lpgao
Everything posted by lpgao
head lamp
lpgao replied to lpgao's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks l;ot. -
engine coolant tempreture gauge reading abnormal
lpgao replied to lpgao's topic in Interior, A.C., Heat, Interior Trim
Many thanks for your kindly reply. I appreciate. I will check as you said. -
head lamp
many thanks for guys kindky reply. But I am mot sure what video shows is on 2011 Ddge? -
I bought 9012 bright white light for my 2011 edge head light, this is right one? how to replace old one?
Thanks lot for your kind reply. I will check there and let you know what I see.
I dont know my Ford Edge lock code because I bought used. So can I set up new code or restore it to a manufactory default one?
Many thanks for your information. I did search glove box and nothing. I bought used one in 2013 and I dont think I can find it. I may go dealer to seek help.
Thanks again for guys replies. But the numbers I got from fuse panel not working for my door lock so what I can do?
Thanks for your kind reply. I tried the numbers I got from fuse panel cover and nothing happen. I also dont think the code will have 2,1 or 3,4 combination because press same buttons twice not making any sense.
2015. 5 digit security code location
lpgao replied to Cheito5459's topic in Alarms, Keyless Entry, Locks & Remote Start
My Edge is 2011 model and tried your way and found nothing displayed. Can you explain more specific how to do this procedure? -
Thanks lot for your reply. If the numbers I see on cover are indeed the keypad codes how can I verify them?
I found those numbers are imprinted or engraved on panle cover so that means the panel cover is made specific to each Edge? -
Thanks for you guys quick replies. But if the code is 3,4 or 2,1 how should I enter those codes for example?
1, After reading posting here I got fuse panle cover and see a set 5 digit numbers but I am not sure if they are the factory set 5 digit code? 2, each button on key pad has two numbers on them so if I have code 1,2,.....how can I enter those two numbers? Press first button twice?
yes it is but it is always off. So my question is can drive choose fan only from outside fress air not using climate control?
It is 2011 limited. But when driver can not choose to blow ioutside air only?
Thanks Candurin for your promptly reply. If as you said some one can get in vehicle pretty easy it is very scary. Anything to make safer?
Thanks for normcloutier kind reply. But how to select "VENT"? I dont see this option. I really need do this because now days outside air is cool but inside hot and there is no need AC. However blow air not is as cool as outside while lower down window. If we can not use outside fresh cool air I will say the AC system design is stupid waste energy.
In a few time I fell some one might get in my 2011 Limited while it was parking on street. I am wondering anyone could open the door or liftgate to get in vehicle without keyless remote and alarm not going off?
Many thanks Waldo for your great information. I never did rotation on my tires as I have my Edge just 2.5 years, and it has total 160k KM. Now I put 4 new Goodyear tires. I attached photo here to show everybody the difference between fron and rear tires. Front one is done, but rear one is still prety good.
Hi Guys, can someone tell me how to turn on outside air only without heating or AC working? Sometimes I could have air direct from outside to my face, but many times heater or AC on. But I just need fan on to bring outside air only.
Thanks for all of your inputs. I like to report my story here to share with you. I bought 4 good year tires which is cheapest brand out there. But when I got car shop the mechanic said first: good year tire is not good, cheap but not last long. Then he told me rear pair are still good so I should just buy a set new for front. I looked carefully and found the quality of good year is not as good as Pirelli on my edge. Secondly, I found the front two almost worn out but the rear set is nearly like new. That means front tires working hard? New ones should go front. BTW, I brought rear set back to home and save for next time change I just buy two new Pirelli.
Many thanks to omar302 for your great information.
Thanks lot to enigma-2 for your kind reply. I have another question is do I need upgrade my software before buy new version map card? Or the new version map will work on existing system?
