jmr061
Everything posted by jmr061
Ford did recently come out with a customer satisfaction program for the 1.5L in some vehicles (not the edge) for the same type of problem. Eventually if a CSP would come out for the 2.0 in the Edge owner's would be eligible for reimbursement. There is some hope based on the CSP for the 1.5L. Cross your fingers, keep poking the bear perhaps, etc and maybe wishes will come true.
That isn't what TSB means. TSB's are only covered under warranty if the vehicle is under some sort of manufacturer warranty whether it be bumper to bumper or extended. If the vehicle isn't under warranty, a TSB is paid for by the consumer. A TSB is not a recall or customer service satisfaction bulletin.
What is this part I found in my driveway?
jmr061 replied to Cyberdave's topic in Brakes, Chassis & Suspension
Looks like an exhaust hanger. -
Wow - 2019 - multiple fault indications - 8 alerts
jmr061 replied to mrthejuice's topic in 2019-Current Edge & Nautilius
9 times out of 10, multiple unrelated faults like that are a voltage issue. Even if the battery terminals look good, clean them anyway. If it still does it, swap out the battery. You don't have to install a Motorcraft battery. I have a battery from O'Reilly Auto in my 2016. If you have a friend that has a comparable battery in their vehicle and they are willing, try sticking theirs in your car for a test. -
Ive never heard of a dept running a tune on a vehicle. Newer vehicles are pretty quick these days just from the factory. They don't use undercover vehicles for pursuits and such for the most part.
Exactly what @omar302 said.
Heated/cooled seat stopped working 2016 Edge sport B272C
jmr061 replied to 68lemans462's topic in 2016 Edge & MKX
Both heat and cooling run the fan. There are no heat mats in the seat. It is a TED unit. What is a Ted in a heated seat? The thermal electric device (TED) is a heat exchanger that has a function to heat or cool the air flow from the climate-controlled seat blower motor. By changing the direction of the current from the power supply, the device takes or gives heat and adjusts the heat exchange process depending on voltage. -
It could be the radio itself. Not having checked for DTCs yet is an issue. There could be a DTC waiting that tells you exactly what is bad rather than just throwing the parts cannon at it. I had access to the manual last week. It just showed that the antenna has a separate AM/FM versus Sirius/GPS antenna (both contained in the sharkfin). The antenna has a power wire running to it from the ACM. It didn't show any other parts other than a splitter for the GPS/Sirius signal. It could be the antenna or it could be the ACM. The FM radio in the ACM itself could be bad. BTW the 14D212 part you mentioned....14D212 is the base part # for APIMs, nothing to do with radio reception.
LIncoln MKX to Ford Edge Instrument Cluster Swap
jmr061 replied to onyxbfly's topic in Accessories & Modifications
For the Explorer a plastic brace has to be cut out and the PLATINUM cluster lens and PLATINUM cluster bezel has to be used.- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
I wish I had access to the service manual but I don't otherwise I would pull some info for you. I did do a parts lookup and the shark fin looks to have am/fm and satellite in it and also there is a part they call an isolator as part of the antenna system as well. I would guess its one of those parts or the ACM itself may be bad. Has the vehicle been read for codes? The ACM has the capability to throw codes for antenna issues.
The APIM has nothing to do with the quality of your radio reception. Did you read my previous post?
The antenna is connected the ACM (CD Player) and you shouldn't have need to remove that to install SYNC3 so doubt you messed with the antenna connection unless wiring harnesses got pulled on or something like that. The ACM will throw a code if the antenna is bad or not connected. Have you had it read for DTCs?
2011 Ford Edge Sync Replacement
jmr061 replied to magnum3672's topic in Audio, Backup, Navigation & SYNC
Yes...you can get it here: APIM REPLACEMENT -
2015 Edge sport rear brake calipers and Elec parking brake
jmr061 replied to Eric46's topic in 2015 Edge & MKX
The tool isn't the spinning tool, you will also note they say if it doesn't bottom out then try to spin it while using the retractor. -
Here is what I have for the 2016... 2016 Edge Rear Brake Pads.pdf -
The 15's and up don't use the screw type that I know of. When I did the brakes on my 16 the service manual didn't call for screw type. I believe that is 14 and earlier. -
Audio Control Module Part Number
jmr061 replied to jeffcarl's topic in Audio, Backup, Navigation & SYNC
Did you plug the electrical connector back in for the switch? -
Yes you can drive it with out an acm. How much is it going to cost to have it repaired? Contact me if you want as I can track down and program the correct module for you as it appears you can’t find one yourself. -
Which SYNC system does it have? If it helps is it the 8" touchscreen or 4.2" non touchscreen. If its the non touchscreen what happens when you press the phone button?
Solved: High-Pitched Whine Noise from Fuel Pump
jmr061 replied to murphye's topic in 2009 Edge & MKX
I don't have an answer for you but I do have a suggestion as far as the forum goes. You revived an almost 12 year old post that has "solved" in the title. Probably not going to get many looks plus you are talking about a noise in the engine area, the original post was the back of the vehicle and a 2009 model year is completely different than a 2021. They didn't even a have a 4 cylinder ecoboost in 2009. I would suggest starting a new post, probably going to get more views an answers. -
The meter....are you trying to alter the odometer?
3G retirement and Navigation issues
jmr061 replied to TimothyFS's topic in Audio, Backup, Navigation & SYNC
Cell service has nothing to do with your navigation on a 2020. -
It would be nice to get a VIN so can determine what firmware it is running on the 19/20- 110 replies
- digital dash swap
- (and 3 more)
Does this cluster exist in the 19/20 Edge in Europe?- 110 replies
- digital dash swap
- (and 3 more)
