perrytime
Everything posted by perrytime
I think people go over board with " The best tires always go on the rear, because it's easier to recover from understeer than oversteer." think about it, 2 new tires on rear, since they wear less than fronts, you will never rotate your tires to keep best on rear, once 2 fronts wear out, 2 new ones on rear and again, no more rotations. If the rears are say 50% of life, i would keep them there and put new ones on front.
just a quick update, the poor mpg on highway returned and long term fuel trims rose, 20 at idle compared to 15 before. I observed on cold start the fuel pressure was several hundred pounds higher than when hot and still the LTFT was still quit positive, so i doubt fuel pressure is my root cause. Took car to dealer with my documented issues, high long term fuel trim, poor MPG at 70, and how the injector cleaner temporarily helped. Much to my disappointment, the starting service adviser left and the the replacement knew nothing, the technician report showed he recorded mpg at around town speeds, didn't address my LTFT concerns, and declared nothing is wrong with car. Disgusted. I just got my follow up survey form, will let them hear it. I have since done another dose of cleaner, this time ran a few miles with cleaner added to near empty tank, long LTFT dropped to 5 at idle, and MPG improved. Maybe once the issue returns, I will try the other Dealer with specific discussion about last visit to dealer.
thanks again for the help, the new O2 sensor was installed a week before I added the sea foam, that tank has been used up. I have 45,000 miles, a little room before emissions warranty is up. no miss fires. I will keep watching and see what develops, i think finding out if 280lbs of fuel pressure at idle is okay or not is important. And seeing O2 sensor is important, 4 different free apps and my OBD fusion can't see it, maybe torque pro could. my OBD fusion is not apple, running on android tablet. the MAP sensor does move, maybe I will pull it out and use a vacuum pump hooked to it and see if matches scan tool. STFT is near always near 0 at idle when LTFT is 15. SInce vehicle seems to running fine now, good mpg on highway, not sure how important to solve this idle LTFT issue.
you really got my curiosity up, how does watching the O2 sensor help find leaking injector? Since the LTFT is positive 15, doesn't that mean engine is lean and wouldn't a leaking injector create rich condition? thanks
thanks for help, I had the recall for fuel damper done, have 2012 with 2.0 engine. no pending codes. last weekend i saw LTFT at 15 on highway as well at idle. web searches suggested MAF or low fuel pressure, or injector can causes lean condition on highway. I am not sure if I have a MAF, scan tool doesn't show any values, so out of desperation i add can of sea foam to tank. so a week goes buy and i buy a OBDII app, OBD fusion. this one shows fuel pressure. not even a listing for MAF. pressure is 288lbs at idle, i take edge on highway, 1900lbs while accelerating, 1400lbs while cruising, and now I see LTFT at 6, and getting 30mpg at 70mph, seems like edge is running right. I still have LTFT of 15 at idle or coasting, but about 6 when crusing. App still doesn't show voltage for O2 bank1 sensor1 sensor, but since the sensor is new no concerns there. To measure tank fuel pump pressure you need a special Tee to put in fuel line to be able to attache gauge. So i have no idea what normal fuel rail pressure at idle should be, does anyone else know? a $10 ford mechanic manual on CD, from ebay, didn't have test procedure.. did the sea foam help or do i just have a intermittent problem? keeping finges crossed.
looks like I was careless, the scan tool was showing bank1 sensor 2, which is after cat, my scan tool cannot show bank1 sensor1 , i guess the new wide band O2 sensors are something different. no codes were set, new up stream O2 sensor didn't help my MPG, I see at idle my LTFT is high, 15. I need to see what it does on the highway, finding scantool software that will let me read fuel rail pressure sensor, ( 2000psi) may be difficult, starting to think a visit to dealer is un avoidable..
no check engine light set, I noticed the cruise @ 70mph MPG dropped from near 30 when i last checked it to 22-23. picked up one those cheap blue tooth OBDII scanners, and saw O2 sensor was lazy, not switching very fast at all, new O2 coming in soon. It is such an easy job, and going to dealer such a pain, and I doubt Emissions warranty covers it, I am doing it myself.
Sure am anxious to learn how to change tranny fluid myself
perrytime replied to perrytime's topic in Transaxle (FWD)
okay, there is a ford mechanic on youtube that does lots of ford videos, I emailed him and he sent me a pdf file. the proceedure for a newer edge with sealed transmission, remove a drain plug on bottom of tranny. after fluid is out replace plug. there is a read cap on fill tube cleverly hidden under a radiotor/heater hose, almost directly in front of battery near radiator, as i recall. there is a plug on side where axle comes outof transaxle, put fluid in fill tube till it comes out this plug. seems like you need to button it all up, get tranny hot, and repeat fill proceedure on hot tranny. if someone wants me to forward pdf file to them, get me your email. -
no issues, went 8k miles without adding oil, must have been that zmax stuff disappearing.
14 Month Fuel Economy Results & Impressions
perrytime replied to Gimp's topic in EcoBoost Mod & Tech
Am I correct in understanding all the data is based on the trip computers read out? Only had ours a few months, but the wife consistantly, 5 or 6 tanks now, says she puts in a gallon more than the trip computer says was used, and thus our MPG is sub 20mpg even though trip computer is 22-23ish. thats not much better than the 96 windstar with 335,000 miles we replaced with the Edge. Anyone else notice if fill ups are always more gallons than trip computer says was used? -
Okay, I have a new theory, I just remebered, that during the sales process I was shown what service was done to the Edge, namely the oil changed, and I saw they added Zmax. I looked on the web and found it is normal for the Zmax to disapear (absorbed, evaportaed, whatever), and is normal to see levle on dip stick drop first few hundred miles. So seeing 12 ounce drop on the dip stick is 3/4 quart. I though i was down a full quart, but will adimit I might not have been that accurate. May update Oil level remained same for last few hundred miles, so feeling good it it was just Zmax disappearing, SO I topped it off and feel good all is well.
Found a new glass treatment
perrytime replied to Bob C.'s topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
good tip, I like "invisible glass", super easy to apply, no haze or buffing. doesn't last too long, but easy of application is my priority. -
I know on a windstar, heavy spray of wd40 into door latch opening helped.
okay, oil level holding steady now for over a week, so I feel good there is no issue with the Edge using oil.
Okay, I have a new theory, I just remebered, that during the sales process I was shown what service was done to the Edge, namely the oil changed, and I saw they added Zmax. I looked on the web and found it is normal for the Zmax to disapear (absorbed, evaportaed, whatever), and is normal to see levle on dip stick drop first few hundred miles. So seeing 12 ounce drop on the dip stick is 3/4 quart. I though i was down a full quart, but will adimit I might not have been that accurate. So I need a few hundred more miles to see if the oil level stays or keeps dropping before i take it to the dealer. Hoping for the best, and for now, the knot in my stomach is almost gone with my new theory.
2.0 engine, more activity with a duplicate post on main edge forum. Dealer showed no prior work for oil issue, next will let them service it, look for leaks, and begin monitoring.
Yes, a 2012 edge, 2.0 ecoboost, just purchased 3 weeks ago with 8500 miles on it, the GM dealer serviced it before the sale, I checked dipstick and it was full when I got it, 1 weeks ago it was down 3/4 quart, and now it was at add mark, down a full quart, about 450 miles since purchase. I stopped by Ford dealer today, pulled up service records for VIN, no issues, other than software updates, all local to Florida. They want to do an oil change, look for leaks, and monitor as next step, as i expected. Of coarse they said 1 quart per 1000 miles is in spec. I see no smoke out tail pipe, I looked thru gap at rear of shield, no oil drips off engine. A bad PCV valve can also be possible issue. Besides turbo, rings, valve stem seals, who know where else a vacuum leak inside engine could be pulling in oil
I am experiencing same issue on just purchased, used edge, hope you have positive news on Ford fixing it.
Very concerned, here on week 3 of owning my 2012 ecoboost edge, purchased with 8500 miles on it from big GM car lot, had fresh oil change, and I see the oil is down to add mark after just 450 miles, I know it was full when I bought it, and last week i saw it at 3/4 down. So its off to the Ford dealer to see what they have to say. Quite a damper on my enthusiasm over purchase of the most expensive car i have ever bought., by 2x. I have a friend that has been fighting high oil consumption on Tahoe, a fully documented tech bulliten on the issue and dealer is fighting, saying usage is with in limits, just wont do the right thing, No drips, but that big shield, might be hiding something. I am afraid dealer will put me thru hoops of proving the consumption, several trips in for them to check it themselves. Just posting to see if anyone else has had issue and see if anyone has advise.
FYI - here is the article - another article indicated the run on of a pump after shutoff was bassed on temp sensor at trubo. will see if I hear anything after summer is hear. http://www.trucktrend.com/roadtests/suv/163_1011_2011_ford_edge_ecoboost/viewall.html
I only have 10k on odometer, plenty of time to find my answers, I will see what the prevailing data and opinions are in a few years when I would anticipate it should be changed at 60-70k. It's just the way I like to maintain vehicles, I like them to last a long time.
