OEM bracket https://www.amazon.com/Genuine-Ford-BT4Z-17A385-C-License-Bracket/dp/B006QLIU3Q Different one http://www.partsgeek.com/catalog/2015/ford/edge/body_mechanical_-ar-_trim/license_plate_bracket.html
Alternatives to Not Having that Aux Outlet???
enigma-2 replied to lilcharmer214's topic in Audio, Backup, Navigation & SYNC
You can use an aux port to USB adapter for around $5 off Amazon. Mixed reviews, but there are several available. https://www.amazon.com/gp/aw/d/B00I6H153K/ref=s9_simh_gw_d0_g147_i1?pf_rd_p=1c5f02ae-183e-4906-990b-5a293310a66c&pf_rd_s=blackjack-personal-1&pf_rd_t=Gateway&pf_rd_i=mobile&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=9QAX8HMRMWAZRNBEB5EB Check this out as well. https://www.amazon.com/gp/aw/d/B00IRVQ0F8?psc=1 -
Everyone makes mistakes.
I'm under the impression that if the plug gap gets too large it can cause excessive current to flow in the coils and that will weaken or damage them. (Was told this by an experienced Ford service mechanic.)
Are the Edge's and MKX's cross-castered vehicles? (Thinking they are from the above specs). If they are, that would explain why several were reporting their Edge's drifting to the right when properly aligned. I think Ford does cross-caster for safety (causing a car to drift right if the driver is unresponsive, the car goes to the edge of the road rather the into oncoming traffic.)
Custom wheels suggestions for 2016 Edge...
enigma-2 replied to 2FAST4U's topic in Accessories & Modifications
First, there are a lot of Chinese junk out there. Anyone who can supply drawings and pay for 10+ where's can sell them under any name thew choose. Forged and no certification. Check put what your thinking of, are they an established, well-known manufacturer? Are the wheels certified? What kind of warranty do they have and what is the return policy? Don't buy cheap, don't buy off-brand. You get what you pay for and the cheap wheels can (and will) fail while driving. Give wheels MORE suspect than tires, there is a lot to consider, and your life can depend on your decision. -
Hi Lex. Is this what your looking for (don't know how close the seller is to you, but he's in the Netherlands). The link uses the mobile version, you may have to convert to full site by replacing "m" with "www". http://m.ebay.nl/itm/Ford-Edge-2007-2011-18-inch-COMPATIBLE-Wheel-Rim-/161859414908?nav=SEARCH Another offer http://m.ebay.nl/itm/2007-2010-FORD-EDGE-wheel-rim-18-3674-SILVER-OEM-OE-7T431007CC-/321966147936?nav=SEARCH
Ford Edge 2016 SEL VS Titanium SDCARD and AUX
enigma-2 replied to t0lkman's topic in Audio, Backup, Navigation & SYNC
My guess is they are attempting to prevent people from buying used SD cards of Ebay and not pay retail. -
Was given a 2016 Lincoln MKX as a loaner last week and the nav unit was unable to track my position because the display had the error "no sd card inserted". Is the nav unit in the MKX different from the Edge? -
Power liftgate intermittently doesn't open 100%
enigma-2 replied to ypodolyan's topic in Exterior & Body
There's one for sale on ebay for $115. http://m.ebay.com/itm/2011-FORD-EDGE-LIMITED-REAR-LIFTGATE-BACK-HATCH-DOOR-PISTON-POWER-MOTOR-/142009782556?_trkparms=aid%253D222007%2526algo%253DSIC.MBE%2526ao%253D1%2526asc%253D20150519202348%2526meid%253D4de51e3939ca46ac9e6aae4a8d90a51b%2526pid%253D100408%2526rk%253D1%2526rkt%253D1%2526sd%253D121996716445&_trksid=p2056116.c100408.m2460 -
It took me awhile but with SeaFoam, you have to run it into the carb and let it sit. It works slowly and will eventually disolve the gum if at all posdible. (Snowblower took a week to clear). Echo blower never did clear, had to tear it apart and clean the jets manually. But if you can get the chemical to work and have the time to wait, it saves having to tear it down. When I do tear a small carb down, I use a small ultrasonic cleaner, works so much faster.
Sounds great. Does it involve gin and vermouth? Ha!
- 6 replies
- aem air filter
- filter minder
(and 2 more)
I was taught in auto class (long ago and far, far away) to hold the filter up to the sunlight and see if you can see the sun through it. If you can, knock the dirt out of it and replace in car. If not it's dirty and needs replacing. Don't know if the same logic holds for modern cars.
- 6 replies
- 2
- aem air filter
- filter minder
(and 2 more)
After I read akirby's post, I looked it up. Good fluid is clear or translucent. Rust colored means that it's absorbed water and should be flushed. Blackish color means brake problems and everything needs to be examined.
Not in North Carolina. ......
Actually I did on Monday. Had mine in for the gas tank recall. (They found that is was leaking, and changed it). Dealer brought up a new MKX for me to use as a loaner. (Told me it was a perk for being a Lincoln owner, otherwise I'd have gotten a Fusion. Ploy to get me to drive a new MKX of course. :-) Thought the sound system was excellent. Seemed to have speakers everywhere. Very clean even a loud setting. When I returned it, talked with the service associate and he said that the Revell system is really the high end speakers. Suff about waveguides and balancing, etc. Nothing about the radio or amp. Never thought to ask if it was surround sound, but I would imagine that it is.
Sorry for beating a (long) dead house, but I was wondering what (if any) THX system has? Surprisingly there doesn't seem to be any topics on this in either forum. I get the surround sound aspect, demo built in sounds great, but does anyone actually sell surround cd's? Anyone ever use their surround system capabilities? Like to buy a great sounding cd, perhaps something 'not' classic. It works with DVD movies really well, but nothing seems to be available for CD music.
This is what I use https://www.amazon.com/gp/aw/d/B00JNJPS4W/ref=ya_aw_od_pi?ie=UTF8&psc=1
Thanks, I'll bet it has never been done. I'll have them do a full flush when I have new pads put on. Any way of telling how much moisture the fluid has absorbed? There such a thing as brake fluid tester?
This is a follow up to my earlier post. As of today, the mats are no longer slippery. It will be interesting to see how long they stay new looking
Mac, what do you think is a good interval for a brake fluid change. I have somewhere around 93k, been kicking it around getting a brake job. (Hate my brakes). You recommend a fluid change when I have this done? (It's not listed in the maintenance manual).
Anyone have Conti CrossContact LX20 experience?
enigma-2 replied to wlepse's topic in Wheels & Tires
On Tirerack.Com. users have rated the Michelin Premier LTX's at 9.5 for wet traction. TireRack testing rated it at top for wet weather and winter traction. The LX20's only rated at 8.9 for wet traction. -
You're getting that good? lol. That's about what I get in my 09 MKX. Currently around 17, depends on how heavy my foot gets. Should see closer to 20 on the highway. Maybe 21 with softer tires like Hankook or Michelin. (Until the softer rubber layer wears off that is).
I know, that's why I said to file it as a comprehensive claim. Cost will be the deductible.
