big.e
Everything posted by big.e
  1. I need a little help with the wiring. For anyone that has done the install in the pbal you get what I believe is the ballast which has a red male wire and blue male wire. On the headlight housing there is a female red wire and black female wire. I am assuming you connect the red to red and blue to black. Is that correct. Also the headlight housing has 2 black wires and 2 white wires which I connected both of the white and then both black. I know this needs to be spliced in the factory harness just confused on where. I was thinking in would be the turn signal/parking lamp. Which has 3 wires a black, red and green. I was going to tap the white to red for powere and black to black for ground. Does this sound right?
