CinnamonEdge
    7
About CinnamonEdge
955 profile views
CinnamonEdge's Achievements
  1. Push rod needs adjustment on the booster it may be out too much.
  2. Well you might get your wish. NHTSA is investigating the issue. Mine wasn't letting me lock the doors or use my auto start. I consider no locks a serious problem. Ford did fix it under the original warranty. I hope that the extended warranty would cover it also.
  3. I wax mine every other wash with a synthetic wax. It helps repel dust and makes it easy to clean. In the winter months it protects the wheels from the road salts.
  4. Im under warranty until March 2019, 75k miles, no problems yet. But only have 30k.
  5. Im sure they wouldnt install it like that. but the design is weak . Its like holding a glass with a pair of pliers. I'm scared to close my doors now.
  6. I might be interested. What tunes are on it now? Who was the original seller? I was quoted three tunes for 200.00 from Unleashed Tuning.
  7. my temp button? the only one I have is on the touch screen.
  8. I'm going to drive to the dealer to see if they will replace it tomorrow.
  9. My warranty ends on Wednesday March 30th,3016.
  10. My front and rear ford emblems are showing signs of corrosion. The front is worse. The front emblem was replaced a couple years back. I showed my dealer 6 months ago and they said it's not bad enough. Shouldn't ford replace this again? It's much more noticeable now.
  11. OMG. That is not right! get that towed back and have them replace the seal now that the vibrations probably ruined it. the blue stuff is Loctite so that the bolts cant come loose. it should not be showing at all.
  12. sorry just thought it was funny you have a milan and an edge? I have the same combo. Ignot silver Milan 2010.
