Everything posted by carsick30
2012 Edge Sport, My impressions not very good so far.
carsick30 replied to Diesel350's topic in Owner Impressions
Oh good, I'm not the only one. See my post "2012 Sport And Already Problems" to join the problem club. -
All I know is that even though everyone says get a harness I am running 55w/6000 with just plug and play without any issues for a couple of months now.
Ordered and installed 6,000/55w kit. Wow, the difference is so drastic over OEM I might actually be able to see through solid objects with these. Surprisingly not getting high-beamed by oncoming traffic unless they are partially incapacitated by the insane brightness and become too disoriented to reach for the high beams. The problem I have is that the ballasts do not fit into the spaces designed for the OEM ballasts. I guess that's what you would expect from aftermarket, but just too bad.
2012 Sport speaker blown?
carsick30 replied to carsick30's topic in Audio, Backup, Navigation & SYNC
Makes sense, but the mystery to me is the fact that I'm only getting this occasional distortion when listening to radio, not USB/CD. And no, it's not radio station static because it happens on every channel. It;s also not antenna reception because the static would then come from all sides, but this one seems to be more in the back. -
carsick30 replied to omar302's topic in Recalls, TSBs & Warranty
Clearly Im being sarcastic. If you are not sure why Im expressing my displeasure, check my thread under Owner Impressions section. What I mean is that the letter basically says this will not cause immediate break failure, but to keep waiting for the spongy feel or for hissing. I can do that or I can talk to friends who have no issues with their SUVs and dont have to wait for the day when this may or may not happen. I find it frustraing to constantly have to wonder what the next problem may be. -
updated
got letter. adding to the ever growing list of either current or future problems. unbeleivable. i love how it says the tear may not kill you right away, but i just can't help but picture having to really use the braking power that one time when it's needed only to discover that the problem has been there long enough for me to take out myself and another car on the road. basically, every time i go in for service i might as well have them look at this to make sure. -
When listening to radio, but not CD or iPod for some reason, seem to be periodically hearing what sounds like one of the back speakers being blown. Anyone else having this problem?
looks good. so, +1 vote for having a backup ballast handy. i'm assuming you didn't have to use their Error Eliminators either with your setup?
i figured as much. i saw posts that for morimotos you should get canbus harness, which is their version of DDM Error Eliminators i think. So, i assumed you have to have that with all kits. i agree that there is no problem with putting HID into halogen projectors as long as the kit is not complete garbage. I've done it as far back as I remember on all cars I've had without melting anything or killing oncoming innocent drivers by blinding them.
Are DDM Error Eliminators really needed on a 2011+ Edge? Anyone run without them and not gotten code flashing on dash?
PASSANGER SEAT CREAKING NOISE
carsick30 replied to sanche's topic in Interior, A.C., Heat, Interior Trim
thanks for posting and for the .pdf! i thought i was losing it when i would hear this sporadically, but could never understand where it was coming from. -
Ah, got it. i can only imagine what that would cost to fix if out of warranty... Which then brings up a follow-up question: since the waterproff cap covers have toget drilled for the install, and HIDs are no longer OEM parts, can Ford say they will not cover surrounding and affiliated components under warranty (not the bulb/ballast onbviously, but other pieces) because of excessive heat/electrical load/etc.?
so bad ballasts potentially... what about the high beams? it uses same bulb as low beams? i guess i just can't register how it would not need a separate bulb for that.
So, based on some discussions throughout here i saw a numbmer of poeople running DDM Tuning HID setup because of cost savings over that other "M-something-rather". http://www.ddmtuning.com/Products/DDM-HID-Kit-Slim-Ballast-35W-or-55W $60 vs $150 certainly makes sense to me. Online you can find HID setups for hundreds more than that, but it doesn't mean they are that much better. Here is what I'm interested in: 1. I know a bunch of people said they have been running DDM without issues for at least a couple of years. But, I also saw owners say they have had issues with DDM without getting into specifics. I would like to hear what those issues are with DDM. Pros: cost and reliability (?). Cons: ? 2. Can someone clarify again please the low vs high-beam with these? The kit does not specify that it is low and high beam. Does that mean the way the Edge lights are built, the switch uses the same bulb but angles it higher for high beams? This is porbably a dumb question, but I just don't get it even after seeing a post on here about some magnetic swtich or something like that.
Updated for another issue.
That would make sense to worry about normally, but the iPod was working with SYNC fine less than 2 weeks ago and for months leading up to the sudden problem. There have been no updates done to SYNC or iPod software when SYNC stopped reading any USB connection. It just happened out of the blue.
2011+ Sync/MyTouch "Master Reset" walk-through?
Thanks for this. I did see that Youtube, but I wanted to make sure that was not going to mess up anything else since the power to all fuses it being pulled. I guess what I don't get is why this, or individual fuse pull, would work if taking down the power to the entire car did not. I guess we'll have to see. I'll also try to post pics if any of this works. -
Makes sense. Actually I did notice that, after I pulled the battery negative cable, the personal settings did stay. But, since that still did not show my USB connection to iPod like it used to, I'll do the power to the fusebox next, then fuse, them master reset, then drive the car through the front window of the dealership. -
Sorry if I missed this in here some place. Is there an actual step-by-step walk through, hopefully with pics, of how to do a "master reset" of the Sync? Need it to make the thing start reading my USB connected iPod again. Online there are a few different suggestions: 1. Pull negative cable from battery - didn't work. 2. Pull fuse - which box is that in and what exactly does it look like? 3. Pull power to fuse box instead of pulling fuse - anyone had luck with this? Seems like the least PIA process, but want to make sure that doesn''t screw up other things. Thanks!
Ford Edge vs Subaru Forester XT
carsick30 replied to Munchie's topic in Competing Crossovers & Vehicles
Beleive me when I tell you that Tribeca's "3rd row" seat is the biggest crock of, well you know. All those clowns did was reduce trunk space, push the back seats up and crammed in 3rd row for what must be intended for infants and "little people" to use a pc term. So, the leg room for regular back seats is completely shot just so that they can say the have the 3rd row feature. This is one of the reasons I say comfort in Ford is significantly better. You cannot compare Tribeca to Highlander. Sure, we are not talking the need to do burnouts and take on 1/4 miles in drag races as far as performance goes. But, you do want to be able to take off from a red light better or merge onto a highway faster or move through traffic more effectively. You also want to handle windy roads with more confidence. Ford SUVs handle like marshmallows in corners and have heavier feel than Subaru. You will have fewer perfomrance and technology issues with Subaru. Ford has the advantage of not needing 93 octane in any of their SUVs while Subaru has to have 91+ in anything with a turbo. It comes down to what is more important to you: performance, handling, and reliability vs comfort, features, gas mileage/cost. -
updated the running tally of nonsense on original post.
For fair comparison Forester should be up against Escape. Edge is in Tribeca class. Having owned all of these, Edge is better on comfort and features, but Subaru takes performance. -
2015 Ford Edge Concept Introduced
carsick30 replied to robertlane's topic in Articles, News & Reviews
Pretty sure I hate the "fog light" openings. Starting to look likea Kia or a Honda. I think I see design hints of Evoque around headlights. I'm surprised they didn't go with the Aston grill look like the sedan lineup. I thought there was some speculation and pics going around that they may go that route. That looked better than this I think. Must wait for Sport version to see what happens. By the way, any chance they have an improved PTU seal concept for this as well considering everyone's leaks at least once? Maybe also a less frustrating SYNC system? -
I'm "psyched" to see all this and know what I have to look forward to on top of the bs I have already dealt with. See my experience: http://www.fordedgeforum.com/topic/13634-2012-sport-and-already-problems/.
