manontheedge
Everything posted by manontheedge
  1. Hmmm... It did nor draw the table correctly... Lets try again... 2008 Alignment Specifications Item LH RH Total/Split Front Camber -0.50° ± -0.75° -0.50° ± -0.75° 0° ± 0.75°a Caster 4.4° ± 0.75° 4.4° ± 0.75° 0° ± 0.75°b Toe - - 0.10° ± 0.20° Rear Camber -0.40° ± 0.75° -0.40° ± 0.75° 0° ± 0.75° Thrust angle - - 0° ± 0.30° Toe +0.05° ± -0.20° +0.05° ± -0.20° 0.10° ± 0.20° for 2010 Alignment Specifications Item LH RH Total/Split Front Camber -0.1° ± -0.75° -0.6° ± -0.75° 0.5° ± 0.75°a Caster 4.3° ± 0.75° 4.5° ± 0.75° 0° ± 0.75°b Toe - - 0.10° ± 0.20° Rear Camber -0.45° ± 0.75° -0.45° ± 0.75° 0° ± 0.75° Thrust angle - - 0° ± 0.50° Toe +0.05° ± -0.20° +0.05° ± -0.20° 0.10° ± 0.20°
  2. Found this on another site... http://www.justanswer.com/ford/2ht85-ford-edge-sel-awd-sluggish-wheels-a-problem-power-steering.html 2008 Alignment Specifications Item LH RH Total/Split Front Camber -0.50° ± -0.75° -0.50° ± -0.75° 0° ± 0.75°a Caster 4.4° ± 0.75° 4.4° ± 0.75° 0° ± 0.75°b Toe - - 0.10° ± 0.20° Rear Camber -0.40° ± 0.75° -0.40° ± 0.75° 0° ± 0.75° Thrust angle - - 0° ± 0.30° Toe +0.05° ± -0.20° +0.05° ± -0.20° 0.10° ± 0.20° for 2010 Alignment Specifications Item LH RH Total/Split Front Camber -0.1° ± -0.75° -0.6° ± -0.75° 0.5° ± 0.75°a Caster 4.3° ± 0.75° 4.5° ± 0.75° 0° ± 0.75°b Toe - - 0.10° ± 0.20° Rear Camber -0.45° ± 0.75° -0.45° ± 0.75° 0° ± 0.75° Thrust angle - - 0° ± 0.50° Toe +0.05° ± -0.20° +0.05° ± -0.20° 0.10° ± 0.20°
