zzbsb
About zzbsb
zzbsb's Achievements
  1. Today I checked my tires pressure and one of them is at 31.5 psi. But the car is not giving TPMS warning. Anyone knows at what pressure level the TPMS will give warning? Thanks.
  2. To give everyone an update: By hard reset the MFT(disconnect battery negative end) the problem is fixed. I disconnected the cable for about couple of hours.
  3. With the weather getting cold, I noticed that even I set the air to distribute through both instrument panel and floor vents, my knees don't feel any warm air and feel cold. I did a quick look but couldn't figure out where the floor vents are. Anyone knows where they are? Thanks.
  4. NO, mine has nothing to do with the settings. I'm in Canada and the city live in has no toll roads. The GPS was perfect until I switched to winter tires. I'll disconnect the negative of the battery when I get time and see how it goes.
  5. Thanks. I'll give it a try to see if it helps. I down sized the snow tires, went with 17" ones. I'm surprised that not many owners talk about this problem here. I guess most of you don't change tires?
  6. Bump up an old thread. My 2013 Edge started giving me this problem too. The GPS would say I've arrived destination while I was no where near my destination. Sometimes you can see the map go crazy like a web and it keeps telling you make crazy turns while there are no such turns. It told me to make a U-turn once on the high way. The system was perfect for about 6 month, just started this problem couple of weeks ago. Anyone knows if there's a fix? Thanks. My wife said this started after I put the snow tires on. I read in another thread that an owner said the dealer was associating this problem with snow tires too so not sure what snow tires would affect GPS. Jay.
  7. Hi Norm, you said you could have dealer to disable the DRL once you have the EDGE2 working. isn't it easier than connecting wires to the rear turn signal? Keep us posted if there's any update. I'm thinking of getting the HID and EDGE2 next year for my 2013 Edge SEL. Jay
