geant90
Everything posted by geant90
  1. What led light strips to you buy and from where? Link if you can please. thanks for the pictures.
  2. Hey FEForums, So I just bought a JL XD300/1 Amplifier for the edge and I'm planning on buying the JL stealthbox or OEM sub-woofer box that is included with the upgraded audio. It will be my first audio Install so my question is: Are all the wires you need for the amp already in the designated AMP location? (12v,Remote, Audio signal) Also should I try to hunt down the OEM sub box or buy the expensive JL box? I don't need "thumping" base just want the lower range present!
  3. Hey fordedgeforum, I've recently installed Halo and LED Headlights on my dad’s 2008 Ford Edge. Everything is working fine I just have a question regarding the signal light wiring. I obviously determined black was ground so I used that with my test light and the middle worked as positive. When searching information on headlights as I was wondering why they have three wires I came to the conclusion that: Signal Light haves Three Wires: 1. running 2. signal 3. ground What is the difference between running and signal and if I wired my led and halos to the signal it would flash with the signal light as well? I’m really concern because I have the 1st and 2nd wire used as the circuit for the Halo and LED which if as the list shows: it is the signal wire.
