fezzman
About fezzman
fezzman's Achievements
  1. Hello all. The AC only trickles out of the dash vents. The air blows out of the defrost vents and at the feet appropriately. I removed the glove compartment door and watched as the flap moves into position as I switched back and forth from defrost. What else could be causing this issue? Since the fan seems to blow variable speeds out of defrost, a relay or fuse isn't the issue. Right? Could this be a vacuum hose issue? I have searched and can't seem to find a diagram of the hoses used to control the vents. It is getting mighty hot out. Thanks for any tips.
