Everything posted by FordIVTteam
Incoming Bluetooth calls
FordIVTteam replied to mcali6301's topic in Audio, Backup, Navigation & SYNC
snake456, I also suggest making an appointment with your dealer. You can have someone in the service department try the phone on a different vehicle as well. Let me know how it goes. mcali6301, Were you able to go to the dealer? Shaay- 34 replies
- mft
- my ford touch
(and 2 more)
mcali6301, I understand, but this isn't the experience I want for you. During your next scheduled maintenance, I recommend mentioning this issue to your dealer. Please keep me posted. Shaay- 34 replies
- mft
- my ford touch
(and 2 more)
Hi snake456, Have you tried any of the suggestions posted by Rebecca? Shaay- 34 replies
- mft
- my ford touch
(and 2 more)
2008 Ford Edge Sync update
FordIVTteam replied to techmerlin's topic in Audio, Backup, Navigation & SYNC
Hi ccatex@gmail.com, I can help with this. Log into your Owner account to check for updates: Owner.Ford.com Once you're in, select the SYNC & HOW TOS tab then select CHECK FOR SOFTWARE UPDATES. You will have the option to download the update to a USB if it is available for self-installation. Shaay -
ambient lighting problem after sync update
FordIVTteam replied to flyers27's topic in Audio, Backup, Navigation & SYNC
drpepper, I responded to your PM. Check it out. Shaay -
Hi drpepper, Do you have a case created for this concern? If not, PM your full name, VIN, best contact number, email address, mileage, and the dealer's information. I will get this escalated to the customer service manager for your region. Shaay -
Red2149, I responded to your post here: http://www.fordedgeforum.com/topic/18357-bluetooth-audio/?p=134153 Check it out. Shaay
Hi Red2149, I don't recommend pulling the fuse without consulting with the dealer. I know you're trying to stay away from the master reset, but it is the best thing to try initially. If you continue to experience issues, I suggest making an appointment with the service department. The instructions for the reset can be found here: http://owner.ford.com/sync-technology/pair-your-phone-sync-myford-touch Please keep me posted. Shaay
Depending on the vehicle warranty start date, the MyFord Touch APIM (Accessory Protocol Interface Module) will be covered under the limited extended warranty. If you're unsure of your vehicle warranty start date, shoot me your VIN in a PM and I'll look it up for you. Rebecca
Hi mcali6301, I'd like to help get to the bottom of this issue. Are you able to try another phone? If not, you have the option to go to the dealer to try one of their phones. Let me know, so we can move forward. factor99, I'm glad everything is going well. Thanks for sharing. Shaay- 34 replies
- mft
- my ford touch
(and 2 more)
Hi mcali6301, You mentioned that these issues are only minor, but I still wanted to provide some basic troubleshooting tips that may be helpful: http://owner.ford.com/how-tos/sync-technology/myford-touch/get-started-with-sync/troubleshooting-tips-for-sync-with-myford-touch.html Let me know if you have any questions after reviewing the link. I'm trained to provide only basic information about MyFord Touch; however, I encourage you to reach out to the dealer for technical questions about how the components are set up: http://owner.ford.com/dealer-locator.html#/ They should be able to provide a little more insight. From what you've described, your MyFord Touch APIM (Accessory Protocol Interface Module) should be covered under the extended warranty for a total of 5 years. Coverage starts on the warranty start date, regardless of mileage. If replacement of the APIM is required, and your vehicle is within the indicated time limitations, your dealership has been authorized to replace it free of charge (parts and labor). Kim
Hi drpepper, That message usually does not indicate an MFT concern, and a master reset will not correct it. Since backup camera concerns are out of my scope, I suggest contacting your dealership so they can diagnose and correct this for you, or Tricia here: http://www.fordedgeforum.com/user/29146-fordservice/ Hope this helps! Rebecca
Navigation update 16777215
FordIVTteam replied to Julien Gauthier's topic in Audio, Backup, Navigation & SYNC
Hey Battiste2, Waldo is on the right track. Is your system working now, or does it still show that you're in Michigan? Also, can you please look at the SD card and provide the version (A4, A5, A6)? Let me know and I'll assist. Shaay -
Hey mcali6301, jmr061 has the right idea. You need a B series SD card. The latest version is B6. You can purchase vailable updates here: www.navigation.com/ford Shaay
Help with Navigation and Destinations app
FordIVTteam replied to trsundstrom's topic in Audio, Backup, Navigation & SYNC
Hi trsundstrom, To get those directions downloaded, you press the VOICE button and summon SYNC SERVICES. Once you have Services connected, you'll want to say DIRECTIONS, and when prompted, say the name of the saved point you just setup. It'll then ask if you want to download it; say YES and once they are downloaded, the route will appear on your navigation screen. Please note, you have to have a subscription to SYNC Services in order to use the SYNC Destinations app. Give it a try and let me know how it goes! Rebecca -
Hi Julien Gauthier, Unfortunately, I don't see a picture attached (it may just be my PC). Where are you getting the file not found message? It sounds like you may be trying to update the navigation portion of MyFord Touch, which gets updated when you perform the SYNC updates. If that's not it, let me know and we'll go from there. Rebecca -
MFT/Sync wont save any changes to settings...?
FordIVTteam replied to wes8398's topic in Audio, Backup, Navigation & SYNC
It's me again! I just want to clarify a few things: I don't have all of the details on what the fix entails, but this is something only your dealership can do. Please check with them before you have anything done to see if there will be a charge for this. MyFord Touch will not allow you to re-install software, but a dealership can re-install updates. The system is designed to see that you have the latest software and not go any further with the update. The limited extended warranty covers the MyFord Touch module (APIM) and software updates; this issue may not be covered under that and it's always best to check with your dealer before having any work performed. Rebecca -
Hi wes8398, Like omar302 stated, your dealership has a fix for this. Please make an appointment with them to diagnose and correct it for you. Let me know how it goes! Rebecca -
Congrats, trsundstrom! Let me know if you have any questions about MyFord Touch, and if you haven't done so already, head over to Owner.Ford.com to create your Owner's account. There's lots of great info about your new Edge on there. Rebecca
HELP with Bluetooth Audio - Music
FordIVTteam replied to AZDiddy's topic in Audio, Backup, Navigation & SYNC
Which SYNC system do you have, AZDiddy? Here's a link to help you determine which one (just in case): http://owner.ford.com/how-tos/sync-technology/all/get-started-with-sync/how-to-identify-your-sync-version.html Fun fact - with all of our systems, you can press the VOICE button on your steering wheel and say BLUETOOTH AUDIO to access that source. Rebecca -
problem with s4 and sync
FordIVTteam replied to chicagojoe's topic in Audio, Backup, Navigation & SYNC
Some phones will do this if you have the lock screen with a passcode setup. If possible, try removing the phone lock while you're connected to SYNC. Rebecca -
Hi jlanha01, Which SYNC system do you have in your Edge? Here's a link to the different systems: http://owner.ford.com/how-tos/sync-technology/all/get-started-with-sync/how-to-identify-your-sync-version.html Once I know which SYNC system you have, I'll send you some troubleshooting steps. Rebecca
You're welcome! The V3.7 software is primarily designed to support new features not available on model years prior to 2014 as well as features in markets outside North America. In the spirit of Globalization, we have included North American owners of 2014 MY and newer vehicles should they choose to update their system. Rebecca
This link should be helpful, dynamix1: http://owner.ford.com/how-tos/sync-technology/sync/get-started-with-sync/troubleshooting-tips-for-sync-and-sync-with-myford.html?sync=sync If you have any questions about the troubleshooting tips listed, don't hesitate to ask. Kim
