lpgao
Everything posted by lpgao
2010-2012 Flex Rims on 2011 Edge, will they fit?
lpgao replied to Spaceman Spiff's topic in Wheels & Tires
I am in Canada too. I like to know more about how you did. Can I PM you? -
my 2011 AWD limited front passenger side wheel hit by car at parking lot, and it got little bit damage. Should I replace the weele or it is still safe to drive? I found tire size is 20", but I checked online the rim seems is 18", so I am confesed what is its size? I checkd with dearler for its price and it is quite expensive, so where I can get cheaper one?
Anybody know how to find your edge powertrain class? I checked lable on my 2011 edge for GVWR, it shows two different numbers for powertrain class I and class II, but how do I know my edge is what powertrain class? How much trailer I can pull with 2011 edge AWD limited?
I found it is difficult to plug power on my 2011 limited. the cord is too short to connect go undernease. If go hood cover, it can not be closed.
Headlights in my 2013 EDGE
lpgao replied to The Ripper's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Dingo:what do you mean"wish you didn't live in Canada"? Is it illegal for use HID in Canada?- 79 replies
- Headlights
- Crappy
(and 2 more)
OEM HID part Information
lpgao replied to ovcrash's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks lot 12 Edge. Electrical circuit drawing is really amazing. It is clear how wires to route. But how do you terminate wires into fuse box and same time maintain fuse box untuched. how you fasten relays and moving halogen bulb wires from head light fixtures to relays? -
most time driving around 100km/hr on highway. Mine is 2011 limited, 3.5 V6 AWD. It does not have ecoboost. It costs more gas than the 2001 Chev venture minivan I had for last 10 years. Why 10 years new vehicle need more gas even it has lot new tech?
I had my ford touch connected to internet via wifi, but what I can do on MFT after it is connected to internet? There is no internet browser in MFT,and no any other application use internet connection, so what for to use wifi?
HID kit upgrade tutorials
lpgao replied to lpgao's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks again for your kind reply. It should be ok if use ohm's law to calculate the amp from those loads on circuits. But what reason for Edge desiner to have seperate 20 amp circuits for HID lamps? -
I found my 2011 edge limited is gas comsupmtion lot: on high way, 12L/100km which is almost 50% (8L/100km)more than factory sepc. Why? anything to improve this?
I am really interested in your wiring diagram from Ford. Can you say in deatails how do you wired to 20 amp circuit inside fuse box specific for HID lamps, not ones 10 amp for halogen bulbs? -
Thanks lot Candurin. Great job and wonderful video. It is very helpful. But I have question: from your video I saw you use wires are for low beam headlamps, which are protected by two 10 amp fuses inside passenger compartment fuse panel(#16 &17). But there are another two 20 amp fuses inside power distribution box, #57 & 78, identified for HID headlamps,suppose to be used for HID lamps, so what do you think those circuits on those fuses?should we use them? -
Thanks again for all the responses. I have done for bulb change, which is halogen bulb. It is working. But I am not sure the bulb and the cover are secure there because I did not feel I turn them lot. I hope they will not fall out because of loose. One thing I noticed is there is humudity inside light lense. So how to dry it? and keep it dry inside?
low/high beam bulb on 2011 Edge
Thanks for your reply me.
