wind noise/air leaking around rear door windows
enigma-2 replied to cottinr's topic in 2016 Edge & MKX
As for the moonroof, you could try a re-initialization procedure. It might be possible that it's closing just quite tight enough. Been discussed here many times, here's a link http://www.fordedgeforum.com/topic/7572-how-to-fix-ford-edge-sunroof-problem/ -
Let's see now, the 2118 MKX? I imaged on the psychic-net that the 18 was finally going to get the hover conversion and folding wheels to provide thrust. Adding the optional Mr. Fusion power generator and the base price will probably come in around 1.2 mil. Oh wait, your asking about the 2018 MKX, not the 2118. My bad. (Lincoln probably hasn't finalized the design yet.)
Shopping for mom - need Edge buying advice
enigma-2 replied to hitops's topic in Buying, Leasing & Ordering
Just as an afterthought, most Ford dealerships will price match any reliable competitor prices. Could get a price on tirerack.Com and then see what your local dealer will offer. And Ford is offered a rebate up to $140 on tires if you buy certain brands and put it on your Ford Credit card. Two advantages, one is the rebate and the second is no charge for credit if paid off in a year (OPM). Just have to make minimum payments. Worth considering. -
2016 Edge SEL dim headlights
enigma-2 replied to rickb145's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
HA! I've got an 09 MKX that will kick your a¤¤ and spit you out sideways. Took me 1/2 hour to remove the driver's side. Some jerk on the Lincoln design team decided that 1-1/2" was plenty of room to change that bulb. Can't even get your hand on the back of the socket; had to use a crow's foot socket to loosen the lock ring. -
Not to mention higher temperatures. Wonder if the H9 bulbs would burn the sockets or glass over the plastic lens sooner? -
Factory vs After Market Alignment Specs
enigma-2 replied to clongtsn's topic in All Wheel Drive (AWD)
I always get a 4-wheel alignment when I change tires. Just got new tires and the alignment showed caster was off. Tires were not wearing abnormally but it does track a little better now. -
I didn't realize that. Thought that it was standard on all Edge's & MKX's. That's one feature I would miss, never knew it was an option on these basic models. Just to clarify, you use the key fob to pop the latch and then lift the tailgate up to say half way and it continues all the way open by itself?
You didn't specify the year, here is a link for the 2009, change if your car is a different year. http://www.fordparts.com/Commerce/PartDetail.aspx?n=spXkL7B3GeJw71D9ISAevQ%3d%3d&id=400320874&m=2&search=true&year=2009&make=Lincoln&model=MKX What exactly did you mean by "fell behind the trip"?
- 32 replies
- interior cabin filter
- Replacement
- (and 5 more)
Do they even offer a non-powered liftgate?
2012 Edge Sport - SYNC Wonkiness
enigma-2 replied to Kissel's topic in Audio, Backup, Navigation & SYNC
I would suggest possibly the SD socket my have possible corrosion. Before taking to dealer, try unplugging and replugging in the SD card to see if this breaks the film on the connectors. (Doesn't cost antthing.) If it works, try using some dielectric grease on the SD card pins. -
Nice! What was the temperature?
Using a MirrorTap on my 09 MKX, Back to the sticky mount for the Escort. I posted addl information on which mirror pins wored for my 09-14. I don't know if they changed in the 15. http://www.fordedgeforum.com/topic/17043-wiring-cable-to-rear-view-mirror-in-2014-sport/
MFT Navigation - POI Importing
enigma-2 replied to Kleber Gomes's topic in Audio, Backup, Navigation & SYNC
No, the POI database is a proprietary, separate part of the navigation map updates (can be purchased separately.) You could run a separate app on your cellphone or from one of several websites that track such information. -
Needs to change the struts. Easy to do, takes only minutes. Heres a Youtube video from mactfordedge on how to change. He used Monroe, I prefer Motorcraft (but they cost more.) https://m.youtube.com/watch?v=CqnmfIjmoqo
Oem cameras are selling for $340-$360 on Ebay. Don't think that it would be too difficult to replace.
Cold Air only
enigma-2 replied to Thomas Edwin Worthy's topic in Interior, A.C., Heat, Interior Trim
Does really sound like the HVAC control module. Could be programming. Read the following series of posts: http://www.fordedgeforum.com/topic/11725-dual-climate-control-repair/ -
ambient light question
enigma-2 replied to northernone's topic in Interior, A.C., Heat, Interior Trim
If you have ambient lighting, is it turned on? (Pg 399 of the OM). -
I'm confused. Are you saying that it opens ok, but does not close when the temperatures are cold? (Closes ok when warm).
It takes me to the correct page. Try it again.
Sync3 freezing 2016 edge sport
enigma-2 replied to RocketDog's topic in Audio, Backup, Navigation & SYNC
It appears that since the last sync update, you now have to hold the "pickup-end" button on the steering wheel a few seconds until hang up occurs. (New "feature".) -
Never done it, but I believe if the bubbles are still there, I would poke them with a pin and try to roll them out. Failing this, I would try an ice cube to see if the rubber could be shrunk, then try rolling again.
Just the battery. Ford usually has a coupon for theirs posted on their website. If you go thst route, get the bigger battery, for about $20 more you should get an extra year or so of use.
The Vista roof is specifically covered in the esp warranty. (Just the mechanical and electrical parts, no glass is covered.)
Yeaaaa, when I used to get a bug up my ... I used to run it through the car wash first, just to get a head start on the process. At my age now, it's much easier to just drop it off at the detailer and pick it up at the end of the day. That way you can drink all the beer you want and still get it clean. HA. -
Perhaps a different dealer might offer better service. Why not contact these people and see what they can come up with. https://parts.lakelandford.com/a/Ford_2013_Edge37L-V6-FWDSport/_51505_6476434/FRONT-SEAT-COMPONENTS-SEATS--TRACKS/MS11440.html Btw, have you tried finding one from a wrecked car? There's a search site online (used it years ago when looking for a blue, leather steering wheel for my Merc Sable. Turned out a yard somewhere in Southern Ohio had one like new.) Don't have the url anymore, but it should pop up in a Google search.
