BuddyB1959
About BuddyB1959
BuddyB1959's Achievements
  1. I've got aftermarket pads already, still have the problem. Hard to believe the rotors since it only happens at slow speeds, slowing down from higway speeds they don't squeak.
  2. Does sound a little like the sound clip, maybe a little higher pitched. Also, to the other post, I would run away from that dealer, brakes are no supposed to squeak, can't be normal
  3. My wife has a 2008 MKX AWD and we are having a continuing problem with squeaking brakes. The squeak started when only braking in reverse, but it now does it in both directions. The squeak only happens at slow speed (parking lot speeds) and it dosen;t matter if the brakes are hot or cold. Things I have done so far New pads on both front and rear All rotors turned Brake fluid flushed and changed What am I missing? Ideas Thanks Buddy
