enigma-2
    303
  1. Hold on, that's a big clue. If the sensors worked when first tested, they may have been using the old sensor data, still encoded in the module. After rebooting, the module reread the sensors, and the new sensors were reread and the module turned off their inputs (believing they were generating bad data.) Try switching sensors, then reseting the circuit. The old sensors "shoud" be read as good and work in their new positions. But the new sensors, now relocated to their new positions, should get locked out. If this test works, it would indicate that you may have bought the wrong sensors, or Chinese aftermarket. (Arrruggg)
  2. My money would be on the connectors. (They worked when you tested them, you tried other, know good sensors, so I'd assume there's a problem in the connection. Look for green crusties or dirt.) I assume the other sensors at the rear work normally?) Doubt it will do any good, but wouldn't hurt to reset the system. On your info screen, in reverse, turn off the backup sensors. Put in drive, then back in reverse and turn the sensors back on. .
  3. @Wubster100 You ever replaced the shocks or struts on your 07? I've replaced to shocks around 120k, but not the struts. Didn't really notice much difference. 140k miles. Wonder if replacing the struts would improve Ride quality? Ride is still smooth and Ford told me the struts are still good. Ride is comfy, but no where as good as my 2004 Sable. Now that, was a smooth, comfortable ride. Best car I ever owned.
  4. This guy walks through how he lines up the phasers & crank. May want to watch it all the say through. (42 minutes.)
  5. Couple of ideas where the vent isn't blocked. https://www.amazon.com/Holder-Accessories-2015-2024-iPhone-Smartphones/dp/B0DJP5DBH4/ref=asc_df_B0DJP5DBH4?mcid=f4bd478cc13e3211a2e3d201c9a80d40&hvocijid=11554450677427836686-B0DJP5DBH4-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=11554450677427836686&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9016241&hvtargid=pla-2281435177618&psc=1 https://www.proclipusa.com/products/241502-proclip-center-mount-ford-f250-350-450-550-super-duty-2017-20xx-ford-expedition-2018-2020?gad_source=1&gclid=Cj0KCQjw2N2_BhCAARIsAK4pEkWisRlxppcIaJguP90xu8FUd13DHBVnwJygS0pmszvRwvsHCnjI_1YaAgrfEALw_wcB
  6. Did you check to see if the 2.0.10 version was automatically installed on your car? Maybe your car no longer needs the update and the site recognized this.
  7. Ford Diagnostic & Repair System? Cant you just do it through the Sync 4 system? ->Settings-> General-> Automatic Updates-> Scan for Update Now .
  8. As this is only happening with the front, left brake, it really sounds like the brake fluid is flowing into the caliper (brakes applied) but unable to completely flow out; until it slowly bleeds off when sitting. If so, I'd suspect a sticking brake caliper piston, kink in the brake hose, caliper pins needing greasing or air in caliper.
  9. Believe the FS100 was discontinued over 10 years ago. FS106 is the current one with holes.
  10. Ahhhh ...... yup. That would have been a good thing to mention during the original write up. 🤔
  11. Not on your gen. 1st gen lens is easily removed. On 2nd gen i understood it was glued on, near impossible to take off. (Which is why they fall off.) <cough>
  12. I have an aspirated 3.5. 7.5k is the recommended interval, although I usually add a quart around 6k miles.
  13. Your 2020 model year 2.0L is of the new design and should be immune to the head gasket failure. But the engine still has to overcome carbon build-up, turbocharger issues, spark plug & coil failures.
  14. Those intermittent errors are a usually a bad connection or near break in wiring. Did they trace the wiring to the bank 1 Sensor 2? I'd look for a weak ground in the wiring that intermittently opens. The P0137 is the sensors heater isn't getting voltage. Hook a voltmeter to the O2 connector's heater wire, (both + and ground) and work backwards, wiggling the wire while watching where the voltage falls off.
  15. Ah ha, so you're the one. They've been searching for you. Now that you've surfaced, prepare to be rounded up and taken to a MAGA re-education facility. Its located in South America. You'll love it, warm year round, every day is a holiday, every meal a banquet. Soon you'll be one of us, walking around with a stupid smile on your face, ketchup stains on your t-shirt, repeating over and over "I know nuth-ing."
  16. I use the dealer as well. What I use for a schedule is: • Oil (at 7.5k) • Power steering (40k) • Brake (30 - 60 k depending on environment) • Transmission (60 k) • PTU (30k) • Coolant (30k) • RDU (90k or after anytime car driven through deep water) • Can of fuel injection & system cleaner (1-2× year) In addition, don't forget to check: the air cleaner (30k), the cabin filter (every 6 mos), seat filters (if you have heated/cooled seats) (annually), fuel filter (150k) and air pressure in spare tire (every 6 mos).
  17. When you say expelled, did you mean gone, or it dumped out on the ground?
  18. Probably the outside temperature sensor failed. It's located behind the front bumper, closer to the passenger side.
  19. I also wipe my wiper blades with an alcohol wipe to clean the dirt off the blade, then wipe with with 303.
  20. I use 303 Protectant on rubber parts exposed to the sun. Use silicone spray on the BAMR moving parts. Believe 303 is a better product for high sun locations. (Very highly rated.) https://a.co/d/2C32Ku5
  21. The lens itself isn't available for your year (only Gen 1 lens available.) If I were you, I'd buy a Dorman off Ebay (make offer for $80), pop off the lens and glue that sucker to your existing light.
  22. Passenger rear: easy checks — rear mud flaps, air shields under car lost a fasrener or two. Sounds like a piece of tape or paper. I'd also look at the right rear dust shield on the rear brake. Best thing to try is what @STBEAST wrote. Have someone else drive and crawl around the backseat and rear compartment, while finding where should is loudest. There was a guy on YouTube who used wireless, magnetic mount microphones in various locations. Allowed him to quickly work down where the sound was loudest.
