury Sable was. And I tend to slid around on them when making a turn. But I would still rate then 6 or even 7 for comfort. My Sable were probably 9, pushing 10 for comfort. And they were cloth which meant they were warmer in freezing temps and fairly cool when it was roasting out. -
What, you have no windows in your house? LOL
Mine doesnt. Two front windows open + bamr pop, and no close. Think the purpose was to vent car after sitting in sun for several hours. If so, global close would be unnecessary.
She's on your Facebook picture & she was in at least on of your videos (forget which one). I agree completely with your reasoning however. I was really paranoid while my daughter was growing up. Worried when she went off to collage, taught her some of the stuff I learned in boot camp. Turns out some punk jumped her in her freshman year in a dark area of Purdue. Like dad taught her, she kicked him in the jewels, palmed his nose and walked away. He didn't. Those who have never been a dad will never know the real meaning of what it means to sacrifice.
