About Adarcla3
Adarcla3's Achievements
New Headlights Needed
Adarcla3 replied to ar&wr's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
http://store.ijdmtoy.com/Ford-EDGE-Aftermarket-Projector-Headlights-p/2lhp-edg07-tm.htm These are on my wishlist, I also have a 2007 AWD. -
I have no issues with reception, though I have not gone out of town recently. And honestly I listen to more XM than anything else. Plus I have the regular antenna in the glove box and quickly change if needed. The large sun roof is good for something :-)
License plate LEDs added
Adarcla3 replied to Adarcla3's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Just the normal T10 5smd bulbs you can get anywhere. I purchase most of my LEDs from tmart.com (I am cheap and they have good deals) The big change is that removed the bulb housings and lined the interior of them with silver reflective tape. -
When I need the room I have 10" Fosgate that can put in back, and when I want to be a kid again I can put the two 12" Fosgates in. The box with 12's I have had for almost 10 years, just changed the woofers a couple times and added some vinyl. The 10" box the wife and built last summer in case we need more cargo room. (The red vinyl was on close-out $2 for the whole piece) ** Yes she is 7 months pregnant in the picture - so I knew I would need more room Both boxes are driven by an Old School Punch 200dsm mounted in the spare tire well. (Tuning is needed when swapping, but can have the change done in about 10min)
LED interior and Cup Lights
Adarcla3 replied to Adarcla3's topic in Interior, A.C., Heat, Interior Trim
Hardwired to an ignition hot, on when the car is on, open fuse in the fuse panel. I also have an over-ride switch mounted next to the hood release that I can turn them off as needed. http://www.tmart.com/24-LED-Strip-Car-Lights-Flexible-Grill-Light-Blue-12V_p84769.html ***I love tmart.com I have used them to convert both cars to all LED inside and out for a lot less than retail*** These are the lights I used under the dash, and under the rear seat. For the cup holders, I used a Blue LED (12v with 100ohm resister wired in series) I got those from FRY's electronics for $3.99. -
Gear Shift Knob recovered
1) I popped the side leather pieces off, they are held in place with plastic tabs. Small screw drive worked perfect. 2) I then removed the chrome trim piece that rides across the top of the shift knob, it looks like a huge flat plastic fish hook once removed. 3) Alcohol cleaned the plastic 4) Cut the vinyl slightly larger than the trim piece 5) Pulled the vinyl onto the trim piece, making sure it is tight around the edge 6) Put back together (the side leather pieces do a great job hiding the bunched up vinyl near the tight corners)
