NickSport11
About NickSport11
NickSport11's Achievements
It does not work at all anymore... All connections are secure and I replaced the element (have to change the entire cushion/pad as they are 1 unit in the 2011+) This new system is almost impossible to test with a standard volt meter from what I can find anyway. The working side was getting 3.3v and the non working side was 2.8v. My next best guess is the module under the passenger seat. Any other thoughts. If not I will be putting in a new heated set module. Hopefully it won't be a waste.
evh, I have MFT so my "switch" in my touch screen. It stays illuminated so I'm not sure. I've been doing some research and there is a DCSM "Dual climate controlled seat module" under the passenger seat. I would expect both seats to be not working if this was the case, but this is the only thing I au currently think of.
Thanks for the idea. I hope it's not that. My buddy runs a shop I'll check to see if he knows of anything else as well.
Cap is tight. I checked this when I noticed low coolant.
I'm from MN the heat has been on for the past 4 months... I don't notice it until I step out of the vehicle. Usually in my garage because there is no wind.
Hi everyone, I have a 2011 sport 69k mikes and I notice when parking in my garage after driving for a while that I smells slightly like coolant (the sweet smell) I have not noticed any puddles, but the coolant is slightly below the cool mark when hot in the tank. Are there any known issues? Also has anyone on here had a similar problem Thanks for your help Nick
Has anyone done this on the edge yet and posted about it? I like the sleek look and like all rear wipers they are pointless. What have you used to fill the hole? I plan to do this soon if anyone has ideas Thanks -Nick
I installed DDM HIDs a few weeks ago and have been happy, but I am haing an issue with the beam pattern. The lower left from each headlight has a shadow. From what I've read it's from the return wire. Well my question is how do I place them in the housing to avoid this? There is only one way they can go in. There are 3 tabs not evenly spaced. If you try to turn the light it does not fit correctly. I bought 9006 bulbs. Should I have gotten something different? Someone please draw a pic. Haha, but it would help. Please help....it's getting dark fast now:( -Nick
Thanks for the replies. Still looking for a solution. Joehio my vehicle is out of warranty and I like to fix things on my own as much as possible. That's why I'm a member of the forum. I like to ask questions and have the community help resolve issues that my vehicle may be having. wwwperfa_znow all of my pre research leads me to believe the only vehicles with a seat filter are if the seats have ventilation (a/c). I've had had many cars with heated seats and not one had a filter. But thanks for the idea. So I drove the vehicle tonight...39 degrees out, and the seat does heat but seems very weak especially when compared to the passenger seat. I believe the element is still good. Is there a thermostat or something that controls the seat temp that I can check out? -Nick
Hi, Well it's getting cold here in MN:( time for the heated seats. When turning on the drivers seat today it did not work. The passenger seat is fine. I just checked for a possible fuse... Not that. Everything else related to the seat works and it does not appear to have a separate fuse for the heated seat. I'm guessing it's the element. Has anyone replaced this? Is it difficult. Any other suggestions would be great -Nick
Help with seat rocking 2011 Edge Sport
NickSport11 replied to NickSport11's topic in Interior, A.C., Heat, Interior Trim
Looks like the fix is over $900... Are you kidding me Ford! Has anyone had any luck tightening anything to help fix or reduce the issue? -
Hi Everyone, I recently bought a 2011 Edge Sport, and have noticed lately that the seat rocks under acceleration and stopping. I have done a search and have come up with very little on the issue. A couple owners had this replaced under warranty. I am now out of warranty so my question is what causes this and how can I fix this on my own? What parts are needed etc. Thank you -Nick
Thanks. Was at the dealer today they wanted 620 plus tax to install the series 200. Crazy! I found online for like 290 and it looks pretty easy to install. My buddy owns a shop and can turn on the remote start for me. My local dealer is pretty expensive. They tried to charge me $45 for the MFT update. I kindly showed them it is under the added MFT warranty. Apparently they didn't get the memo. -Nick
