deestop
About deestop
deestop's Achievements
  1. My rear right shock nut (upper) was loose. Replaced the nut (oem)and the noise went away
  2. I have a 2015 sel... Are the antiflikr bulbout warning light an issue without the canbus decoders?
  3. UPDATE...Do NOT buy ebay aftermarket.. They will not fit and the wiring modifications are a real pina....live and learn I suppose... Awaiting ford to have an oem replacement. I might not have the car by then.
  4. I purchased some aftermarket off ebay and they would not work.. Don't go there... The oem is the best bet . Not sure about the wiring.. i would say if the harness and plug is there it would work.. The bumper needs removed which wasn't a big deal after doing it. videos are out there to help you thru it. Maybe call a dealer and see if the plug is wired back to the body control module and battery junction box?. As far as finding the oem they are out there online and prices vary greatly. good luck
  5. Is there a drop in "fog light" available that doesn't require wire modifications to make them operating.. Does Ford have one in the making with an angel eye or something a bit more interesting than the glow stick they have currently? I purchased these from ebay because they are really nice but want to hook them up using my existing pigtail sockets w/o all the other wiring hookups.. unfortunately I believe this is a no go... The chinese kits have no wiring diagram and almost no tech support taking the bumper on and off makes this a bit more challenging.
  6. anything out there that is plug and play type for 2015-18 fogs to replace the drl deco lights?
  7. deestop
    Alternator
    I own a 2015 edge SEL fwd 3.5l with a whopping 27,232 miles on it and recently had to have the alternator replaced by a ford dealer to the tune of $1381.11... Evidently the first gen of the edge has to have the cooling compressor removed along with several other obstacles to perform the replacement. I realize this is way early to loose an alternator and Ford will not allow any warranty on this. (It sure makes me want to look into another make.) Any warranty or something out there to help cushion the blow? The dealer tried selling me an ext. warranty at the tune of 3g or 113.00 a month on a car I am still making payments on.
