ccutaia1
Everything posted by ccutaia1
  1. Here is what I have been looking for. Seem the Explorer has the same setup:
  2. I just need removal instructions on what looks like a 16-18 Edge with lane keep option.
  3. It is not as easy as just pulling it off. The 1st time I did it I pulled the whole setup off the window camera and all. There is a sequence to removing it.
  4. Thanks for the illustration but I need to know how it unclips, removes from the hardware holding the shroud in place.
  5. It is not the same shroud as a 2018 Edge, the camera area, lower shroud needs to come off and it is not the same as the 2020 Edge or the one in the Raptor video.
  6. Hi, I want to put in a mirror power tap for my 2018 Edge and need to remove the adaptive cruise/lane keep camera shroud cover. Can someone show me the way????
  7. This ad is for 4, 20 inch OEM polished aluminum wheels off of a Ford Edge Titanium. These are "NEW" car take off's Less than 100 miles on them. WHEELS ONLY & lug nuts only, 2015 thru 2020. $549 or BO plus shipping, located in zip code 37871.
  8. I have a tailgate where the Edge and Titanium emblems are 3/8" off plain. The Ford dealer said they are not supposed to be on the same plain, REALLY since when!!!!! Does anyone know of a spec for their location and relationship to each other???
  9. $45K for the car, it's a big deal, you don't see that stuff in other brands.
  10. On my 2013 I could not see it when it was new, but when I traded it in on a 2018 Edge it was very prominent. You could see the complete outline of the airbag.
  11. Can anyone else see the dash passenger side airbag outline in their dash? Mine is pretty prominent in the sun.
  12. My Titanium has the upgraded leather seating with cooling & heating. My questions what is leather on the seats and what is not???? I don't know for sure what they mean by term leather-trimmed, what is leather and what is vinyl? Also, I assume everything else in the interior other than the steering wheel and seat trim is vinyl for cleaning purposes.
  13. The video on YouTube is spot on. The top piece has to come off first, push forward pull down. The bottom piece does not pull straight down if you do you may wind up pulling down the whole mirror assembly as I did. You need to take the ears left and right on the top of the bottom piece once the top piece is removed and push them out to release the tabs shown in the video then pull down. Alls well that ends well, everything is back together and working with no damage.
  14. I tried to remove the camera cover and it is not coming off as you had said it would, are you sure?
  15. Hi, I am trying to get to the mirror wiring to connect my radar detector but need to understand how schrod covering the lane keeping camera comes off so I don't break it.
  16. OK, so if I have the mirror and camera which I do, the wire color/connection is the same as the video?
  17. $600.00, 4 Hankook VENTUS S1 NOBLE2 - 245/50R20 Tires For Sale, New Car takeoff. These tires have 386 miles on them when taken off the car. Compare at $840.00 or more for the set. Located in Knoxville TN.
  18. $725 This ad is for 4, 20 inch OEM polished aluminum wheels off of a new 2018 Ford Edge Titanium. These are "NEW" car take off's. 20" x 8", 5x108 bolt pattern. Wheels are located in Knoxville TN
  19. I just swapped my 20's with 18's, rides like a dream, quiet, and still handles nice. The only thing I am not sure about is do I need to have the dealer change the CPU to reflect the change in tire/rim size? The '20s seemed to be about an inch taller.
  20. Hi, On my new 2018 Edge Titanium due to the horrible ride of the 20" rims with the 245/50R20 tires, I went to 18" rims with the stock size tires 245/60R18 tires. My question is it looks like the 20-inch setup was a little taller, do I need to have the dealer adjust the tire size in the CPU of the car? Please let me know.
  21. Dropped down to 30 PSI, still rides like a buckboard.
  22. Hi, I want to tap into my dimming rear view mirror and connect my radar detector. 1st how does the plastic remove from the mirror so I can get to the connections, 2nd what color wires can I tap into for power and ground?
