Ive noticed mine being off by a few meters at times while driving, always seems to self-correct. Assumed this occured when it switching satellites and was recalculating. By being off by several km would indicate it was only locked on to 2 or 3 satellites. Could always stop and get into the test mode and check to see what satellites the system was actually locking on to.
I wear American Optical Pilot Aviator Sunglasses (non-polarized glass version). Was thinking, the instrument cover is a textured, matt finish, might make a difference if one were to use conditioner and turn it shinny. Not certain as to what my detailer uses, but it seems to last and not shinny.
I happened to remember this post while we were on a day trip this last Saturday and made a special point to look for glare. Have a 2009 MKZ and have to say, I have no glare no matter what angle the sun took to the car. Do see a weak reflection of the top of the instrument cluster, but it's not really objectionable. Don't know what difference there is between the Edge and MKX; or the 09 and the 08 or 07, but they seem to have gotten it right in the 09.
Noticed a strange map behavior this weekend. On my 09 mkx, I have three views that I can choose for the nap. One with "north up", one with "car up" and one that's "3D" (sort if). Anyway, wife notice that we were driving on the wrong road, map was showing we were on the next road over from the actual road. For the heck of it, I switched from the "car up" view to the "north up" and ... bingo ... fixed! Switched back to "car up" and we were magically transported back to the other road. Weird. Anyway, others have reported problems with the navigation display, if you are having this type of problem, try switching the view and see if it self-corrects.
Isn't that the 2020 Ford prototype where the body is made from transparent aluminum, stronger than helium and glows in the dark? Heard the engine is made out of plastic and powered by a fusion reactor. Wonder if Ford will able to get the door switches to work by then?
Sorry about reviving such an old thread. My pass rear turn signal bulb burnt out and I thought I replace both (as when one me goes, the other is also probably as worn.) Reason I'm posting is, both sockets looked like new, no evidence of burning or overheating. Bulb is 3057K. (09 MKX).
Yup, makes one wonder what the 2018 palladium trim will include.
You would think that the system would default to something similar to a "non-active" system when a fault occurs. Making the car un-drivable when a fault occurs is completely unacceptable as every electronic component WILL (eventually) fail. .
Can you disable it by pulling fuse 71?
Could also add in the additional cost of larger tires.
Access Passenger Compartment Fuse Panel
enigma-2 replied to msawdust's topic in Interior, A.C., Heat, Interior Trim
Perhaps their sold at your local Ford dealer? -
Escort live. Sync's to certain Escort radar detectors.
Reason I keep the screen in view is I run a program coupled to my radar detector. When radar is posted on the cloud, it shows the map on the screen where the radar was detected (red within the last 10 minutes, yellow 10-20 minutes, green 20-30 minutes). Also shows the frequency (helps determine type of radar) and distant in feet to radar source. Comes in handy at times.
I was reading in another forum where someone had a leak in his A-Piller. He popped off the covers and found that the drain for the sunroof was disconnected; allowing water to run down the piller into the floor well. He reattached it and all good again.
Try a reset. Don't think it will work but shouldn't hurt. Pull fuse 29 and wait 1/2 hour. If radio comes on when you reconnect, let is go for several minutes (can turn down the sound if too loud, but don't change channels, etc. until the reboot is complete). If this doesn't work try a full reset. Make sure the car is on, in Park Press the Phone Button to enter the PHONE MENU Scroll repeatedly until SYSTEM SETTINGS appears in the radio display Press OK to enter the SYSTEM SETTINGS MENU Scroll repeatedly until ADVANCED appears in the radio display. Press OK Scroll repeatedly until MASTER RESET appears in the radio display Press OK. SYNC will ask you to confirm the reset Press OK to confirm. The radio display will read ALL RESET SYNC will take you back to the ADVANCED SETTINGS MENU
Surmising: the reason the ACM works after the car has run is, it's switched over the the acc connection and continues to operate for the duration of the accessory delay. The problem seems to be getting power through the start/run feed (which is a separate feed). Unfortunately I don't have a 2012 service manual, mine only goes up to 2010. In the 2010, power comes through the Smart Junction Box, fuse #28, then through a GY-VT wire to the ACM (audio control modular or radio for short). So if this still holds for your 2012, ir fault lies either in the SJB (of fuse panel for short) as there's electronics in here which controls this circuit, the wire to the radio (not likely) or the radio itself. Troubleshooting ideas: using an inexpensive 2 volt tester, pull the radio and ampifiler fuses and test the fuse socket (with the switch in the on or run, position.) If the SJB *is* feeding power, it's probably the radio (ACM actually, but you must replace the entire radio to fix). If there is *no power* then it's the SJB fault and one possible fix would be to rewire to a different circuit that's powered only when the car is on (on in the run position). Involves cutting the wire near the SJB and using a 12 volt quick connector, linking to a different conductor (wire). BTW, on the 2010, there are three fuses to the ACM, #28, operate in run, #41 operate in acc & #39 which I have no ida as to what it does.
PS on my 09 mkx, I clip a pinch type onto the consol Fwd storage comp door (where the power outlet is located). Keeps my phone low and out of the way while still accessible.
Seen those but always worried that jiggling of the part that slide into the would damage mechanism. Also, when drive detectors a cd inserted, tries to load cd, what hapoens to mechanism when it can't? Too expensive to play around with imho.
Nice looking display. Sometimes it pays to pay more for better quality. ?
Tirerack.Com is showing the Michelin Premier LTX (bout $200/ea) as the highest rated. I'm running Bridgestone Dueler's, they gave them for around $150/ea. Good tires. Ford will match these prices and give you a $70 rebate with the Michelin's & $140 with the Bridgestone tires. (If you put the tires on your Ford card, if you don't have one, you can apply right at the service desk.) -
What are you wanting to hook up?
I've had t at happ n to me, but on y occasion lly. I had alw ys thought it was related to the micr phone picking up ext aordinary noise. ?
