Clyde Epperson
Facebook Member
About Clyde Epperson
2,733 profile views
Clyde Epperson's Achievements
  1. Recommendations for what struts to put on. The cold temps of Denver are starting to hurt my head as the lift gate falls!
  2. Manual climate control, Drivers side has no heat and little air volume compared to passengers side that is blowing hot air with lots of volume. Putting recirculating button on helps with the cold air making it slightly warm. I’ve had other fords with blend door issues so is this possibly the same problem. Is it a diy job? Thanks Clyde
  3. Does any one have any how to replace video's or instructions?
  4. Car was running at 3000 rpm turned off and it started right back up and was at normal rpm. Any ideas?
  5. The traction control light is back on after I reset it. Any ideas?
  6. Yes followed instructions. the brake pushes the switch back in but not enough. Any idea it just a fine little amount.
  7. No work at wheels and no need to bleed brakes. I just reset light by removing negative terminal, light went out so well see. Now I just have brake light issue.
  8. Brake lights are staying on? And traction control light came on? Please help Thank you
  9. Anybody have instructions on replacing the forward catalytic converter? Thank you
  10. I thought that was a different code.
  11. I haven't pulled codes in a while to make sure. What is a good catalytic converter brandto get?
  12. It was 2014 when I had the coil/pcm go out and had those fixed. At that time I didn't need and inspection.
