rwf78155
    5
Everything posted by rwf78155
  1. the badge add's 20 hp ! jk Happy Thanksgiving !
  2. Welcome......as you will soon find out, this site is a great source of info from great members
  3. onyxbfly....I did not see your earlier reply to me on tire options ....
  4. I'm soooooo hoping that Toyo will step up to the plate and make some 21 inch tires ....fabulous tires !
  5. Can you give me the brand and model of the tires so I can replace my Pirelli's
  6. akirby....the three hour test was to test and totally reset all electronics in the vehicle to factory settings
  7. Got the vehicle back..... A three hour computer/run test showed the battery was at fault......not consistently putting out 12 volts. Ford (Griffith Ford) put a new battery in and reran the test with no issues !
  8. Got Home Thursday night and pushed the button on my 2018 Edge Sport and all electronics (dash, gauges, radio etc.) shut off but.....the engine remained running. I tried shifting it in and out of park, drove it around the block....tried everything and the engine continued running. Finally after 15 minutes it shut off, which is a built in Ford safety feature. It's been at my Ford dealership and they say they have never seen or heard of this, btw......the check engine light remains on Anyone else ever seen or heard of this ?
  9. Took it to Ford because the engine won't shut off with the start/stop button.......everything else turns off except the engine !
  10. just replace the filter in the stock airbox with a K&N like I did ...adds 20hp......jk !
  11. My 2013 ( which I traded in for a 2018 ) had the same issue. It turned out to be the shift to park system was not shutting systems down when the vehicle was turned off. My Ford extended warranty covered everything and even paid for a rental car while they waited for the repair parts
  12. Anyone know the name of the paint color or the paint code for the 21 inch wheels on the Ford Edge Sport
  13. My previous Edge Sport did the same......turned out to be a faulty shifter switch and was replaced by Ford at no cost due to a recall
  14. Ive run mine down to 5 miles to go and when I filled the tank it took the amount required for an empty tank..
  15. but Ford performance has dropped the ball on the Ford performance tune for the 2018 Ecoboost...which is still not available !
