SOMDTBSS
Everything posted by SOMDTBSS
What does it take to install?
Installed LED's in the SS(not an Edge.. Sorry), And live them, every light buld is now HID or LED, its great... Very much worth it!! :yup:
Foglight Prewire?
SOMDTBSS replied to PrinzII's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
When you replace the non fog light switch, with the new headlight/fog light switch, you can hear the relay clicking to turn on the fog lights. I could not however find the wires leading out of the Smart Junction Box to run to the fog lights. There is a Tan wire with a yellow stripe on the plug for the head lights switch, that same wire is also going into the SJB, I tapped into that wire, to use as the latching 12 Volt signal wire for the AEM relay harness I installed to use with the new OEM fog lights... I spent a lot of time in the foot well of the Edge attempting to locate the fog light wires and was unsuccessful...... Otherwise, it’s a pain in the ass!! But worth it, next I will probably be adding HID to the fog lights… -
Foglight Prewire?
True that! Its probally a relay, or something else along the lines of that... Also, HID install came out GREAT!!! 6,000 K low beams, looks good, easy install!! -
Foglight Prewire?
No prewire..... I have a fog light wiring harness, bought it form local store, its a AEM, comes with a relay and all equipment needed to install lights. Tonight i am going to take the dash apart, and attempt to find the wire that comes outta the stock switch to work the fog lights. I bought a new headlight switch from ford with the fog light option. installing the lights was easy! Crawl up under car, i took the bottom plastic piece off, reach up, and the stock black grilles come out,(where the new lights will be going), and the fog lights and new grills just clip in. Tonight i am going to wire, ill get back to you guys tonight or tomorrow.... -
Foglight Prewire?
I will have a definite answer for you guys this weekend, parts should be here tomorrow to install for lights on edge, using the parts list on this forum in a different thred... Edge will be up on ramps Saturday night... More info to come.. Guessin i am the Guinna pig here! -
Depends on what kinda upgrade... Different color? Brighter? Re-aim them? What are looking to do? You might wnat to think about different color bulbs, or even HID's. But, this, like most other forums, if you look around, i am sure you will find the answers your looking for!
I have rotational tires on my other truck, and i know that their mounting is very important to their performance(hence the "directional" markings on the tires). Therefor i cannot do a conventional tire rotation,(left front goes to right rear) without having them unmounted, turned around, remounted on the rim in the opposite direction. In my knowledge, they would not put a "inside" and "outside" marking on the tires if they didn't mean something... just my 2 cent!!
Took SS to back to dealer today(warranty work), so the edge is the next project, whenever i get up under it and start lookin around ill keep you guys posted on the fogs/HID Install, pictures will be included!
OEM Fog Lights
SOMDTBSS replied to SOMDTBSS's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
SLP Headers, MAC CAI, Ported & Polished Throttle Body, E-Fans, HSRK, Hotchkins rear sway bar and front bushings are this month. SLP top end(rockers arm and push rods), Corsa Touring Exhaust, and MSD ignition will be on the way. I already have the engine covers painted, HID installed, and working on a fiberglass custom enclosure. -
I just ordered the parts to do mine, ill let you know how the install goes whenever the parts come in.. Read me!!
OEM Fog Lights
I don't know, i have not had a chance to crawl up under it yet...(headers came in for Trailblazer :happy feet: ) when ever i get the chance ill look... If not, wiring is not that difficult... And...just ordered HID kit for Edge! Edge might look good, but not as fast as Trailblazer SS!! It does get much better gas mileage however..... -
OEM Fog Lights
Yeah, just ordered them!! :yup: Ill let you know how the install goes!! :hyper: -
Really?? The Trailblazer SS is my playtoy.. The edge is more the wife's truck then anything else, but, ill still play around with it! I gotta hook it up!!
OEM Fog Lights
True that, but i liked the look of the OEM lights, they just didn't have any at the dealer! And as close to the ground as the fog lights are, i think the projectors are the only way to go. Had regular lights on a Cavi, and replaced them every 6 months.. But i have not had any problems outta my Trailblazer Projector fog lights, and its lowered, on the beltway, high speeds!! -
Black 2008 SEL, with SYNC
Looking to buy a pair of OEM Fog lights. According to the dealer, they are not avaible(bunch o tards, they prob are). Was just wondering.. Thanks!
I didn't buy one, the wife did. And ill be the one working on it! How is everyone? In the southern maryland area here...
