ravishingrocket
Everything posted by ravishingrocket
I recently upgraded my bulbs to LED and noticed this. I first thought it was a bulb issue, so i swapped bulb sides and it still is the same. The headlights turn on, but there is very little light on the drivers side. I was in a fender bender a few years ago where there was some damage done to the front drivers side. I dont think the headlight needed replacing but wondering if there might be some kind of internal damage thats causing it to appear like its not working
I puchased this and the outlet is far too big to fit the front passenger spot on my 2013 Edge. Maybe the space is a little bit bigger in the 2015+ Edge? It does appear it will fit the rear of the center console for the 2nd row. I will posts pics when i get around to installing
I found the part number for the dual usb outlet. FB5Z-19A495-AA
Bump. Anyone have part numbers or links to the dual usb outlet covers? I cant seem to find them
Has anyone else had gasket material ooze out around the liftgate latch? I have cut away gasket before but more just slowy squeezes out
I think that was it. Thanks!
I tried searching, but nothing came up. I remember reading a post where someone swapped out the cig lighter port for an oem usb port. Can anyone link me to that thread or know of an oem style port i can purchase? Thanks
Frustration with Ford delivery information
ravishingrocket replied to GJCATL's topic in Buying, Leasing & Ordering
I had a similar experience when i ordered my edge back in 2013. Dealership was nice and informative until i handed over money for deposit then gave me the run around. Was told car would arrive in 4-6 weeks. Took over 10 weeks- 4 replies
- dealership
- buy
- (and 6 more)
Line out converter ?'s
ravishingrocket replied to fishx65's topic in Audio, Backup, Navigation & SYNC
Get an amp with it built in -
I've read a few threads that said to tap the remote wire into fuse 35. That works fine if I only want the amp on when the engine is running. How can I go about wiring the remote wire so whenever the stereo is on the amp is on and off when its off? I tried tapping into the power wire for the display screen, but when the screen went off the amp stayed on
I am looking at adding the JL Audio JX500/1D amp that has speaker level inputs, which require speaker wire to RCA adapters. Can I run this amp alone or would I still need a processor like a LC2i? I will be running one sub
Noise from dash area
ravishingrocket replied to EspoMan's topic in Interior, A.C., Heat, Interior Trim
Tapping on this panel duplicated my rattling noise. I just put some foam padding behind there and no more noise. -
No interior lighting?
ravishingrocket replied to cdubb's topic in Interior, A.C., Heat, Interior Trim
I added the cup holder lights to my 2013 SEL. Bought the oem ones on ebay. U can always get the universal ones tho.... -
I am going to add a Curt hitch to my 2013 SEL and I am getting a 5x8 Carry-On brand trailer from Lowe's. Would a 3/4" rise/2" drop ball mount be what I need? If not, what size do I need? Thanks
Front alignment needed?
ravishingrocket replied to ravishingrocket's topic in Brakes, Chassis & Suspension
Shouldn't be any unusual wear. I only have 7200 miles -
I shot you the info. Thanks -
My 2013 SEL will pull to the left and I have to hold the steering wheel a little bit to the right with some force in order to drive straight. If I move the steering wheel straight or let go, it immediately pulls to the left. This issue becomes more apparent the faster I travel. It has been like this for as long as I can remember. I bought it new and have had it almost a year now. I keep my tire pressures at normal levels. I have not hit any large potholes or anything to throw off the alignment. I have read about people having issues with it pulling to the right and some people having "bad" tires replaced. Anyone else have alignment issues to the left? I have not taken it to the dealer or anywhere to get looked at. Between work and toting kids around, I dont have time to run all over the city and get the run around. I have read on here people have gotten 3-4 alignments done and their problem still persists.
I have this issue too. Dunno what it is
