olddude#1
Everything posted by olddude#1
  1. My edge presents me what I call a rumble through steering wheel when start to drive and will continue roughly until you get to about 60 mph and it reduces but remains. My local mechanic thought it may be the flex plate based on forum info but recommended I Take it to a transmission specialist. Took it to a transmission specialist and he was sure it was not the flex plate after lengthy road test. he said tranny change perfectly and motor performed perfectly. Took it to my Ford dealer they preformed a diagnostic and road test and concluded it was not the flex plate or torque converter and supported the finding of the tranny specialist. At 60 mph car in neutral rumble decreases but when accelerator is pressed the rumble return. At 60 mph car in neutral and the ignition turned off there is not a rumble and know steering noises or other audible sounds. Ford dealer suggest the problem could be motor mount or mounts but could or would not say that this would resolve the issue. Looking for help or recommendations before I make a large financial investment Thanks Help Help
  2. Hello, I am Perry My dash noise occurs primarily when I am stationary If I change the temperature setting I can eliminate the noise on occasion it will occur while driving. Told by dealer if could be a damper or thermostat/temp control value going bad It's to costly to experiment I would appreciate any sound advice or solutions Thank you
