az_edge
Everything posted by az_edge
First, I would get an amp with higher wattage. Second, I believe you could just use the existing wiring since that xd300/1 has speaker level inputs.
My 60 portion of the back seat won't un-latch anymore. If I press the button in the cargo area I can hear the mechanism but nothing happens. If I pull up on the manual lever next to the seat nothing happens. There is normal tension on the lever, but it doesn't release the seat. Anyone else experience this? Thoughts?
Yeah, it's pretty amazing how large that area is behind the panel. The Stealthbox is a generous size for sure! I bet they could've made the sub 12" if they wanted.
The trouble with Sirus is that the audio quality is a joke. It sounds like streaming music with a 56k modem.
*Update* Ok, I was kinda happy with my stealthbox and jl amp. But I wasn't convinced it was all worth it. I changed my high-pass settings to about 90 and the low-pass settings to about 95. That's better. Then I remembered I hadn't setup my lc7i bass control and accubass settings. In fact, they were turned all the way down! So I setup the lc7i bass settings. I also added the remote control knob for the jl amp ( a must have IMHO ). Then I re-configured the output signal on the jl sub amp to 31.6 volts. Bingo! Bass is awesome! My system sounds gorgeous! I love the remote knob so I can adjust the sub output on the fly, it's great! The Stealthbox and jx500/1d rocks!
Ok I tuned my sub amp with a multimeter. The book says 31.6v but the guy at jl audio said to use 29.0v to be safe. So I'm at 29.0v. I'm still playing with my lc7i accubass settings but so far so good. I also have the crossover on both amps set to 80. The stealthbox is pretty powerful. Yet it's not very noticeable outside the vehicle, perfect. I have no idea how you guys with multiple 12" subs do it. I must be getting old, ugh. The system sounds awesome. The stealthbox doesn't make a huge difference but it compliments the system quite nicely. The lows are great. I think I need to order the sub amp remote knob so I can adjust the volume of the sub when I want. I think I just need to adjust the sub volume level to match the 4 channel amp a little better as something seems a bit off with certain songs.
OK, the amp is all hooked up. I installed the amp in front of the spare tire on top of a foam square that I bought; worked like a charm. I'm not sure that I have everything adjusted properly. I've got the Input Sensitivity and Bass Boost turned all the way down for the break-in period. I switched my 4-Channel amp to High Pass and set both amp's crossover settings to 80. I'm not sure what to think so far..... I'm sure I need to get things broken in and adjusted properly before rendering a fair opinion.
No worries. Yes, I saw the 10TW3 enclosure but I wasn't so sure about the fit.
I don't think there is any room behind there. . Hmmmm...
I don't have the foam. I've got the plastic storage trays. I'd prefer not to cut them.
So the amp will not fit perfectly under the rear seat. When I fold down the seat it won't fold completely all the way with the amp under there, bummer. So I was thinking of installing it on the driver sidewall next to the lift gate motor. But, it looks like a real pain to take all that apart to get behind there and I wouldn't mind having access to the amp to make adjustments when needed. Now I'm thinking of setting it in front of the spare tire on top of that that metal brace thing. Maybe I could make a piece of foam to fit over that large metal thing and have the amp cradled on top of the foam. Thoughts?
The Stealthbox is 9 inches deep.
What do you mean?
I've got it. I'll install it this weekend.
I didn't have a speaker grill to begin with, just the storage box. I had to modify the opening after removing the storage box. You can see how I modified the opening in the 5th pic. I used a dremel tool to remove the storage box and to cut the opening to make it larger. I gave it the maximum opening and kept the sub centered with the opening.
I have completed the install of the stealthbox. I still have to install the JX 500/1D 500W Amp. The install took a while since I took my time and did it to perfection. The install is not too bad, you just need to clear wires so the box can fit correctly. Measureing, cutting, and drilling the Speaker Grill is the hardest part. Here are the pics......
Thanks Prinzll, no dice. Under the rear set might work...
Ok the amp is in. But....the stealthbox was missing a large bracket. So I called up Crutchfield and JL Audio and they are overnighting the bracket. Also, the instructions that came with the Stealthbox are a joke. They must be for an older version of the box. Thankfully, I found the updated directions online. Jeez, can't it ever just be easy....... Now I just have to figure out where to install the amp. I already have my 4channel Alpine PDX-F4 in the side panel next to the sub.
Well, my stealthbox was delivered today. The sub and enclosure looks great. Tomorrow the JL Audio JX 500/1D 500W Amp will be delivered. I'll keep anyone interested up to date on the install and the outcome of adding this thing to my Edge. Wish me luck.
Subwoofer part number (not even Ford can tell me)
az_edge replied to az_edge's topic in Audio, Backup, Navigation & SYNC
No, why? -
I have changed my mind and I'm gonna do the stealthbox -
Those who added a stock sub enclosure....
do you guys think the stealthbox is worth the difference in sound quality? -
what did you end up doing rocket? -
this is when getting a stealthbox makes sense
