Larry
    4
About Larry
1,145 profile views
  • Haz
Larry's Achievements
  1. BMS reset did NOT work on my car 2013 Edge sel Larry
  2. Thanks to all that responded, I'll do the pass light and brake pedal and the sleep for 8 hours . I did the 5 bright light flashes, 3 pumps on brake pedal . This did NOT work on my 2013 Edge sel
  3. Haz, Thank you very much. I'll do the 8 hour undisturbed, see what happens. I installed the new battery and started using car, not thinking or knowing about reset. Low battery message has only come on twice in the 6 month since new battery was installed. Get message when startinng. Thanks again Larry
  4. Hello, Could anyone tell me how to reset the BMS on 2013 Edge sel , without tools. I get low battery message. Battery is only 6 months old and tested fine. Thanks Larry
  5. Thanks much for the info. I see the canbus bulbs have built in resistor. Pretty salty, might just leave stock ????? ?
  6. Hello, Could anyone tell me if I can replace the stock rear turn signal bulbs with led bulbs. 2013 Edge SEL Thanks Larry
  7. WWWPerfA_ZN0W, I just thought I would throw the question out to you guys to see what others thought. I too am leery of adding to the coolant or oil. Larry
  8. Hi David, Next time I get to wally world I'll check out Royal Purple. I purchased the bars leak lube for winterizing my pressure washer. Couple ounces of anti freeze and small amount of bars leak lube. The I thought it may help prevent failure of water pump in my Edge. ( very poor design ) I'm also retired, 76 years young, have time on my hands and like you always thinking about over kill , must be how we were raised?? Our Edge has 68,000 on it now, So far no problems. I did change belts, more over kill. Still have original tires and brakes. Hard to believe how well the Michelin tires wear. Rotate about 7,000 miles. I switched from Motorcraft synthetic blend oil to Valvoline full synthetic . After switching oil the mpg increased about 1 mpg, engine is quieter and smoother. We take a 3 to 4 thousand mile road trip every year, average mpg has been 26.6 - 26.7 I think pretty good. I drive the speed limits or a little over. Sorry about being long winded Larry Northwest, In.
  9. Hello, I would like your thoughts about using bars leak water pump lube to help prevent failure. I changed coolant at 60,000. Only 68,000 on car now. I posted picture of what I'm talking about 2013 Edge 3.5 Thanks Larry
  10. No I haven't noticed distortion there but do have some on both left and right bottom corners
  11. I was chiming in with akirby about finding new dealer with a example of a bad one. Sorry I didn't ask a question.
  12. My Nephew has a 2017 f-150 3.5 . Dealer just resealed his pan. I told him to keep a close eye on it. I also told him not to take truck to that dealer. Bad dealership. Techs are ok but what they are told to do is the problem.
  13. Wow, rust at 28,000. I would raise hell if dealer doesn't replace hatch. My 2013 has 64,000 Northern Indiana miles, salt etc. No sign of bubbles/rust anywhere. I do preventative liquid wax in bottom doors seams and hatch seam. I have to squat down , pull hatch down enough to squirt liquid wax in seam. I leave the wax in the seams. Just add more each fall. Rinse and blow out seams , let dry . For the hood I saturate small piece of cloth and push wax into seam.
  14. Is the oil pan plastic like the f-150 I have a 2013 Edge 3.5 aluminum pan. Larry
  15. Catch Can? Why? Which engine do you have? Thanks Larry 2013 Edge 3.5
