ronaldo1981
Everything posted by ronaldo1981
Using ford IDS application and VCMII or VCM, a battery monitoring system reset is necessary. "BMS reset procedure"
replaced the seals but, the leak showed up after 100 miles, the shaft journal is POS and im buying a new shaft. im king of failure.
i need some used parts for my 11 edge limited AWD 3.5L as follows: 1- air bag module 2- driver seat module 3- passenger seat occupant classified module 4- SONY amplifier 5- 1 18" chrome clad wheel or just wheel cover 6- wheel nuts. shipping to 34238 FL or 75050 TX thanks
seems like he is not available anymore
ordered a new shaft from ebay, damn this will travel overseas and cost me 150 at least! in addition to the new damaged installed seal.
hello do you still have the rims? i want to buy one shipped to tx grand prairie thanks
im located in baghdad and i have too many parts order from the us, but shipping similar part with that weight will cost me a fortune. does the shaft from 11-13 explorer fit to the edge?
the seal washer and deflector are different than the old kit. I hope to find a good used shaft but why not buying a new one 70$ is not too much to stop that damn leak.
Hi. 11 edge 3.5L AWD. RH ATF leak. The manual recommended seal kit # DB5Z-7275-C. The seal washer is little different and the extra seals were recycled. The leak came back after 50 miles. Grrrrrrrr But this was a concern. The shaft journal that the seal seated on was bad. Now I have the same new kit but need an advice. Replace the intermediate shaft due to a bad journal. ?
Anyone ?!
Hello everyone My friend is asking me to install an OEM rear camera to his 2011 edge sel (it doesn't have the navigation screen ) so it has the human interface machine 1 with the small LCD screed. Is that possible? Thanks.
Key Fob Issue
ronaldo1981 replied to fifthranger's topic in Alarms, Keyless Entry, Locks & Remote Start
You can program the remote by turning the key off>on 8 times in 10 seconds then stay on then press unlock botton. -
hello everyone im having this issue with several 11 edge transmissions which became more mysterious to me EVEN with my ford factory diagnostic tool (VCMII). when setting the ignition key in the ON position without starting the engine I can hear a LOW whistling coming from the transmission (im 100% sure) and it keeps coming in all gear floor shift positions (PRNDM), after 10-15 minutes the battery voltage start draining down than 11v untill it die after 30 minutes, all the above is without starting the engine p.s i cant hear it when the engine is running. all fuses relays connectors sensors etc are ok....: no DTC or fault when scanning everything and data logging, im sick looking for the problem!! the whistling goes away by:- 1- setting the ignition to OFF or ACC. 2- disconnecting the transmission main connector (i hear a clicking sound while i do that). 3- disconnecting the PCM connector that going the transmmission. the car was flooded in the USA and the transmission core (valve and solenoid bodies were replaced). the transmission works just fine with no problems at all, up/down shifts o/d etc..everything normal. hope someone tells me that's normal, just replace the battery it is bad!
thanks, lots of parts are being ordered and shipped to me!
hello everyone sorry for the lack, im little busy working on the car..now i will shut my mouth and post some pics..here we go! im looking for used electrical components for the car if someone has a part out vehicle... cheers.
hello everyone im saddam from baghdad and im a ford tech, i have the ford dealer diagnostic tool VCMII and ford IDS software. im having fun getting the flooded ford vehicles coming from USA back to life again including my 11 edge limited. hope we help each other with information including the programming (PCM BCM RFA IKT IA) etc etc. im a ex 98 ford crownvic owner and i really loved it but was sold for security reasons. glad to be here
