selecoboost2013
About selecoboost2013
selecoboost2013's Achievements
  1. This is something that should be included on the scheduled maintenance. What I found is that 2 things can happen as carbon build up, one there is a gradual loss of power or two there is a sudden loss of power under hard acceleration. The second one is the one that concerns me more because it could be dangerous if you are merging on the freeway and suddenly the vehicle losses power on goes into limo mode.
  2. I got the wrench light while accelerating to pass on a hill. Then I notice a mild loss of power. My wife took it to the dealer and I don't know what the problem was but it is fine now. Should we be worried about the carbon build up reported on other direct injection engines?
  3. http://www.fordescape.org/forum/electronics-audio-lighting/27193-standard-radio-8-nav-conversion-3.html That's too bad, on my 2013 escape I was able to do some changes to the bcm and enable global open using a software called focccus and a OBDII scanner.
  4. Is there any way to have the signature led lights on at all times or use them as daytime running lights? Has anyone enable this on the BCM?
