dre2142
Everything posted by dre2142
Is there a way to rest the BMS manually without a program? I have a 2013 Limited.
Hey all- My son has a 2010 Ford Edge Limited. He got a subwoofer and amp that he wasnt to add in. I had systems in the past in my younger years but that was a long time ago and these car stock systems have changed. Just clarification- he'll keep his stock headunit so we'll need a rca lineout converter to attach RCAs, (tapping into which two wires on the stock harness?), and remote wire tapped into back of unit as well- any idea which specific colored wire on this car? Blue I assume? He just wants a little more bass so nothing too crazy with this system hes adding. Thanks in advance!
Blower motor replacement?
dre2142 replied to Yankeesgirl05's topic in Interior, A.C., Heat, Interior Trim
My fan is making a clicking/whirring noise. I have a 2010 Limited- DUAL zone. Can I get away with one of the cheaper replacement fans or do I need the motorcraft replacement? (MM966, #7T4219805A)? Dont want to throw too much money to it as I plan to trade in sooner than later. -
Thanks all- seems to be the problem. Part 8T4Z-3A719-A Rock auto parts here: whats the difference between the Gates, Edelman, etc and the Motorcraft part- pics are different. Do I need the more expensive Motorcraft assembly, or can I get away with the cheaper ones? Looks like the Motorcraft/genuine ford part comes with a bit more to it. http://www.rockauto.com/en/partsearch/?partnum=8T4Z3A719A
Also there is no oil splatter anywhere above this point.
Hey all- I have a 2010 edge limited. I have a slow leak, and this is where its coming from, in the pics. Can anyone identify this part? Closer to the passenger side, off center of car. Not far from the oil drain plug. Nothing else has oil on it. I think this leaks mostly under pressure as Ive cleaned it all off and its not dripping right now. I also replaced a few of the zip ties, as two were one but broken. Doesnt seem to be dark enough for engine oil- more of a reddish color. Any help would be greatly appreciated! https://farm3.staticflickr.com/2810/34151678132_f6b98d89b4_s.jpg https://farm3.staticflickr.com/2863/33467816184_88a42d3f15_s.jpg
great thread
- 668 replies
- 2011 Ford Edge
- Limiited
(and 4 more)
my wife says she has a swishing noise when turning, and she has fluid near the pedal. is this bad steering pump?
It's a slight vibration in the steering wheel upon acceleration within that rpm band. 1800 to 2000 rpm.
I did the above and have slight feedback/vibration at 1800rpms.... any ideas of what could be causing this? Only issue I ran into was getting my rear boots off- had to end up replacing them as they cracked/broke on the way out. Kinda a panic moment on how to get them out but ended up using a hook tool to grab them and bring them out. Easy in the end.
Fairly easy job. Changed out my plugs, replaced with the same OEM.....cleaned out throttle body, replaced PCV (2010 Limited) I have a slight feedback from the engine now at 1800rpms.......any ideas?
Washer fluid pump...
dre2142 replied to dre2142's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The back nozzles on the back window are the same pump, yes?.......there is no problem getting fluid pumped to that back nozzle, so I must have an issue with clogged lines on the front. -
Thanks all- Ill explore more! -
So I wasnt getting any spray out of my nozzles.....check out the connections and both had broken off at the fluid tube at the nozzles under the hood. I think I got most of the broken nozzle pieces out of the tubes. Put new nozzles in, and now Im getting fluid out of the nozzles but they arent making it up onto the windshield. What do you think the problem is. A- tubes are clogged? I blew through the ends of them and blew bubbles in the resevoir. B- pump is dying or not pushing hard enough? Is this an option, that the pump is only half power or is the pump a "it either works or it doesnt"? Let me know your thoughts. Thanks all
And is there a Mecon LV name brand equivalant?
Only 5 quarts? Or is that all that will drain at any given time?
With the cost of rotors being so low nowadays, what is the benefit of turning rotors versus just buying brand new rotors? Seems the cost difference doesnt justify turning.
BRAKE PADS...to many options, where do I start?
dre2142 replied to hehateme2812's topic in Brakes, Chassis & Suspension
Im going to order some of these Hawks -
Hey all- what are the normal OEM calipers on these Edges? AC -DElco considered the safe replacement? Looking at the ACDelco 18A2473 Professional Durastop Front Brake Rotor
