lpgao
About lpgao
1,482 profile views
lpgao's Achievements
  1. Many thanks for your kindly reply. I appreciate. I will check as you said.
  2. many thanks for guys kindky reply. But I am mot sure what video shows is on 2011 Ddge?
  3. I bought 9012 bright white light for my 2011 edge head light, this is right one? how to replace old one?
  4. ny 2011 Edge limited has problem on engine coolant tempreture gauge reading, it is not showing normal tempretrure at middle.rerratic reading. why this hapen? how to fixe this?
  5. Thanks lot for your kind reply. I will check there and let you know what I see.
  6. I dont know my Ford Edge lock code because I bought used. So can I set up new code or restore it to a manufactory default one?
  7. Many thanks for your information. I did search glove box and nothing. I bought used one in 2013 and I dont think I can find it. I may go dealer to seek help.
  8. Thanks again for guys replies. But the numbers I got from fuse panel not working for my door lock so what I can do?
  9. Thanks for your kind reply. I tried the numbers I got from fuse panel cover and nothing happen. I also dont think the code will have 2,1 or 3,4 combination because press same buttons twice not making any sense.
  10. My Edge is 2011 model and tried your way and found nothing displayed. Can you explain more specific how to do this procedure?
  11. Thanks lot for your reply. If the numbers I see on cover are indeed the keypad codes how can I verify them?
  12. I found those numbers are imprinted or engraved on panle cover so that means the panel cover is made specific to each Edge?
  13. Thanks for you guys quick replies. But if the code is 3,4 or 2,1 how should I enter those codes for example?
  14. 1, After reading posting here I got fuse panle cover and see a set 5 digit numbers but I am not sure if they are the factory set 5 digit code? 2, each button on key pad has two numbers on them so if I have code 1,2,.....how can I enter those two numbers? Press first button twice?
