Whiteknight08
About Whiteknight08
618 profile views
Whiteknight08's Achievements
  1. Yeah the ILDS is mostly people who like to dress up their vehicles in their own way and Lowered vehicles. http://ilovedrivingslow.com/http:/ilovedrivingslow.bigcartel.com/ilds 'Driving slow is a lifestyle. It's the way you drive, the way you dress and carry yourself. Most importantly the way you dress your car.'
  2. So I am guessing this is the new one huh. only difference is that it has WiFi capabilities so you dont have to plug it into your usb computer. http://www.autoanything.com/performance-chips/sct-x4-power-flash-programmer-49-state-legal For high-octane performance, tune your ride with the high-tech SCT X4 Power Flash Programmer (49-State Legal) Preloaded with an impressive set of dyno-proven and track-tested tunes for your year, make and model The easiest way to crank up your horsepower, boost torque and enhance throttle response Create and store up to 10 custom tunes optimized for your particular driving style Offers a wide range of adjustability to critical vehicle parameters, including rev limiter, shift points, idle speed and more (varies by vehicle) Increases fuel efficiency when you’re not pushing the pedal to the metal The SCT X4 Power Programmer features a smaller, more ergonomic design compared to the X3 Easy-to-read full color LCD screen that runs in landscape and portrait modes Auto-dimming for optimal contrast night and day Logs and displays PCM data in real-time while you drive, or review your runs at home using SCT’s LiveLink software Connects to your computer via built-in WiFi for easy updating Equipped with two analog inputs Measures 2.75” by 5.5” Street legal in all states except California Your SCT X4 Power Flash Programmer (49-State Legal) includes a 1-Year Warranty DescriptionThe digital revolution has just arrived on your dashboard. Celebrate technology at its finest with a SCT X4 Power Flash Programmer (49-State Legal), the most innovative tuner in the SCT lineup. More compact and ergonomic than the X3, the X4 boasts a brilliant full-color LCD display that puts huge horsepower, torque and throttle response gains right at your fingertips. Packed with dyno-proven tunes tailor made for your ride, the SCT X4 Tuner unleashes your full performance potential. But that’s just the beginning. With full control over a wide range of critical engine parameters, you can built and store up to 10 custom tunes for any situation, from towing trailers up steep grades to passing slowpokes on the highway. You don’t have to get your hands dirty installing the SCT X4 Flash Tuner. Just plug it into your OBD-II port, follow the on-screen prompts and you’re ready for action. Plus, it doubles as a digital gauge set, giving you real-time readouts of all your key speed stats. And with WiFi built in, you can update your X4 without ever connecting it to your PC. It even comes with a 1-Year Warranty.
  3. Thankb you all so very much. Greatly appreciated
  4. Ok next questions are 1) for a 2008 edge sel is the sensor on the valve stem or some where else. or in the actual wheel. 2.) If i get the tires mounted and balanced by the website. Then go on ebay to get the FORD tpms, will I have to dismount the tires from the wheels, then remount n balance them?
  5. You bet she does. She just turned two on the 25th.
  6. So im looking online at some different sites selling wheel and tire packages. They try to get you to buy 200.00 worth of tpms stuff. This sensor only tells you if your tire pressure is low, right? So do I REALLY NEED this sensor? Will it just give me an annoying light on my dash if I don't have it? Will the vehicle perform differently if I don't have it. main thing is if I dont NEED this sensor then I cant justify spending 200.00 on it. The wheel will still work the same as if it did not have it correct? Thanks in Advance!
  7. Nice Surfer1. Any one else want to post their aftermarket rims and tire specs?
  8. Just an update; Installed/replaced all map and dome lights to LED ones. Also the plate lights were interchange as well as reverse lights. Today I installed my HID's. 5000K 35watt low beams from a reputable ebay seller. Orangemika, i have dealt with him with all my HID installs and have had no problems. 30 bucks for 2 bulbs and ultra slim ballasts, fast shipping too. Will post pictures when it gets dark out. Thanks for looking
  9. So nobody wants to post their aftermarket wheels/tire set up? Maybe after taxes come back then there will be some pictures.
  10. Yes they are the same light n will fit. Try eBay for the tails. For a grille also try ebay too. If you dont like the chrome. You could always paint the tails your self. I did a DIY for it. Look it up.
