jmr061
Everything posted by jmr061
Unless you have the B&O Sound System by Bang & Olufsen it does not have HD radio. Don't believe this is available in the 2020 ST-Line. The B&O Sound System by Bang & Olufsen uses a completely different ACM which has only the audio output for the amplifier which. The ACM is physically missing the hardware for driving speakers without the an amplifier. What this means is an HD receiver won't even function properly in your vehicle.
Trailer running lights stay on.
jmr061 replied to Snoking's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
SSM 49179 - 2015-2020 Edge, 2016-2018 MKX, 2019-2020 Nautilus - Parking Lamps Stay On And/Or Trailer Lights Flicker With Vehicle Turned Off Some 2015-2020 Edge, 2016-2018 MKX, and 2019-2020 Nautilus vehicles may exhibitthe parking lamps stay on and/or the trailer lights flicker with vehicle turnedoff when a trailer is connected to the vehicle. This may be due to the softwarein the trailer module (TRM). To correct the condition, reprogram the TRM with the latest software of the appropriate Ford diagnostic scan tool. Use causal part19H332 and applicable labor times from Section 10 of the Service Labor Time Standards (SLTS) Manual. APPLICABLE VEHICLES 2015 - 2020 CAR: DQ CD539N EDGE 2016 - 2020 CAR: D9 U540N MKX -
I'll do you one better. check the pdf, 19 edge st drain fill.pdf
Dash shows tank has more miles with regular than premium!!?
jmr061 replied to kapk22's topic in Accessories & Modifications
Fill up with premium, shows 273...meaning it is basing DTE off the previous tank driving habits Then fill up with regular after the premium tank and now showing 319 DTE which is based off your premium tank. Granted it may or may not be attributed to octane as many other factors come into play (driving habits, weather including wind, temp, etc) So it seems right to me. -
Brakes Worked Fine, Until the Dealer....
jmr061 replied to SmokinJoe's topic in Brakes, Chassis & Suspension
I replaced my rear rotors and pads at about 15000 I think. Ford is known for crappy rotors. Not sure why they would have replaced your calipers though. I wouldn't leave a vehicle for a long time with the parking brake applied. The pads probably were stuck to the rotor. An inspection may be in order. They have the front brake hoses now. Owner letters are going out in May. -
Sorry I may have gotten some part #s mixed up while searching for downloads. I thought that was 4.1.3 but looks like I mixed up some of the file name. Just do searches for the files in that list. See what you can come up with.
2018 Edge FordPass question
jmr061 replied to brigantinebob's topic in Alarms, Keyless Entry, Locks & Remote Start
Mine works great. You need to research it and be comfortable with all the aspects of installing it and setting it up or pay someone to do it for you. -
False, it was not available at all on the Edge in 2018. Confirmed via dealer order guide. Also false that it can't be added. I added it to my 16 Edge a couple years ago if not more. It's not officially supported by Ford for upgrading but it can be done. -
For the Edge it wasn't available until 2019. The info is out there, its not a con unless you were told by a saleperson it has it. -
Sounds like the PTU is bad. There isn't really anything you can do yourself. Changing the fluid in it would likely be useless at this point and no, there is no dipstick for the PTU. A new PTU may be in your future. Curious....what's your mileage?
This appears to be an older version. Use at your own risk http://ivsu.binaries.ford.com/owner-package/1148041883126412588/DR3T-14D544-AG.zip No idea if it will install. Here is something I found...and the 13 Edge's I looked up that seem to have original software are 4.1.2 Use the table below to match the FPN number with your SYNC software version. SYNC Gen 1 Software Version CIP/FPN V1.01 8L2T-14D544-AD V1.02 8L2T-14D544-AE V1.1 9L3T-14D544-AC V1.2 9L3T-14D544-AD V1.3 9L3T-14D544-AE V2 9L2T-14D544-BC V2.01 9L2T-14D544-BD V2.1 9L2T-14D544-BE V3 AR3T-14D544-AC V3.01 AR3T-14D544-AD V3.1 AR3T-14D544-AE V3.1.1 CM5T-14D544-AC V3.1.4 CM5T-14D544-AD V3.1.6 CM5T-14D544-AE V3.2 BG1T-14D544-AB V3.2.2.2 BG1T-14D544-AD V3.2.4 BG1T-14D544-AG V3.2.5 BG1T-14D544-AH V3.2.6 BG1T-14D544-AJ V4.0 CR3T-14D544-AB V4.0.2 CR3T-14D544-AC V4.1.2 DG1T-14D544-AC V4.1.3 DR3T-14D544-AD V4.1.4 DL3T-14D544-AB V4.2.1 DG1T-14D544-AE V4.2.1.4 DR3T-14D544-AE V4.3 EJ5T-14D544-AA V4.4 FJ5T-14D544-AA V4.4 FJ5T-14D544-AB V4.4 DE8T-14D544-AC V4.4 CM5T-14D544-AF V4.4 DR3T-14D544-AF V4.4 DL3T-14D544-AE V4.6 Varies depending on vehicle and region V4.8 Varies depending on vehicle and region
So you are at version 4.6? What was it previously? You have the 4.2" display right? Ford does not support rolling SYNC software back. A long press of the voice button or simply saying hey siri doesn't work?
I want auto start for my 2015
jmr061 replied to StewSuhr's topic in Alarms, Keyless Entry, Locks & Remote Start
https://www.12volt.solutions/products/2015-2017-ford-edge-remote-start-plug-and-play-kit-1?variant=32580098228327 -
Liftgate Latch Release (manual liftgate) The liftgate latch can be released using: the exterior liftgate release switch. a valid programmed passive key. The BCM sends a voltage signal to the exterior liftgate release switch. When the liftgate release switch is pressed, the voltage signal is routed to ground, indicating a request to release the liftgate latch. The BCM momentarily provides voltage to the liftgate latch to actuate the release motor. When using the liftgate release switch, the BCM releases the liftgate only when the doors have been electronically unlocked and the vehicle is in PARK. When using a programmed RKE transmitter, press the liftgate release button twice within 3 seconds to release the liftgate latch. The liftgate latch releases if the vehicle speed is 5 km/h (3.1 mph) or less. The liftgate latch can also be released using the passive entry feature. Refer to Liftgate Passive Entry in this section. 15 edge manual liftgate.pdf
2011 Ford Edge Sync Replacement
jmr061 replied to magnum3672's topic in Audio, Backup, Navigation & SYNC
I sent you a direct message. -
The original APIMs for MFT are known to have high failure rates. Thats why Ford did an extended warranty on them (which is expired now btw) but Ford made improvements to the APIMs and they do hold up much better now. Problem with these other sellers is they will use whatever APIMs they can find cheap and use non ford methods of programming them. I only provide the correct latest gen APIM for SYNC2 replacements and program them using the official Ford method which means the latest software and firmware are in them and they are linked/programmed to your vehicle in the official Ford SYNC service registry. I charge $315 plus shipping. I don't have any in stock right now but can track one down if you want. -
Personally I'd just go with what the vehicle came with. The BMS (battery management/maintenance system) is setup for what it came with. I recently had to replace the battery in my 16 Sport and while it was tempting to get a higher CCA amp I just bought one that matched the OEM specs. The original lasted 4.5 years. I figured that was pretty good considering I hear stories of newer vehicles eating batteries every 3 years or sooner,
Interior Chimes and Warning Sounds
jmr061 replied to NonnieMiss's topic in Alarms, Keyless Entry, Locks & Remote Start
The chimes go through the stereo system typically if everything is good and healthy and the can bus network is all timed and in sync. If anything is amiss it defaults to the instrument cluster speaker. That is what is happening. Probably because of the weaker battery voltage from sitting. -
I am going to have to disagree with others and Ford and say it should be covered. Its an electrical fault within the mirror glass, not a defect within the construction of the mirror glass functionality (like the mirror isn't reflecting anymore) or customer damage. If the defroster on the rear window goes bad and isn't repairable, because it's on glass it wouldn't be covered? I call BS. It's an electrical issue and should be covered.
